Results 1 to 7 of 7
Thread: BU-353 lasted about a week
    Constant Bitrate Rickk's Avatar
    Feb 2013
    Western Massachusetts
    My BU-353 lasted about a week. I think sitting in a somewhat warm car in the sun killed it.
    It locked up instantly when I first got it.
    After a few days it took several minutes to lock up.
    Now it wont lock up at all.
    Time to try something else.
    Rick
    VegasGuy's Avatar
    May 2009
    Las Vegas
    Hmmm I don't know. I had a BU-353 on the roof of my truck for about 3 years here in Vegas. Never garaged and rarely in the shade. It's now been sitting on a ledge outside my window in the direct sunlight for the past 2 years...never out of the elements or the heat, and always worked as expected. I'd bet moisture or just a plain manufacturing defect before I'd suspect heat. Likewise for all my radio and wifi gear. Just about 3 years in the truck without a break...and no failures that I could detect.
    Feb 2013
    Dunno... maybe I got a bad one... I do see a thread here with others complaining about them dying as well. It may have been the heat opening up a crappy solder joint.
    I would think they would make them out of white plastic instead of black plastic to start with.
    Anyway, I ordered a BR305-PS4, which is also made by USGLOBALSTAT. It appears to be made for permanent outdoor mounting. It is rated for a bit hotter (85 C verses 80 C). The claimed lockup time is quicker.
    One thing that I am concerned with is where the heck to mount it. I have a perfect spot, which is also a perfect spot for an outdoor WiFi antenna. I hear they interfere sometimes... I will have to play with that a bit before I drill any permanent holes. Another thing I am not thrilled with is the PS/2 connector, requiring an adapter to go to USB. The PS/2 connector is big, and it is going to be a hassle to run the wire thru where I need to run it.
    Time will tell I guess.
    Rick
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    My BU has been on the dash of my truck on the windshield for 3 years, no issues yet...trucks been sitting out side all summer not driven with the windows up and locked, so who knows, hopefully you just a bad one
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    I have bought over 70 bu-353's and s4 models and I find it's like rolling the dice whether you have a good one or a bad one. That's why I settled in on the sure development board and all it's benefits i.e. multiple connection options, exterior antenna with a long cable and low power consumption. Just my 2 cents SNO
    Sep 2012
    Germany - Munich
    Feb 2013
    I just noticed the thread on the internal battery.
    While I only used my BU-353 for a week in the truck, I actually bought it close to 2 years ago.
    I wonder if that might be the problem. The symptoms sort of match.
    I may mess with it when I get the chance, just to understand what went wrong.
  1. $25 off for 1 Week
    By Jensen2000 in forum MP3Car Products - store.mp3car.com
    Last Post: 11-17-2009, 09:20 AM
  2. $25 off for 1 week
    By Jensen2000 in forum Announcements
    Last Post: 11-16-2009, 11:09 AM
  3. Poll: How long has your car PC lasted?
    By Bugbyte in forum The FAQ Emporium
    Last Post: 09-20-2006, 03:31 PM
  4. FS: 2 Week Old AMD 64 3200+ 2.2 GHz
    By mangina24 in forum Classified Archive
    Last Post: 04-04-2005, 10:40 AM
  5. hell week?
    By cubanmoses in forum Off Topic
    Last Post: 09-02-2003, 11:14 PM
