Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: bu-353 driver loading
  1. #11
    Nov 2009
    Thunder Bay, Ontario, Canada
    Quote Originally Posted by p057 View Post
    force it on port 1 if you dont use it for anything else so it doesn't have to scan so much. If you can force the touchscreen drivers onto another port, like 2 or 5 or something, that would be great too. Keep them always plugged into the same physical USB ports so that they don't get reassigned something else.
    this is exactly what i'd like to do. i just don't know how to go about it in xp. any help would be appreciated.
  2. #12
    Nov 2009
    Quote Originally Posted by Curiosity View Post
    The chimes from the monitor connecting/disconnecting are normal. It's just like unplugging your monitor. The brake switching the monitor sounds annoying though. I'd check on that. How is that wired? Something in the car to an input on the monitor? Are you sure it's not shorting anything?
    they are annoying. I've got a liiliput ebay701 w/ autoswitch. the switch is activated by a wire the needs to be supplied 12v. My camera also requires 12v. my truck has a harness designed for hooking up to trailer wiring, which has a reverse light wire that supplies 12v only when the truck is in reverse. I hooked that wire up to the camera's positive and then (in parrallel) spliced that wire to run to the cab of the truck where it connects to the 12v input for the monitor switch. the camera is grounded t the frame at the rear bumper. it seemed to work perfect until i realized that the monitor momentarily flickers about 1/10th of the time that i depress the brake pedal. annoying is right. with a multimeter on the 12v wire going to the input of the monitor, it occasionally reads a negative voltage when i press the brakes. I don't know how to fix this. could a diode wired in line stop this negative signal?
  3. #13
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Yes, a diode would help with the negative voltage. Just put it inline with the silver band toward the monitor. That would be the easiest to try.
    It will also drop the voltage a bit, so if the monitor is picking up a low signal (0.5V or less) frome the brakes that can filter it out. More in series can drop it more.
    The flickering is probably due to induction from the brake/reverse wires close together on a long run giving it similar characteristics of a transformer, just all pulled out straight. Transformers need AC to to work, but with DC it's 1 cycle so 1 little pulse.
    If a diode doesn't do it, then a relay will but then you get click noises when reversing. An optocouplers gets a little more complicated but would be nicer.
  4. #14
    Nov 2009
    ok, i'm going to install the diode tonight and watch the results for a while. but if i was to install a relay, could i put it in the cab so that the same wire that feeds constant 12v for the computer psu also supplies the relay, and the reverse wire that would goto the monitor is the switch for the relay? or would the relay's switch then be subject to the same affect as the monitor and give the same results?... also, i've never even seen the word "optocoupler" before! could you elaborate on that for me? btw.. thanks alot for the insight!
  5. #15
    Mar 2004
    Florence Yall, BFKY
    With the relay you would connect the coil to the reverse lights wire and ground - That would switch the relay on when you switch to reverse, but there won't be enough power to pull it down from just the brakes. The switch side (common) can be sourced from the monitor or PC power, and N.O. connects to the monitor input.
    An optocoupler is a small 4 or 6 pin DIL chip. It essentially has an LED in it that when emitting turns on a phototransistor. The LED side needs to be ~2.2v so a resistor is needed. 1.2K ohm would be fine to drop 16v to 2.2v. The other side would just be any 12v and the monitor input like the relay. It may be the same idea as the monitor has internally though, so the relay would be a better choice since it takes more current to turn it on.
    Hmm, a better idea would be a resistor, say 100 ohms, and an electrolitic capacitor after it between the wire and ground. That could suck up the short pulse before it gets to the monitor. Not sure what size though.
  6. #16
    Jan 2010
    Quote Originally Posted by thunderbay View Post
    wow this thread went a little off course, lol.
    Here's how to go about it (off memory) you can go to the My Computer icon, right click it, click "Manage".
    Go to the device manager.
    find the BU-353 which MAY be labelled as serial to usb or something weird (i dont know, i dont use any windows machines with my puck, i have it connected to a Linux machine in my car).
    Just look around for it.
    Right click it, click on properties.
    click the "advanced" tab when the new window comes up, may take a second or two.
    click on Advanced Port Settings
    leave everything else alone EXCEPT for the COM port number. Set it to something that is not in use OR com port 1. As long as you dont have any ACTUAL serial connections connected to your computer, you should be fairly safe forcing it on com 1. Click OK out of all those windows and tell your software to always check for port 1.
    Just remember to physically ALWAYS connect that USB puck to the same exact usb port on the computer, otherwise it changes port numbers. If you decide later that you need to change it, do the same thing i outlined above while plugged into that port. You can set them all to port 1 if you want, the computer will auto set to com port 1... at least it should. I'm basing this off memory since i haven't done any GPS stuff with windows in a long time.
    Good luck! let us know how it goes and if this was successful for you.
  7. #17
    Nov 2009
    hey thanks! that's what i've been hoping for, i'll give it a shot.
  8. #18
    Nov 2009
    ok, i forced the gps to com1 and it seems to be a little better. most of the time after coming out of hibernation it seems to detect the gps automatically. however once in a while, I have to goto settings>navigation and then select save without even changing any options and it works immediately.
    any ideas?
  9. #19
    Oct 2006
    sorry, if you tried this already, i only quickly skimmed the thread, but why not give xport a shot. i've never have any problem with xport and xp setup.
  1. Bu 353
    By sebberry in forum GPS
    Last Post: 09-04-2006, 09:35 PM
  2. WTB: BU 353 GPS receiver
    By penny1jordan23 in forum Classified Archive
    Last Post: 07-06-2006, 08:52 PM
  3. Can't get the BU 353 to work with Destinator plugin
    By inniss777 in forum Centrafuse
    Last Post: 11-24-2005, 02:56 PM
  4. BU 303 Driver
    By oekundar in forum GPS
    Last Post: 10-04-2005, 10:08 AM
  5. Need Driver For GlobalSat BU 303
    By Skuzzle in forum GPS
    Last Post: 12-28-2004, 11:09 AM
