Tony, even though BU-353 has been out for about 5 years now, it still is a very good performer. The occasional issues you may hear, may be specific to the particular installations, and may have very little to do with the quality of the GPS unit.
If you are really set against BU-353, have a look at Quarz Q818X. It is based on the MTKII chip, which may even be a dB or two more sensitive than BU-353's SiRFstarIII chip. But keep in mind that BU-353 is one of few units that are weatherproof and w/magnetic base. By placing BU-353 on the roof of the vehicle, you will gain more than a dB or two of signal strength.
Qstarz Q818X can work at 1, 2, 3, 4, or 5Hz. Some software takes advantage of this (eg. Garmin Mobile PC), and some doesn't (iGuidance).
Qstarz Q818X is a dual, Bluetooth and USB, GPS receiver. You have the option to use BT or USB, which ever suits your needs.
But pretty much any modern GPS unit has a very decent performance these days.
In BU-353 we trust.
LinkBack URL
About LinkBacks
