Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 35
Thread: BU-353 cuts out unexpectedly
  1. #11
    Mar 2006
    Montreal
    rather than hack the cable, hack a usb extension instead hehehehe
    tried from inside dash (working before) to top dash, and then roof, same issue now..
  2. #12
    Sep 2005
    firing up an old thread here...forgot to subscribe to this.
    I think it might be more of a com port/xport issue. If I restart Xport, the GPS comes back online.
    This happens very inconsistently, can't figure out what triggers it to make it repeatable.
    My vehicle isn't garage parked, always has a clear view of the sky.
  3. #13
    Feb 2010
    This happened to me too, I thought it was the positioning of the puck. It is currently under the center console, right beside the emergency brake. Is there any known fix for this other than rebooting?
  4. #14
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    With XPort, you can look at the bottom of the window. If it says "Port Doesn't Exist" then there's a hardware problem or the driver isn't working. Try the latest. If it says "No Data Stream" then the GPS itself isn't working but the USB interface is. If it says "NMEA Data" with 0SVs, then it most likely needs a better view of the sky.
  5. #15
    Sep 2005
    Pomona, CA
    Resurrecting:
    I have some similar issues with my BU-353 and I do park in an underground garage in multiple locations. The main issue I have with my unit is that it either takes a really long time to get the signal back after exiting the garage or it doesn't get it back at all until I hibernate with a clear view then resume. I have some other intermittent issues of losing signal for no apparent reason (clear sky, had fix just before, located under the bottom corner of windshield), but that doesn't bother me as much as the issue after leaving the garage(s).
    I will try and pay more attention to what Xport says when this happens to see if I can find any clues.
    Carputer Progress:
    Re-do fabrication of screen [DONE]
    Add mini-USB and micro-USB power from M2-ATX [DONE]
    Teardown PC [100%]
    Add HDMI > VGA converter [0%]
  6. #16
    Dec 2008
    i think im going to put a switch linline the usb cord for my gps puck. it was working great for months, but now sometimes after a few hibernates it will cut out, and not long after that i get a system blue screen with a "driver power state failure". in any caee, a system restart always gets it working perfectly again for a few hibernates.
    ill post back if i figure out whats going on, it seems to me if i can just reset the usb connection when needed it should work better... i hope...
  7. #17
    Feb 2003
    SE, PA
    Ive had the same problem too, with the G945CLF2 board and BU-353..but it happens only once in a while and usually clears up within a few minutes.
    G945GLCF2 | 512MB RAM | 160GB HD | Holux GPS w/ Routis | XMPCR w/ TOSLINK mod | Audigy 2 NX | | Xenarc 700TSV |Opus 150W PSU.
  8. #18
    Sep 2005
    It deteriorated to the point where the GPS just wouldn't work. I rebooted (not hibernate), no luck. kept trying to rescan w/ xport, it would find it, GPS shows up but then disappears after a few seconds. Tried different USB port, no luck. I started thinking it was finally dead.
    Then I downloaded the latest Xport, it has since been revised since last I checked. Got it up and running and so far it works flawlessly. Knock on wood.
  9. #19
    Jun 2008
    I've been having what I think might be a similar problem. I haven't changed anything lately (at least I don't recall changing anything) with my system, but the past few days the gps signal will just cut out and I haven't found anyway for it to come back except to reboot the computer. Typically I have my gps antenna going into a usb hub, and then use xport to split to two different com ports (for iguidance and rr). Now it will work for a random length of time, anything from only a few minutes to an hour or so, and then it cuts out so that the gps program behaves as though I have the wrong port set or the antenna unplugged. I haven't noticed anything in xport when this has happened in the past, I'll have to open it up and see if it displays anything as mentioned above. Also, I never hibernate, I always power the system off when I turn off the car. Is there a chance that the gps antenna is just starting to fail?
  10. #20
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    Probably xport. Don't try anything else until you have updated it.
    CAR: 2007 G35 Sport Coupe 5AT
    HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
  1. Bu 353
    By sebberry in forum GPS
    Last Post: 09-04-2006, 09:35 PM
  2. FS : globalsat BU 353 gps receiver, brand new
    By skuller in forum Classified Archive
    Last Post: 08-02-2006, 09:20 AM
  3. WTB: BU 353 GPS receiver
    By penny1jordan23 in forum Classified Archive
    Last Post: 07-06-2006, 08:52 PM
  4. Can't get the BU 353 to work with Destinator plugin
    By inniss777 in forum Centrafuse
    Last Post: 11-24-2005, 02:56 PM
  5. Can'BU 353 with Destinator plugin
    Last Post: 11-23-2005, 07:04 PM
Tags for this Thread
