Results 1 to 6 of 6
Thread: Issues with BU353
    Newbie Hicotton02's Avatar
    Aug 2010
    Murrieta, California, United States
    Issues with BU353
    Not sure where the issue lies, but I am not getting a lock with the receiver. I have the GPS on com 6 and xport sees it and passes it to COM 7 and 8. RR uses COM 7 and iG uses 8. Xport says low signal in the bottom toolbar. So it seems to me that the GPS is functioning but not getting a lock. I have the GPS unit under my passenger seat on my motorcycle. so there is a 1/8 in plastic piece and 2" of foam padding between the gps and the sky. Does it REALLY need to have a clear view of the sky? or is there something fundamental I am missing?
    Variable Bitrate chris350's Avatar
    Aug 2007
    Queens, NYC
    the only suggestion i can make at this point is to try moving the gps receiver ...
    CarPc
    Project "Driver"
    Planning [99.9%]
    Parts Collected [98.5%]
    Installation & Fabrication [98%]
    Total Completion Level [96.9 %]
    http://www.mp3car.com/vbulletin/work...ct-driver.html
    Aug 2010
    Ok, I will try to find a secure place to put it on the way home.
    Variable Bitrate sargeants's Avatar
    Oct 2008
    Ontario, Canada
    it's best to have it with a direct view of the sky, but doesn't necessarily need it.
    I've got my BU353 tucked up in the corner of my roof near the A pillar. I can get anywhere from 3-11 satellites depending on where I am in the city.
    Another check is to not run xport and set iG to use port 6, along with the correct baud. In xport, have you tried the 'find gps' button?
    03 Hyundai Elantra GT {Worklog}
    HP TC4400; 250GB SATA, WiFi, BT, 12.1" touch
    RideRunner; w/ mobilephone.net, OBDMPG, mediaart, RRMedia, DFXVoice and more...
    cmdRR tall skin creator
    86 Pontiac Fiero SE 2m6
    possible carpc install
    Aug 2010
    I moved it to the tank and it picked up 8 sats immediately. Apparently it doesnt like being attached to the computer case or power supply..now I have to get creative
    I am here: http://maps.google.com/maps?ll=33.319612,-117.150432
    Sep 2011
    Quote Originally Posted by Hicotton02 View Post
    The issue isnt' that the receiver "doesn't like being attached to the computer case or power supply"... It's that under your seat...under you, there isn't enough signal for the receiver to lock onto. GPS signals are usually between -150 and -160dbw at the earths surface. Cover that receiver or add body-coupling in and there's basically no chance for it to "hear" the signals above the noise floor. (Think "iphone death grip")
    It'll probably be a little difficult on a bike to get a good, safe placement that doesn't look out of place but it should be possible, like you said, with some creativity. I believe the BU353's are weatherproof, so that helps, just remember that the USB cable probably can't take very much heat or repetitive movement.
    Good luck. Let us know what you come up with.
  1. Gmpc & bu353?
    By Archy88 in forum Garmin Mobile PC
    Last Post: 02-18-2010, 04:55 AM
  2. Bu353 Gps
    By Mazda6gp in forum GPS
    Last Post: 06-01-2007, 12:34 PM
  3. WTB bu353 GPS
    By xs10x in forum Classified Archive
    Last Post: 09-24-2006, 04:45 PM
  4. Troubleshooting BU353??!!?
    By SciFiFan in forum GPS
    Last Post: 09-14-2006, 03:40 PM
  5. need some help, BU353 and route 66 GPS
    By edgley in forum MacCar
    Last Post: 02-28-2006, 05:03 PM
