Page 4 of 4 FirstFirst 1234
Results 31 to 35 of 35
Thread: BU-353 cuts out unexpectedly
  1. #31
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    thanks curiosity for your hard work and help
    i will see if it does it again... i have to prolific drivers in my system, one for bu353 and another for a usb to serial cable for my HD-radio... I have to narrow it down to see what is to blame...it is either the prolific driver or xport.. i will wait to see if i will do it again with the older prolific driver...if yes i will move on and connect my gps directly to the com port and see..
    does NMEA filtrer close the port and reopen it 100%??
    that might be usefull
  2. #32
    Apr 2006
    Greece
    ok it seems that the 2005 prolific driver did the trick..it has been 2 days now without a problem.. it is soon to say, bu i will keep u posted
  3. #33
    Apr 2006
    Greece
    ok just to let everybody know, changing the prolific drivers to 2005 solved all my problems...It has been 20 days now without a problem..Xport has been flawless..
    thanx curiosity
  4. #34
    Sep 2005
    Long term follow up:
    GPSGate now has a free client. I've been using this instead of Xport and it has been working flawlessly.
    • GPS always there, no dropouts.
    • No lag whatsoever between my actual position and what the GPS software says.
    • Resumes from hibernate perfectly.
    • Way fewer BSOD (I suspected xport might have been causing some of these).
    • Port sharing of the GPS for both the front end and my GPS software.
  5. #35
    Nov 2011
    Germany
    Hi everybody,
    i'm glad that i found this thread, cause i already thougt about sellling my BU-353. My problem is nearly the same, i use the BU-353 with TomTom and Centrafuse. But after a while, everything from 2 to 60 minutes is possible, the device "breaks" and i have to replug it.
    Can somebody post the 2005 Driver or give me some other possible solutions?
  1. Bu 353
    By sebberry in forum GPS
    Last Post: 09-04-2006, 09:35 PM
  2. FS : globalsat BU 353 gps receiver, brand new
    By skuller in forum Classified Archive
    Last Post: 08-02-2006, 09:20 AM
  3. WTB: BU 353 GPS receiver
    By penny1jordan23 in forum Classified Archive
    Last Post: 07-06-2006, 08:52 PM
  4. Can't get the BU 353 to work with Destinator plugin
    By inniss777 in forum Centrafuse
    Last Post: 11-24-2005, 02:56 PM
  5. Can'BU 353 with Destinator plugin
    Last Post: 11-23-2005, 07:04 PM
Tags for this Thread
