Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: BU-353 battery
    Mar 2010
    Istanbul,Turkey
    BU-353 battery
    Keeps last stored position , date ,time , satellite data. I have some questions:
    1-This battery is rechargeble?
    2-What happens end of life? Can we change it?
    3-I bought my BU-353 at 2011. its 3 years old. Battery may died? its important if battery died? Or its not important. Can still work but late fix to satellites?
    Variable Bitrate chris350's Avatar
    Aug 2007
    Queens, NYC
    why are you asking/? i wasn't aware there is a battery on the inside.
    CarPc
    Project "Driver"
    Planning [99.9%]
    Parts Collected [98.5%]
    Installation & Fabrication [98%]
    Total Completion Level [96.9 %]
    http://www.mp3car.com/vbulletin/work...ct-driver.html
    Mar 2010
    Istanbul,Turkey
    Fixing satellites too late. I just want to know reason is dead battery?
    Feb 2011
    Might be. When my battery on a different receiver (ublox5) went weak (after 2 years), it was sometimes not found on USB anymore and took very long time to get charged again and then also only lasted a few days without power before being not found again.
    I tried to change the battery, but it was built in, so I had to buy a new receiver.
    Its a big deal for me since I only drive my car in spring and summer. The rest of the year it sits in a cold garage without power to the battery and I guess thats not so good for it. I hope this time it lasts longer, but its already a year old again. It seems to get fixes very slow after it was without power for a long time, but once the battery has been charged for half a day or so, it get a 3D fix even in the garage very quickly.
    Mar 2010
    Istanbul,Turkey
    I will try to change battery but its not easy. Have a metallic cover and no screw. But i will try. its ok if i break it because in this way annoying.
    Do you know what kind battery using BU-353 inside?
    Feb 2011
    Im not sure, since I had a different one. It should be some kind of button cell, though.
    I think mine was implemented the same way yours is. Metallic clamp to hold it in place and soldered onto the PCB. I attached a picture.
    Mar 2010
    Istanbul,Turkey
    Mine looks like this:
    Mar 2010
    Istanbul,Turkey
    Mar 2010
    Istanbul,Turkey
    Batterty information:
    Part Number: MS621FE
    Manufacturer: Seiko Instruments
    Short Description: BATTERY LITHIUM 3.1V RECHARGE
    Mar 2010
    Istanbul,Turkey
    Disassembled battery from PCB. I will use battery holder outside. I will solder battery holder's cable to PCB and holder will stay out. Should i use high capasity AA or AAA battery? USB can charge it?
  1. Replies: 3
    Last Post: 01-08-2012, 05:05 PM
  2. Replies: 7
    Last Post: 06-01-2008, 12:36 PM
  3. Replies: 13
    Last Post: 07-30-2006, 07:09 PM
  4. Dual-battery setup with a smaller battery?
    By kbyrd in forum Power Supplies
    Last Post: 12-10-2005, 02:17 PM
  5. Replies: 3
    Last Post: 08-04-2004, 05:52 AM
