Results 1 to 10 of 19
Thread: OBDII Module doesn't work
    Lok
    Lok is offline
    VENDOR - Portal Media Lok's Avatar
    Feb 2008
    I guess this message is for chuck. I am unable to get the OBDII Module to work in streetdeck. I can get the scan tool program to work just fine in windows but streetdeck doesn't seem to like it. I have the log file below in verbose mode. I am using the ELM Scan device from your webstore.
    INFO: ************************************************** ******************************
    INFO: StreetDeck Application Data Log
    INFO: Log started: Tuesday, February 26, 12:26 PM
    INFO: Log set to VERBOSE mode
    INFO: Application Version: 1.1.1.0
    INFO: Command Line: -verbose
    INFO: Program Path: (C:\Program Files\StreetDeck)
    INFO: Application Data Path: (C:\Documents and Settings\Alok Car PC\My Documents\StreetDeck)
    INFO: Music Path: (C:\Documents and Settings\Alok Car PC\My Documents\Index)
    INFO: Unindexed Music Path: (C:\Documents and Settings\Alok Car PC\My Documents\My Music)
    INFO: Videos Path: (C:\Documents and Settings\Alok Car PC\My Documents\My Videos)
    INFO: Pictures Path: (C:\Documents and Settings\Alok Car PC\My Documents\My Pictures)
    INFO: CAppData::OnPreCreate - Finished
    INFO: CNAVController::CreateHostWindow - Creating mappoint host window.
    INFO: CMappointCtrl::GetClsid - Using StreetDeck control id
    INFO: CNAVController::CreateHostWindow - GetCtrlSite.
    INFO: CNAVController::CreateHostWindow - PaneState.
    INFO: CNAVController::CreateHostWindow - EnableBusyDialog.
    INFO:
    OnPreCreate - Initialization time 0.234 / 0.234 seconds.
    WARNING: UV_GetUpdateList - The system cannot find the path specified. (ERROR=0x00000003)
    INFO: CDrawWnd::Create - DirectX object successfully created!
    INFO:
    Direct3DCreate9 - Initialization time 0.078 / 0.312 seconds.
    INFO:
    PreEnumerate - Initialization time 0.000 / 0.312 seconds.
    INFO:
    Enumerate - Initialization time 0.016 / 0.328 seconds.
    INFO:
    BrushCreate - Initialization time 0.000 / 0.328 seconds.
    INFO:
    RenderWindow PreCreate - Initialization time 0.000 / 0.328 seconds.
    INFO:
    RenderWindow Create - Initialization time 0.015 / 0.343 seconds.
    INFO:
    Init Loading Logo - Initialization time 0.000 / 0.343 seconds.
    INFO: CDrawWnd::Create - Main render window successfully created!
    INFO: CDrawWnd::Create - Creating main application...
    INFO: CUVAppData::OnCreate - Navigation controller successfully initialized!
    INFO:
    Window / Direct3D Create - Initialization time 0.016 / 0.359 seconds.
    INFO: CAuthorize::ReadIdeDriveAsScsiDriveInNT - Found Drive Serial Number! (serial: S0BUJ10L541806, controller: 0, drive: 1
    WARNING: CAuthorize::ReadPhysicalDriveInNTWithZeroRights - DeviceIOControl IOCTL_STORAGE_GET_MEDIA_SERIAL_NUMBER error = 6
    WARNING: CAuthorize::ReadPhysicalDriveInNTWithZeroRights - DeviceIOControl IOCTL_STORAGE_GET_MEDIA_SERIAL_NUMBER error = The request is not supported for this device.
    INFO: CAuthorize::ValidateRegistrationInfo - Validating Registration codes (FWOHWXWY, BAXEWCOX)
    INFO:
    LoadRegInfo - Initialization time 0.078 / 0.437 seconds.
    WARNING: UV_GetFileList - The system cannot find the file specified. (ERROR=0x00000002)
    INFO:
    Init Plugins - Initialization time 0.000 / 0.437 seconds.
    INFO:
    OneTimeDOne - Initialization time 0.156 / 0.593 seconds.
    INFO:
    OneTimeSceneInit - Initialization time 0.000 / 0.593 seconds.
    INFO:
    FindBestWindowedMode - Initialization time 0.000 / 0.593 seconds.
    INFO: CDrawWnd::Initialize3DEnvironment...
    INFO: CDrawWnd::Initialize3DEnvironment - Successfully created D3D device!
    INFO: CRenderEngine::InitDeviceObjects...
    INFO: CRenderEngine::RestoreDeviceObjects...
    INFO:
    RenderEngine Init - Initialization time 0.188 / 0.781 seconds.
    INFO: THREAD ID:3016 = CDrawWnd::LoadingThread
    INFO:
    PreInitDeviceObjects - Initialization time 0.078 / 0.859 seconds.
    INFO:
    StatsFont - Initialization time 0.016 / 0.875 seconds.
    INFO: Initializing POI database...
    INFO:
    OnInitDeviceObjects Start - Initialization time 0.328 / 1.203 seconds.
    WARNING: CInfillOverlay::OnStartup - Error opening infill device hardware (1), trying again! (Open Failed!)
    WARNING: CInfillOverlay::OnStartup - Error opening infill device hardware (2), trying again! (Open Failed!)
    WARNING: CInfillOverlay::OnStartup - Error opening infill device hardware (3), trying again! (Open Failed!)
    INFO: CInfillOverlay::InitDevice - Infill drivers not present (C:\Program Files\StreetDeck\T3devControl.dll or C:\Program Files\StreetDeck\InfillG4Cmd.dll)!
    INFO: CAppData::OnInitDeviceObjects - Using skin Default
    INFO:
    Folder Init - Initialization time 14.953 / 16.156 seconds.
    INFO: CSoundController::InitDeviceObjects...
    SetFormat(hr=0x08887800INFO: Loading Textures...
    INFO: CTextureBag::LoadTextures...
    INFO: THREAD ID:1580 = DownloadHttpFile
    INFO:
    Load Textures - Initialization time 0.047 / 16.203 seconds.
    INFO:
    Load Logo Texture - Initialization time 0.000 / 16.203 seconds.
    INFO: Initializing Textures...
    INFO:
    Initialize Textures - Initialization time 0.000 / 16.203 seconds.
    INFO: Initializing Speech Controller...
    INFO:
    Init Speech - Initialization time 0.000 / 16.203 seconds.
    INFO: Initializing Media Event Processor...
    INFO:
    Init Media Event Processor - Initialization time 0.000 / 16.203 seconds.
    INFO: Initializing Volume Control Textures...
    INFO:
    Init POI DB - Initialization time 0.000 / 16.203 seconds.
    INFO: Initializing media manager CDVDManager device objects...
    INFO: Initializing media manager CiPodManager device objects...
    INFO: Initializing media manager CLaunchCastManager device objects...
    INFO: Initializing media manager CXMRadioManager device objects...
    INFO: Initializing media manager CRadioManager device objects...
    INFO: Initializing media manager CTVManager device objects...
    INFO: Initializing media manager CVideoFileManager device objects...
    INFO: Initializing media manager CAudioFileManager device objects...
    INFO:
    Init Media Managers - Initialization time 0.015 / 16.218 seconds.
    INFO:
    Enumerate Apps - Initialization time 0.000 / 16.218 seconds.
    INFO: CAppData::LoadSkin - Loading skin Default...
    INFO: CAppData::LoadSkin - Loading skin C:\Documents and Settings\Alok Car PC\My Documents\StreetDeck\UI\Skins\Default\Skin.skn...
    INFO: CAppData::LoadSkin - Loading PanelList...
    INFO: CAppData::LoadSkin - Loading OverlayZOrder...
    INFO: CAppData::LoadSkin - Loading Colored texture list...
    INFO: CAppData::LoadSkin - Loading SystemMetrics...
    WARNING: CAppData::SetSystemMetric - The specified skins system metric eSMListNAVDirectionYOffset, 700 is outside the bounds (Min:-500, Max:500) allowed by it. The default value of 0 will be used instead.
    INFO: CAppData::LoadSkin - Loading SystemColors...
    INFO: CAppData::LoadSkin - Loading SystemFonts...
    INFO: CAppData::LoadSkin - Loading ImportedFonts...
    INFO: CAppData::LoadSkin - Finished loading skin...
    INFO:
    Load Skin - Initialization time 0.094 / 16.312 seconds.
    INFO: CAppData::OnInitDeviceObjects - Skin successfully loaded!
    INFO: CFontBag::InitDeviceObjects...
    INFO:
    Init FontBag - Initialization time 0.031 / 16.343 seconds.
    INFO: Creating CAlwaysVisibleOverlay.
    INFO: Creating CNetworkCommOverlay.
    INFO: Creating CRemoteMediaDestinationModule.
    INFO: Creating CWebServicesOverlay.
    INFO: Creating CWSUserNameRenameModule.
    INFO: Creating CWSPasswordRenameModule.
    INFO: Creating CWebServicesSettingsModule.
    INFO: Creating CComboSelectOverlay.
    INFO: Creating CMultiMonEnabledOverlay.
    INFO: Creating CMediaTimeOverlay.
    INFO: Creating CKeyPadNumbersOverlay.
    INFO: Creating CKeyPadLettersOverlay.
    INFO: Creating CKeyPadWebOverlay.
    INFO: Creating CKeyPadAlwaysVisibleOverlay.
    INFO: Creating CMediaPlaySpeedOverlay.
    INFO:
    Overlays - Initialization time 0.032 / 16.375 seconds.
    INFO: Creating CUserOverlay0.
    INFO: Creating CUserExtendedOverlay0.
    INFO: Creating CUserOverlay1.
    INFO: Creating CUserExtendedOverlay1.
    INFO: Creating CUserOverlay2.
    INFO: Creating CUserExtendedOverlay2.
    INFO: Creating CUserOverlay3.
    INFO: Creating CUserExtendedOverlay3.
    INFO: Creating CUserOverlay4.
    INFO: Creating CUserExtendedOverlay4.
    INFO: Creating CUserOverlay5.
    INFO: Creating CUserExtendedOverlay5.
    INFO: Creating CUserOverlay6.
    INFO: Creating CUserExtendedOverlay6.
    INFO: Creating CUserOverlay7.
    INFO: Creating CUserExtendedOverlay7.
    INFO: Creating CUserOverlay8.
    INFO: Creating CUserExtendedOverlay8.
    INFO: Creating CUserOverlay9.
    INFO: Creating CUserExtendedOverlay9.
    INFO:
    User Overlays - Initialization time 0.000 / 16.375 seconds.
    INFO: Creating CUserModule0.
    INFO: Creating CUserModule1.
    INFO: Creating CUserModule2.
    INFO: Creating CUserModule3.
    INFO: Creating CUserModule4.
    INFO: Creating CUserModule5.
    INFO: Creating CUserModule6.
    INFO: Creating CUserModule7.
    INFO: Creating CUserModule8.
    INFO: Creating CUserModule9.
    INFO:
    User Modules - Initialization time 0.015 / 16.390 seconds.
    INFO: Creating CSafeModulesOverlay.
    INFO: Creating CVolumeOverlay.
    INFO: Creating CBluetoothConnectedOverlay.
    INFO: BT Create
    INFO: Creating CBluetoothSettingsModule.
    INFO: Creating CBluetoothSettingsModuleWizard.
    INFO: Creating CBluetoothVolumeModule.
    INFO: Creating CBluetoothPairedDevicesModule.
    INFO: Creating CBluetoothPairingModule.
    INFO: Creating CBluetoothPairedDeviceStatusModule.
    INFO: Creating CBluetoothMainModule.
    INFO: Creating CBluetoothOptionsModule.
    INFO: Creating CBluetoothPhoneStatusModule.
    INFO: Creating CBluetoothDialNumberModule.
    INFO: Creating CBluetoothPhoneBookModule.
    INFO: Creating CBluetoothPhoneBookEntryModule.
    INFO: Creating CBluetoothEditPhoneBookEntryModule.
    INFO: Creating CBluetoothImportModule.
    INFO: Creating CBluetoothImportCSVModule.
    INFO: Creating CBluetoothImportBluetoothModule.
    INFO: Creating CListSearchOverlay.
    INFO: Creating CBluetoothStartModule.
    INFO: Creating CBluetoothActiveCallOverlay.
    INFO: Creating CBluetoothIncomingCallOverlay.
    INFO: Creating CBluetoothActiveCallModule.
    INFO: Creating CBluetoothSendTonesModule.
    INFO: Creating CBluetoothCallLogModule.
    INFO: Creating CBluetoothVoiceRecognitionOverlay.
    INFO: Creating CVolumeModule.
    INFO: Creating CAppSoundsModule.
    INFO: Creating CEnhancedAudioModule.
    INFO: Creating CWMEqualizerModule.
    INFO: Creating CBalanceFaderModule.
    INFO: Creating CMuteOverlay.
    INFO:
    Volume Modules - Initialization time 0.094 / 16.484 seconds.
    INFO: Creating CVoiceInputModule.
    INFO: Creating CVoiceInputSettingsModule.
    INFO:
    Voice Modules - Initialization time 0.000 / 16.484 seconds.
    INFO: Creating CMoveFileModule.
    INFO: Creating CRenameModule.
    INFO: Creating CGestureModule.
    INFO: Creating CGestureSettingsModule.
    INFO: Creating CGlyphSettingsModule.
    INFO: CGestureModule::LoadGlyphDataHelp - loading glyph data file (C:\Documents and Settings\Alok Car PC\My Documents\StreetDeck\Functions.gdf)...
    INFO: CGestureModule::LoadGlyphDataHelp - done loading glyph data file
    INFO: Creating CRelayModule.
    INFO: Creating CRelaySettingsModule.
    INFO: Creating CRelayPluginSettingsModule.
    INFO: Creating CConfigureRelayPluginSettingsModule.
    INFO: Creating CRelaySetSettingsModule.
    INFO: Creating CConfigureRelaySetSettingsModule.
    INFO: Creating CRelayRenameModule.
    INFO: Creating CChooseRelaysSettingsModule.
    INFO:
    Relay Modules - Initialization time 0.031 / 16.515 seconds.
    INFO: Creating CMediaChangeOverlay.
    INFO: Creating FunctionText.
    INFO: Creating FileOptionsOverlay.
    INFO: Creating CSystemRestoreModule.
    INFO: Creating MsgBox.
    INFO:
    MsgBox Modules - Initialization time 0.000 / 16.515 seconds.
    INFO: Creating CExternalAppsModule.
    INFO:
    External Apps Modules - Initialization time 0.000 / 16.515 seconds.
    INFO:
    Tray Overlays - Initialization time 0.016 / 16.531 seconds.
    INFO: Creating CFileSearchResultsModule.
    INFO: Creating CFileSearchRenameModule.
    INFO:
    EQ Modules - Initialization time 0.000 / 16.531 seconds.
    INFO: Creating CNetSyncSettingsModule.
    INFO: Creating CNetComputerBrowserModule.
    INFO: Creating CUserNameRenameModule.
    INFO: Creating CPasswordRenameModule.
    INFO: Creating CNetShareBrowserModule.
    INFO: Creating CRipMediaSettingsModule.
    INFO: Creating CRipMediaTransferModule.
    INFO: Creating CRipMediaSelectTypeModule.
    INFO: Creating CMediaDestinationRename.
    INFO: Creating CRipMediaOverlay.
    INFO: Creating CStartupSettingsModule.
    INFO: Creating CStartupSettingsModuleWizard.
    INFO: CStartupSettingsModule::OnNeedWizardProperties - Retrived hardware code: FWOHWXWY, Check Code: BAXEWCOX
    INFO: Creating CShutdownSettingsModule.
    INFO: Creating CDisplaySettingsModule.
    INFO: Creating CDisplaySettingsModuleWizard.
    INFO: Creating CCalibrateDisplayModule.
    INFO: Creating CInputSettingsModule.
    INFO: Creating CKeyboardSettingsModule.
    INFO: Creating CInputOptionsSettingsModule.
    INFO: Creating CGeneralSettingsModule.
    INFO:
    General Modules - Initialization time 0.047 / 16.578 seconds.
    INFO: Creating CShortcutsModule.
    INFO: Creating CSetTimeSettingsModule.
    INFO: Creating CSetTimeSettingsModuleWizard.
    INFO: Creating CSkinSettingsModule.
    INFO: Creating CColorSettingsModule.
    INFO: Creating CMultiMonSettingsModule.
    INFO:
    MultiMon Modules - Initialization time 0.015 / 16.593 seconds.
    INFO: Creating CMainSettingsModule.
    INFO: Creating CSyncSourceModule.
    INFO: Creating CSimpleSettingsModule.
    INFO: Creating CSystemInformationModule.
    INFO: Creating CStartModule.
    INFO: Creating CYahooSearchModule.
    INFO: Creating CShutdownModule.
    INFO: Creating CProcessShutdownModule.
    INFO: Creating CHelpModule.
    INFO: Creating CAboutModule.
    INFO: Creating CMusicStartModule.
    INFO: Creating CMusicModule.
    INFO: Creating CMusicSettingsModule.
    INFO: Creating CMusicSearchModule.
    INFO: Creating CMusicSearchResultsModule.
    INFO: Creating CMusicPlaylistModule.
    INFO: Creating CMusicArtistStringColModule.
    INFO: Creating CMusicAlbumStringColModule.
    INFO: Creating CMusicSongStringColModule.
    INFO: Creating CMusicGenreStringColModule.
    INFO: Creating CMusicArtistAlbumModule.
    INFO: Creating CMusicSelectFolderModule.
    INFO: Creating CMusicNowPlayingModule.
    INFO: Creating CMusicLoadedOverlay.
    INFO: Creating CMusicPlaylistContentsModule.
    INFO: Creating CMusicVMODStartModule.
    INFO: Creating CVisualizationModule.
    INFO: Creating CVisTitleOverlay.
    INFO: Creating CVisAlbumArtOverlay.
    INFO: Creating CRipMediaMusicModule.
    INFO: Creating CiPodModule.
    INFO: Creating the iPod module
    INFO: Creating CHDRadioModule.
    INFO: Creating CRadioSettingsModule.
    INFO: Creating CHDRadioKeypadOverlay.
    INFO: Creating CLaunchCastModule.
    INFO: Creating CLCUserNameRenameModule.
    INFO: Creating CLCPasswordRenameModule.
    INFO: Creating CLaunchCastLoadedOverlay.
    INFO: Creating CLaunchCastSettingsModule.
    INFO: Creating CLaunchCastStationGuideModule.
    INFO: Creating CLaunchCastFilterStationsModule.
    INFO: Creating CXMRadioModule.
    INFO: Creating CXMRadioChooseStationsModule.
    INFO: Creating CXMRadioStatusModule.
    INFO: Creating CXMRadioStationListModule.
    INFO: Creating CXMRadioSettingsModule.
    INFO: Creating CXMRadioSettingsModuleWizard.
    INFO: Creating CGirderModule.
    WARNING: CPluginBag::GetPlugin - LoadLibrary - The specified module could not be found. (ERROR=0x0000007e)
    WARNING: CPluginBag::GetPlugin - Could not load plugin (C:\Documents and Settings\Alok Car PC\My Documents\StreetDeck\Plugins\Input\InputG35SWC.dll )!
    WARNING: CPluginBag::GetPlugin - Could not load plugin (C:\Documents and Settings\Alok Car PC\My Documents\StreetDeck\Plugins\Input\InputPhidgetsEn coder.dll)!
    INFO: Creating CGirderSettingsModule.
    INFO: Creating CGirderPluginSettingsModule.
    INFO: Creating CPicturesModule.
    INFO: Creating CPictureSettingsModule.
    INFO: Creating CRipMediaPicturesModule.
    INFO: Creating CSlideshowModule.
    INFO: Creating CSlideshowOverlay.
    INFO: Creating CVideosModule.
    INFO: Creating CVideoSettingsModule.
    INFO: Creating CFullScreenVideoFileModule.
    INFO: Creating CFullscreenVideoOverlay.
    INFO: Creating CFullscreenVideoInfoOverlay.
    INFO: Creating CFullscreenVideoStoppedInfoOverlay.
    INFO: Creating CFullscreenVideoResumeInfoOverlay.
    INFO: Creating CFullScreenDVDModule.
    INFO: Creating CDVDSettingsModule.
    INFO: Creating CDVDOptionsModule.
    INFO: Creating CFullscreenDVDOverlay.
    INFO: Creating CDVDSelectSubPictureStreamModule.
    INFO: Creating CDVDInfoModule.
    INFO: Creating CDVDSelectAudioStreamModule.
    INFO: Creating CFullScreenTVModule.
    INFO: Creating CFullscreenTVOverlay.
    INFO: Creating CTVChannelChangeOverlay.
    INFO: Creating CTVPropOverlay.
    INFO: Creating CTVOptionsModule.
    INFO: Creating CRearviewCameraModule.
    INFO: Creating CRearviewCameraOverlay.
    INFO: Creating CRearCameraPropOverlay.
    INFO: Creating CRearviewCameraSettingsModule.
    INFO: Creating CConfigureRearviewCameraSettingsModule.
    INFO: Creating CVehicleModule.
    INFO: Creating CVehicleSettingsModule.
    INFO: Creating CRelayControlModule.
    INFO: Creating COBDIISettingsModule.
    INFO: Creating CVehicleGraphOBDIIModule.
    INFO: Creating CDiagnosticsModule.
    INFO: Creating CDiagnosticsViewCodeModule.
    INFO: Creating CNAVStartModule.
    INFO: Creating CNAVStatusModule.
    INFO: Creating CNAVFindAddress.
    INFO: Creating CNAVFindPlaceModule.
    INFO: Creating CNAVDBFindPlaceModule.
    INFO: Creating CNAVFindNearbyModule.
    INFO: Creating CNAVPOIModule.
    INFO: Creating CNAVCustomPOIModule.
    INFO: Creating CNAVMapModule.
    INFO: Creating CNAVFullScreenModule.
    INFO: Creating CNAVFullscreenOverlay.
    INFO: Creating CNAVViewFullscreenOverlay.
    INFO: Creating CNAVViewDirectionOverlay.
    INFO: Creating CNAVViewListOverlay.
    INFO: Creating CNAVViewStatusOverlay.
    INFO: Creating CNAVGPSTrackingOverlay.
    INFO: Creating CNAVClickedLocationOverlay.
    INFO: Creating CNAVVirtualEarthOverlay.
    INFO: Creating CNAVScrollMapOverlay.
    INFO: Creating CNAVMapOnlyModule.
    INFO: Creating CNAVStreetSettingsModule.
    INFO: Creating CNAVDirectionsModule.
    INFO: Creating CNAVRouteTypeModule.
    INFO: Creating CNAVFavoritesRenameModule.
    INFO: Creating CNAVSettingsModule.
    INFO: Creating CNAVSettingsModuleWizard.
    INFO: CSpeechController::OnSettingsChange
    WARNING: UV_GetFolderList - The system cannot find the path specified. (ERROR=0x00000003)
    INFO: Creating CNAVFindLatLongModule.
    INFO: Creating CNAVFindResultsModule.
    INFO: Creating CRipMediaPOIModule.
    INFO: Creating CNAVShowRouteModule.
    INFO: Creating CNAVFindPlacesListModule.
    INFO: Creating CNAVCurrentDirectionOverlay.
    INFO: Creating CRipMediaVideosModule.
    INFO: Creating CUpdateListModule.
    INFO: Creating CPackageListModule.
    INFO: Creating CAddPackageModule.
    INFO:
    Package Modules - Initialization time 0.375 / 16.968 seconds.
    INFO: Creating CScriptListModule.
    INFO: Creating CScriptRemoveModule.
    INFO: CScriptedModule::LoadSkin - Loading skin C:\Documents and Settings\Alok Car PC\My Documents\StreetDeck\Scripts\{03531B5D-1128-46B1-B412-1B6679485D5D}\ProcessSatellites.sds...
    INFO: CScriptedModule::LoadSkin - Loading PanelList...
    INFO: CScriptedModule::LoadSkin - Finished loading skin...
    INFO: Creating {03531B5D-1128-46B1-B412-1B6679485D5D}\ProcessSatellites.
    WARNING: UV_GetFileList - The specified path (C:\Documents and Settings\Alok Car PC\My Documents\StreetDeck\Scripts\{03531B5D-1128-46B1-B412-1B6679485D5D}\AddIns) does not exist!
    INFO: CScriptedModule::LoadSkin - Loading skin C:\Documents and Settings\Alok Car PC\My Documents\StreetDeck\Scripts\{1FB0936A-FD23-4A41-86E3-61C3F3977B0F}\main.sds...
    INFO: Creating {1FB0936A-FD23-4A41-86E3-61C3F3977B0F}\main.
    WARNING: UV_GetFileList - The specified path (C:\Documents and Settings\Alok Car PC\My Documents\StreetDeck\Scripts\{1FB0936A-FD23-4A41-86E3-61C3F3977B0F}\AddIns) does not exist!
    INFO:
    Scripting Modules - Initialization time 0.407 / 17.375 seconds.
    INFO:
    Load Modules - Initialization time 0.015 / 17.390 seconds.
    INFO: Media manager CDVDManager scene initialization...
    INFO: Creating CDVDManagerOverlay.
    INFO: Creating CDVDManagerExtendedOverlay.
    INFO: Creating CDVDTray.
    INFO:
    CDVDManager - Initialization time 0.000 / 17.390 seconds.
    INFO: Media manager CiPodManager scene initialization...
    INFO: Creating CiPodManagerOverlay.
    INFO: Creating CiPodManagerExtendedOverlay.
    INFO: Creating CiPodMusicTray.
    INFO:
    CiPodManager - Initialization time 0.000 / 17.390 seconds.
    INFO: Media manager CLaunchCastManager scene initialization...
    INFO: Creating CLaunchCastManagerOverlay.
    INFO: Creating CLaunchCastManagerExtendedOverlay.
    INFO: Creating CLaunchCastTray.
    INFO:
    CLaunchCastManager - Initialization time 0.000 / 17.390 seconds.
    INFO: Media manager CXMRadioManager scene initialization...
    INFO: Creating CXMRadioManagerOverlay.
    INFO: Creating CXMRadioManagerExtendedOverlay.
    INFO: Creating CSatRadioTray.
    INFO:
    CXMRadioManager - Initialization time 0.016 / 17.406 seconds.
    INFO: Media manager CRadioManager scene initialization...
    INFO: Creating CRadioManagerOverlay.
    INFO: Creating CRadioManagerExtendedOverlay.
    INFO: Creating CRadioTray.
    INFO:
    CRadioManager - Initialization time 0.000 / 17.406 seconds.
    INFO: Media manager CTVManager scene initialization...
    INFO: Creating CTVManagerOverlay.
    INFO: Creating CTVManagerExtendedOverlay.
    INFO: Creating CTVTray.
    INFO:
    CTVManager - Initialization time 0.000 / 17.406 seconds.
    INFO: Media manager CVideoFileManager scene initialization...
    INFO: Creating CVideoFileManagerOverlay.
    INFO: Creating CVideoFileManagerExtendedOverlay.
    INFO: Creating CVideoTray.
    INFO:
    CVideoFileManager - Initialization time 0.000 / 17.406 seconds.
    INFO: Media manager CAudioFileManager scene initialization...
    INFO: Creating CAudioFileManagerOverlay.
    INFO: Creating CAudioFileManagerExtendedOverlay.
    INFO: Creating CMusicTray.
    INFO:
    CAudioFileManager - Initialization time 0.016 / 17.422 seconds.
    INFO:
    Media Manager Ontime Scene Init - Initialization time 0.000 / 17.422 seconds.
    INFO: CAppData::LoadXMLSettings - Loading XML Settings from C:\Documents and Settings\Alok Car PC\My Documents\StreetDeck\config.xml...
    INFO:
    Create Class Enum - Initialization time 0.046 / 17.468 seconds.
    INFO:
    BindToStorage - Initialization time 0.000 / 17.468 seconds.
    INFO:
    GetDisplayName - Initialization time 0.000 / 17.468 seconds.
    INFO: CGirderModule::OnLoadXMLConfig - No plugins were loaded from the girder plugin path!
    WARNING: CRelayModule::OnLoadXMLConfig - No plugins were loaded from the Relay plugin path!
    INFO: Loading script options for GPS status...
    INFO: Loading script options for Weather...
    INFO:
    Load Settings - Initialization time 0.016 / 17.484 seconds.
    WARNING: CAppData::SortOverlays - Could not find overlay (CPanelChooserOverlay) to set Z-Order!
    WARNING: CAppData::SortOverlays - Could not find overlay ({A42819EF-8B34-48C2-80CF-3B8754FD7F1B}\OverlayTest) to set Z-Order!
    WARNING: CAppData::SortOverlays - Could not find overlay ({458E5981-B826-43C6-9D9C-C0C3D0C4EFBE}\ListenForFunctions) to set Z-Order!
    WARNING: CAppData::SortOverlays - Could not find overlay ({DE5511FB-CE24-4CB8-8709-C5288EF3A2B9}\VoiceShowRecognitionOverlay) to set Z-Order!
    INFO:
    Init Skin - Initialization time 0.000 / 17.484 seconds.
    INFO: Overlay CDVDManagerExtendedOverlay scene initialization...
    INFO: Overlay CNAVScrollMapOverlay scene initialization...
    INFO: Overlay CFullscreenTVOverlay scene initialization...
    INFO: Overlay CFullscreenDVDOverlay scene initialization...
    INFO: Overlay CFullscreenVideoStoppedInfoOverlay scene initialization...
    INFO: Overlay CFullscreenVideoOverlay scene initialization...
    INFO: Overlay CMuteOverlay scene initialization...
    INFO: Overlay CUserOverlay3 scene initialization...
    INFO: Overlay CUserExtendedOverlay2 scene initialization...
    INFO: Overlay CTVManagerOverlay scene initialization...
    INFO: Overlay FileOptionsOverlay scene initialization...
    INFO: Overlay CKeyPadNumbersOverlay scene initialization...
    INFO: Overlay CMultiMonEnabledOverlay scene initialization...
    INFO: Overlay CComboSelectOverlay scene initialization...
    INFO: Overlay CRearCameraPropOverlay scene initialization...
    INFO: Overlay CFunctionNameOverlay scene initialization...
    INFO: Overlay CUserExtendedOverlay5 scene initialization...
    INFO: Overlay CWebServicesOverlay scene initialization...
    INFO: Overlay CDVDTray scene initialization...
    INFO: Overlay CTVChannelChangeOverlay scene initialization...
    INFO: Overlay CListSearchOverlay scene initialization...
    INFO: Overlay CUserOverlay4 scene initialization...
    INFO: Overlay CiPodManagerExtendedOverlay scene initialization...
    INFO: Overlay CNAVViewDirectionOverlay scene initialization...
    INFO: Overlay CSafeModulesOverlay scene initialization...
    INFO: Overlay CUserExtendedOverlay4 scene initialization...
    INFO: Overlay CFullscreenVideoInfoOverlay scene initialization...
    INFO: Overlay CSlideshowOverlay scene initialization...
    INFO: Overlay CMediaChangeOverlay scene initialization...
    INFO: Overlay CVolumeOverlay scene initialization...
    INFO: Overlay CUserOverlay5 scene initialization...
    INFO: Overlay CSatRadioTray scene initialization...
    INFO: Overlay CXMRadioManagerOverlay scene initialization...
    INFO: Overlay CNAVFullscreenOverlay scene initialization...
    INFO: Overlay CBluetoothIncomingCallOverlay scene initialization...
    INFO: Overlay CUserExtendedOverlay7 scene initialization...
    INFO: Overlay CRadioManagerExtendedOverlay scene initialization...
    INFO: Overlay CUserOverlay6 scene initialization...
    INFO: Overlay CRadioManagerOverlay scene initialization...
    INFO: Overlay CDVDManagerOverlay scene initialization...
    INFO: Overlay CNAVClickedLocationOverlay scene initialization...
    INFO: Overlay CLaunchCastLoadedOverlay scene initialization...
    INFO: Overlay CUserExtendedOverlay6 scene initialization...
    INFO: Overlay CMediaTimeOverlay scene initialization...
    INFO: Overlay CVideoTray scene initialization...
    INFO: Overlay CTVTray scene initialization...
    INFO: Overlay CRadioTray scene initialization...
    INFO: Overlay CLaunchCastTray scene initialization...
    INFO: Overlay CNAVGPSTrackingOverlay scene initialization...
    INFO: Overlay CNAVViewFullscreenOverlay scene initialization...
    INFO: Overlay CVisTitleOverlay scene initialization...
    INFO: Overlay CGestureModule scene initialization...
    INFO: Overlay CBluetoothVoiceRecognitionOverlay scene initialization...
    INFO: Overlay CUserOverlay7 scene initialization...
    INFO: Overlay CMusicTray scene initialization...
    INFO: Overlay CiPodMusicTray scene initialization...
    INFO: Overlay CBluetoothConnectedOverlay scene initialization...
    INFO: Overlay CUserExtendedOverlay9 scene initialization...
    INFO: Overlay CNetworkCommOverlay scene initialization...
    INFO: Overlay CAlwaysVisibleOverlay scene initialization...
    INFO: Overlay CUserExtendedOverlay1 scene initialization...
    INFO: Overlay CUserOverlay0 scene initialization...
    INFO: Overlay CAudioFileManagerExtendedOverlay scene initialization...
    INFO: Overlay CVideoFileManagerOverlay scene initialization...
    INFO: Overlay CLaunchCastManagerExtendedOverlay scene initialization...
    INFO: Overlay CLaunchCastManagerOverlay scene initialization...
    INFO: Overlay CTVPropOverlay scene initialization...
    INFO: Overlay CHDRadioKeypadOverlay scene initialization...
    INFO: Overlay CUserExtendedOverlay8 scene initialization...
    INFO: Overlay CUserOverlay8 scene initialization...
    INFO: Overlay CVideoFileManagerExtendedOverlay scene initialization...
    INFO: Overlay CNAVCurrentDirectionOverlay scene initialization...
    INFO: Overlay CNAVViewListOverlay scene initialization...
    INFO: Overlay CVoiceInputModule scene initialization...
    INFO: Overlay CBluetoothActiveCallOverlay scene initialization...
    INFO: Overlay CUserOverlay1 scene initialization...
    INFO: Overlay CUserExtendedOverlay0 scene initialization...
    INFO: Overlay CMediaPlaySpeedOverlay scene initialization...
    INFO: Overlay CKeyPadLettersOverlay scene initialization...
    INFO: Overlay CNAVViewStatusOverlay scene initialization...
    INFO: Overlay CRearviewCameraOverlay scene initialization...
    INFO: Overlay CFullscreenVideoResumeInfoOverlay scene initialization...
    INFO: Overlay CRipMediaOverlay scene initialization...
    INFO: Overlay CUserOverlay9 scene initialization...
    INFO: Overlay CTVManagerExtendedOverlay scene initialization...
    INFO: Overlay CNAVVirtualEarthOverlay scene initialization...
    INFO: Overlay CGirderModule scene initialization...
    INFO: Overlay CMusicLoadedOverlay scene initialization...
    INFO: Overlay CUserExtendedOverlay3 scene initialization...
    INFO: Overlay CUserOverlay2 scene initialization...
    INFO: Overlay CKeyPadWebOverlay scene initialization...
    INFO: Overlay CAudioFileManagerOverlay scene initialization...
    INFO: Overlay CXMRadioManagerExtendedOverlay scene initialization...
    INFO: Overlay CiPodManagerOverlay scene initialization...
    INFO: Overlay CVisAlbumArtOverlay scene initialization...
    INFO: Overlay CRelayModule scene initialization...
    INFO: Overlay CKeyPadAlwaysVisibleOverlay scene initialization...
    INFO:
    Overlay Scene Init - Initialization time 0.016 / 17.500 seconds.
    INFO: Module CNAVFindResultsModule scene initialization...
    INFO: Module CNAVFavoritesRenameModule scene initialization...
    INFO: Module CNAVStreetSettingsModule scene initialization...
    INFO: Module CNAVMapOnlyModule scene initialization...
    INFO: Module CTVOptionsModule scene initialization...
    INFO: Module CStartModule scene initialization...
    INFO: Module CRipMediaTransferModule scene initialization...
    INFO: Module CNetSyncSettingsModule scene initialization...
    INFO: Module CUserModule8 scene initialization...
    INFO: Module CWSUserNameRenameModule scene initialization...
    INFO: Module CRemoteMediaDestinationModule scene initialization...
    INFO: Module CScriptRemoveModule scene initialization...
    INFO: Module CNAVFindPlacesListModule scene initialization...
    INFO: Module CFullScreenDVDModule scene initialization...
    INFO: Module CLCPasswordRenameModule scene initialization...
    INFO: Module CShutdownSettingsModule scene initialization...
    INFO: Module CVolumeModule scene initialization...
    INFO: Module CBluetoothSettingsModule scene initialization...
    INFO: Module CBluetoothPairedDevicesModule scene initialization...
    INFO: Module CNAVPOIModule scene initialization...
    INFO: Module CDiagnosticsViewCodeModule scene initialization...
    INFO: Module CHelpModule scene initialization...
    INFO: Module CYahooSearchModule scene initialization...
    INFO: Module CMediaDestinationRename scene initialization...
    INFO: Module CRipMediaSettingsModule scene initialization...
    INFO: Module CNetComputerBrowserModule scene initialization...
    INFO: Module CBluetoothSendTonesModule scene initialization...
    INFO: Module CBluetoothStartModule scene initialization...
    INFO: Module CNAVShowRouteModule scene initialization...
    INFO: Module CRipMediaPOIModule scene initialization...
    INFO: Module CNAVMapModule scene initialization...
    INFO: Module CFullScreenTVModule scene initialization...
    INFO: Module CFullScreenVideoFileModule scene initialization...
    INFO: Module CMusicVMODStartModule scene initialization...
    INFO: Module CMusicArtistStringColModule scene initialization...
    INFO: Module CMusicPlaylistModule scene initialization...
    INFO: Module CGeneralSettingsModule scene initialization...
    INFO: Module CRenameModule scene initialization...
    INFO: Module CBluetoothPhoneBookEntryModule scene initialization...
    INFO: Module CUserModule5 scene initialization...
    INFO: Module CNAVFindPlaceModule scene initialization...
    INFO: Module CNAVDBFindPlaceModule scene initialization...
    INFO: Module CRearviewCameraModule scene initialization...
    INFO: Module CRearviewCameraSettingsModule scene initialization...
    INFO: Module CDVDSelectSubPictureStreamModule scene initialization...
    INFO: Module CPictureSettingsModule scene initialization...
    INFO: Module CMusicSelectFolderModule scene initialization...
    INFO: Module CExternalAppsModule scene initialization...
    INFO: Module CRelayPluginSettingsModule scene initialization...
    INFO: Module CBluetoothImportBluetoothModule scene initialization...
    INFO: Module CUserModule4 scene initialization...
    INFO: Module {1FB0936A-FD23-4A41-86E3-61C3F3977B0F}\main scene initialization...
    INFO: Module CNAVSettingsModule scene initialization...
    INFO: Module COBDIISettingsModule scene initialization...
    INFO: Module CMusicPlaylistContentsModule scene initialization...
    INFO: Module CMainSettingsModule scene initialization...
    INFO: Module CSyncSourceModule scene initialization...
    INFO: Module CMultiMonSettingsModule scene initialization...
    INFO: Module CCalibrateDisplayModule scene initialization...
    INFO: Module CStartupSettingsModuleWizard scene initialization...
    INFO: Module CSystemRestoreModule scene initialization...
    INFO: Module CBalanceFaderModule scene initialization...
    INFO: Module CBluetoothPhoneBookModule scene initialization...
    INFO: Module CBluetoothPairedDeviceStatusModule scene initialization...
    INFO: Module CUserModule7 scene initialization...
    INFO: Module CDiagnosticsModule scene initialization...
    INFO: Module CXMRadioChooseStationsModule scene initialization...
    INFO: Module CShutdownModule scene initialization...
    INFO: Module CDisplaySettingsModule scene initialization...
    INFO: Module CConfigureRelayPluginSettingsModule scene initialization...
    INFO: Module CUserModule6 scene initialization...
    INFO: Module CNAVRouteTypeModule scene initialization...
    INFO: Module CHDRadioModule scene initialization...
    INFO: Module CiPodModule scene initialization...
    INFO: Module CRipMediaMusicModule scene initialization...
    INFO: Module CMusicSettingsModule scene initialization...
    INFO: Module CShortcutsModule scene initialization...
    INFO: Module CChooseRelaysSettingsModule scene initialization...
    INFO: Module CBluetoothImportModule scene initialization...
    INFO: Module CUserModule1 scene initialization...
    INFO: Module CNAVFindAddress scene initialization...
    INFO: Module CVehicleModule scene initialization...
    INFO: Module CDVDInfoModule scene initialization...
    INFO: Module CVideoSettingsModule scene initialization...
    INFO: Module CXMRadioSettingsModule scene initialization...
    INFO: Module CVisualizationModule scene initialization...
    INFO: Module CColorSettingsModule scene initialization...
    INFO: Module CWMEqualizerModule scene initialization...
    INFO: Module CBluetoothImportCSVModule scene initialization...
    INFO: Module CUserModule0 scene initialization...
    INFO: Module CPackageListModule scene initialization...
    INFO: Module CVehicleSettingsModule scene initialization...
    INFO: Module CDVDSelectAudioStreamModule scene initialization...
    INFO: Module CXMRadioSettingsModuleWizard scene initialization...
    INFO: Module CRadioSettingsModule scene initialization...
    INFO: Module CSystemInformationModule scene initialization...
    INFO: Module CKeyboardSettingsModule scene initialization...
    INFO: Module CNetShareBrowserModule scene initialization...
    INFO: Module CBluetoothVolumeModule scene initialization...
    INFO: Module CBluetoothSettingsModuleWizard scene initialization...
    INFO: Module CUserModule3 scene initialization...
    INFO: Module {03531B5D-1128-46B1-B412-1B6679485D5D}\ProcessSatellites scene initialization...
    INFO: Module CRipMediaVideosModule scene initialization...
    INFO: Module CNAVFullScreenModule scene initialization...
    INFO: Module CPicturesModule scene initialization...
    INFO: Module CGirderPluginSettingsModule scene initialization...
    INFO: Module CLCUserNameRenameModule scene initialization...
    INFO: Module CAboutModule scene initialization...
    INFO: Module CProcessShutdownModule scene initialization...
    INFO: Module CSkinSettingsModule scene initialization...
    INFO: Module CUserNameRenameModule scene initialization...
    INFO: Module CFileSearchRenameModule scene initialization...
    INFO: Module CBluetoothCallLogModule scene initialization...
    INFO: Module CBluetoothMainModule scene initialization...
    INFO: Module CUserModule2 scene initialization...
    INFO: Module CAddPackageModule scene initialization...
    INFO: Module CNAVCustomPOIModule scene initialization...
    INFO: Module CLaunchCastFilterStationsModule scene initialization...
    INFO: Module CMusicAlbumStringColModule scene initialization...
    INFO: Module CVoiceInputSettingsModule scene initialization...
    INFO: Module CBluetoothEditPhoneBookEntryModule scene initialization...
    INFO: Module CConfigureRearviewCameraSettingsModule scene initialization...
    INFO: Module CGirderSettingsModule scene initialization...
    INFO: Module CLaunchCastModule scene initialization...
    INFO: Module CMusicNowPlayingModule scene initialization...
    INFO: Module CMusicSearchModule scene initialization...
    INFO: Module CMusicSearchResultsModule scene initialization...
    INFO: Module CSetTimeSettingsModule scene initialization...
    INFO: Module CStartupSettingsModule scene initialization...
    INFO: Module CFileSearchResultsModule scene initialization...
    INFO: Module CGestureSettingsModule scene initialization...
    INFO: Module CEnhancedAudioModule scene initialization...
    INFO: Module CBluetoothPhoneStatusModule scene initialization...
    INFO: Module CBluetoothPairingModule scene initialization...
    INFO: Module CWebServicesSettingsModule scene initialization...
    INFO: Module CScriptListModule scene initialization...
    INFO: Module CUpdateListModule scene initialization...
    INFO: Module CNAVSettingsModuleWizard scene initialization...
    INFO: Module CNAVFindNearbyModule scene initialization...
    INFO: Module CNAVStatusModule scene initialization...
    INFO: Module CDVDOptionsModule scene initialization...
    INFO: Module CLaunchCastSettingsModule scene initialization...
    INFO: Module CInputOptionsSettingsModule scene initialization...
    INFO: Module CMoveFileModule scene initialization...
    INFO: Module CVehicleGraphOBDIIModule scene initialization...
    INFO: Module CDVDSettingsModule scene initialization...
    INFO: Module CMusicSongStringColModule scene initialization...
    INFO: Module CMusicModule scene initialization...
    INFO: Module CInputSettingsModule scene initialization...
    INFO: Module CPasswordRenameModule scene initialization...
    INFO: Module CConfigureRelaySetSettingsModule scene initialization...
    INFO: Module CBluetoothActiveCallModule scene initialization...
    INFO: Module CWSPasswordRenameModule scene initialization...
    INFO: Module CNAVStartModule scene initialization...
    INFO: Module CNAVFindLatLongModule scene initialization...
    INFO: Module CNAVDirectionsModule scene initialization...
    INFO: Module CXMRadioModule scene initialization...
    INFO: Module CDisplaySettingsModuleWizard scene initialization...
    INFO: Module CRipMediaSelectTypeModule scene initialization...
    INFO: Module CRelaySettingsModule scene initialization...
    INFO: Module CRelaySetSettingsModule scene initialization...
    INFO: Module CGlyphSettingsModule scene initialization...
    INFO: Module CAppSoundsModule scene initialization...
    INFO: Module CBluetoothDialNumberModule scene initialization...
    INFO: Module CRelayControlModule scene initialization...
    INFO: Module CVideosModule scene initialization...
    INFO: Module CSlideshowModule scene initialization...
    INFO: Module CRipMediaPicturesModule scene initialization...
    INFO: Module CXMRadioStationListModule scene initialization...
    INFO: Module CXMRadioStatusModule scene initialization...
    INFO: Module CLaunchCastStationGuideModule scene initialization...
    INFO: Module CMusicStartModule scene initialization...
    INFO: Module CMusicGenreStringColModule scene initialization...
    INFO: Module CMusicArtistAlbumModule scene initialization...
    INFO: Module CSimpleSettingsModule scene initialization...
    INFO: Module CSetTimeSettingsModuleWizard scene initialization...
    INFO: Module CRelayRenameModule scene initialization...
    INFO: Module CBluetoothOptionsModule scene initialization...
    INFO: Module CUserModule9 scene initialization...
    INFO:
    Module Scene Init - Initialization time 0.031 / 17.531 seconds.
    INFO: CDrawWnd::RestoreDeviceObjects...
    INFO: CDrawWnd::RestoreDeviceObjects - SetTransform
    INFO: CDrawWnd::RestoreDeviceObjects - GetRenderTarget
    INFO: CFontBag::RestoreDeviceObjects...
    INFO: CD3DBitmapFont::AllocBatchData - Creating Vertex Shaders
    INFO: CD3DBitmapFont::AllocBatchData - Creating Vertex Buffer
    INFO: CD3DBitmapFont::AllocBatchData - Creating Index Buffer
    INFO: CD3DBitmapFont::AllocBatchData - Checking for alpha blend support
    INFO: CD3DBitmapFont::AllocBatchData - Setting Render States
    INFO: CD3DBitmapFont::AllocBatchData - Successfully set render states
    INFO: Restoring overlay CDVDManagerExtendedOverlay device objects...
    INFO: Restoring overlay CNAVScrollMapOverlay device objects...
    INFO: Restoring overlay CFullscreenTVOverlay device objects...
    INFO: Restoring overlay CFullscreenDVDOverlay device objects...
    INFO: Restoring overlay CFullscreenVideoStoppedInfoOverlay device objects...
    INFO: Restoring overlay CFullscreenVideoOverlay device objects...
    INFO: Restoring overlay CMuteOverlay device objects...
    INFO: Restoring overlay CUserOverlay3 device objects...
    INFO: Restoring overlay CUserExtendedOverlay2 device objects...
    INFO: Restoring overlay CTVManagerOverlay device objects...
    INFO: Restoring overlay FileOptionsOverlay device objects...
    INFO: Restoring overlay CKeyPadNumbersOverlay device objects...
    INFO: Restoring overlay CMultiMonEnabledOverlay device objects...
    INFO: Restoring overlay CComboSelectOverlay device objects...
    INFO: Restoring overlay CRearCameraPropOverlay device objects...
    INFO: Restoring overlay CFunctionNameOverlay device objects...
    INFO: Restoring overlay CUserExtendedOverlay5 device objects...
    INFO: Restoring overlay CWebServicesOverlay device objects...
    INFO: Restoring overlay CDVDTray device objects...
    INFO: Restoring overlay CTVChannelChangeOverlay device objects...
    INFO: Restoring overlay CListSearchOverlay device objects...
    INFO: Restoring overlay CUserOverlay4 device objects...
    INFO: Restoring overlay CiPodManagerExtendedOverlay device objects...
    INFO: Restoring overlay CNAVViewDirectionOverlay device objects...
    INFO: Restoring overlay CSafeModulesOverlay device objects...
    INFO: Restoring overlay CUserExtendedOverlay4 device objects...
    INFO: Restoring overlay CFullscreenVideoInfoOverlay device objects...
    INFO: Restoring overlay CSlideshowOverlay device objects...
    INFO: Restoring overlay CMediaChangeOverlay device objects...
    INFO: Restoring overlay CVolumeOverlay device objects...
    INFO: Restoring overlay CUserOverlay5 device objects...
    INFO: Restoring overlay CSatRadioTray device objects...
    INFO: Restoring overlay CXMRadioManagerOverlay device objects...
    INFO: Restoring overlay CNAVFullscreenOverlay device objects...
    INFO: Restoring overlay CBluetoothIncomingCallOverlay device objects...
    INFO: Restoring overlay CUserExtendedOverlay7 device objects...
    INFO: Restoring overlay CRadioManagerExtendedOverlay device objects...
    INFO: Restoring overlay CUserOverlay6 device objects...
    INFO: Restoring overlay CRadioManagerOverlay device objects...
    INFO: Restoring overlay CDVDManagerOverlay device objects...
    INFO: Restoring overlay CNAVClickedLocationOverlay device objects...
    INFO: Restoring overlay CLaunchCastLoadedOverlay device objects...
    INFO: Restoring overlay CUserExtendedOverlay6 device objects...
    INFO: Restoring overlay CMediaTimeOverlay device objects...
    INFO: Restoring overlay CVideoTray device objects...
    INFO: Restoring overlay CTVTray device objects...
    INFO: Restoring overlay CRadioTray device objects...
    INFO: Restoring overlay CLaunchCastTray device objects...
    INFO: Restoring overlay CNAVGPSTrackingOverlay device objects...
    INFO: Restoring overlay CNAVViewFullscreenOverlay device objects...
    INFO: Restoring overlay CVisTitleOverlay device objects...
    INFO: Restoring overlay CGestureModule device objects...
    INFO: Restoring overlay CBluetoothVoiceRecognitionOverlay device objects...
    INFO: Restoring overlay CUserOverlay7 device objects...
    INFO: Restoring overlay CMusicTray device objects...
    INFO: Restoring overlay CiPodMusicTray device objects...
    INFO: Restoring overlay CBluetoothConnectedOverlay device objects...
    INFO: Restoring overlay CUserExtendedOverlay9 device objects...
    INFO: Restoring overlay CNetworkCommOverlay device objects...
    INFO: Restoring overlay CAlwaysVisibleOverlay device objects...
    INFO: Restoring overlay CUserExtendedOverlay1 device objects...
    INFO: Restoring overlay CUserOverlay0 device objects...
    INFO: Restoring overlay CAudioFileManagerExtendedOverlay device objects...
    INFO: Restoring overlay CVideoFileManagerOverlay device objects...
    INFO: Restoring overlay CLaunchCastManagerExtendedOverlay device objects...
    INFO: Restoring overlay CLaunchCastManagerOverlay device objects...
    INFO: Restoring overlay CTVPropOverlay device objects...
    INFO: Restoring overlay CHDRadioKeypadOverlay device objects...
    INFO: Restoring overlay CUserExtendedOverlay8 device objects...
    INFO: Restoring overlay CUserOverlay8 device objects...
    INFO: Restoring overlay CVideoFileManagerExtendedOverlay device objects...
    INFO: Restoring overlay CNAVCurrentDirectionOverlay device objects...
    INFO: Restoring overlay CNAVViewListOverlay device objects...
    INFO: Restoring overlay CVoiceInputModule device objects...
    INFO: Restoring overlay CBluetoothActiveCallOverlay device objects...
    INFO: Restoring overlay CUserOverlay1 device objects...
    INFO: Restoring overlay CUserExtendedOverlay0 device objects...
    INFO: Restoring overlay CMediaPlaySpeedOverlay device objects...
    INFO: Restoring overlay CKeyPadLettersOverlay device objects...
    INFO: Restoring overlay CNAVViewStatusOverlay device objects...
    INFO: Restoring overlay CRearviewCameraOverlay device objects...
    INFO: Restoring overlay CFullscreenVideoResumeInfoOverlay device objects...
    INFO: Restoring overlay CRipMediaOverlay device objects...
    INFO: Restoring overlay CUserOverlay9 device objects...
    INFO: Restoring overlay CTVManagerExtendedOverlay device objects...
    INFO: Restoring overlay CNAVVirtualEarthOverlay device objects...
    INFO: Restoring overlay CGirderModule device objects...
    INFO: Restoring overlay CMusicLoadedOverlay device objects...
    INFO: Restoring overlay CUserExtendedOverlay3 device objects...
    INFO: Restoring overlay CUserOverlay2 device objects...
    INFO: Restoring overlay CKeyPadWebOverlay device objects...
    INFO: Restoring overlay CAudioFileManagerOverlay device objects...
    INFO: Restoring overlay CXMRadioManagerExtendedOverlay device objects...
    INFO: Restoring overlay CiPodManagerOverlay device objects...
    INFO: Restoring overlay CVisAlbumArtOverlay device objects...
    INFO: Restoring overlay CRelayModule device objects...
    INFO: Restoring overlay CKeyPadAlwaysVisibleOverlay device objects...
    INFO: Restoring module CNAVFindResultsModule device objects...
    INFO: Restoring module CNAVFavoritesRenameModule device objects...
    INFO: Restoring module CNAVStreetSettingsModule device objects...
    INFO: Restoring module CNAVMapOnlyModule device objects...
    INFO: Restoring module CTVOptionsModule device objects...
    INFO: Restoring module CStartModule device objects...
    INFO: Restoring module CRipMediaTransferModule device objects...
    INFO: Restoring module CNetSyncSettingsModule device objects...
    INFO: Restoring module CUserModule8 device objects...
    INFO: Restoring module CWSUserNameRenameModule device objects...
    INFO: Restoring module CRemoteMediaDestinationModule device objects...
    INFO: Restoring module CScriptRemoveModule device objects...
    INFO: Restoring module CNAVFindPlacesListModule device objects...
    INFO: Restoring module CFullScreenDVDModule device objects...
    INFO: Restoring module CLCPasswordRenameModule device objects...
    INFO: Restoring module CShutdownSettingsModule device objects...
    INFO: Restoring module CVolumeModule device objects...
    INFO: Restoring module CBluetoothSettingsModule device objects...
    INFO: Restoring module CBluetoothPairedDevicesModule device objects...
    INFO: Restoring module CNAVPOIModule device objects...
    INFO: Restoring module CDiagnosticsViewCodeModule device objects...
    INFO: Restoring module CHelpModule device objects...
    INFO: Restoring module CYahooSearchModule device objects...
    INFO: Restoring module CMediaDestinationRename device objects...
    INFO: Restoring module CRipMediaSettingsModule device objects...
    INFO: Restoring module CNetComputerBrowserModule device objects...
    INFO: Restoring module CBluetoothSendTonesModule device objects...
    INFO: Restoring module CBluetoothStartModule device objects...
    INFO: Restoring module CNAVShowRouteModule device objects...
    INFO: Restoring module CRipMediaPOIModule device objects...
    INFO: Restoring module CNAVMapModule device objects...
    INFO: Restoring module CFullScreenTVModule device objects...
    INFO: Restoring module CFullScreenVideoFileModule device objects...
    INFO: Restoring module CMusicVMODStartModule device objects...
    INFO: Restoring module CMusicArtistStringColModule device objects...
    INFO: Restoring module CMusicPlaylistModule device objects...
    INFO: Restoring module CGeneralSettingsModule device objects...
    INFO: Restoring module CRenameModule device objects...
    INFO: Restoring module CBluetoothPhoneBookEntryModule device objects...
    INFO: Restoring module CUserModule5 device objects...
    INFO: Restoring module CNAVFindPlaceModule device objects...
    INFO: Restoring module CNAVDBFindPlaceModule device objects...
    INFO: Restoring module CRearviewCameraModule device objects...
    INFO: Restoring module CRearviewCameraSettingsModule device objects...
    INFO: Restoring module CDVDSelectSubPictureStreamModule device objects...
    INFO: Restoring module CPictureSettingsModule device objects...
    INFO: Restoring module CMusicSelectFolderModule device objects...
    INFO: Restoring module CExternalAppsModule device objects...
    INFO: Restoring module CRelayPluginSettingsModule device objects...
    INFO: Restoring module CBluetoothImportBluetoothModule device objects...
    INFO: Restoring module CUserModule4 device objects...
    INFO: Restoring module {1FB0936A-FD23-4A41-86E3-61C3F3977B0F}\main device objects...
    INFO: Restoring module CNAVSettingsModule device objects...
    INFO: Restoring module COBDIISettingsModule device objects...
    INFO: Restoring module CMusicPlaylistContentsModule device objects...
    INFO: Restoring module CMainSettingsModule device objects...
    INFO: Restoring module CSyncSourceModule device objects...
    INFO: Restoring module CMultiMonSettingsModule device objects...
    INFO: Restoring module CCalibrateDisplayModule device objects...
    INFO: Restoring module CStartupSettingsModuleWizard device objects...
    INFO: Restoring module CSystemRestoreModule device objects...
    INFO: Restoring module CBalanceFaderModule device objects...
    INFO: Restoring module CBluetoothPhoneBookModule device objects...
    INFO: Restoring module CBluetoothPairedDeviceStatusModule device objects...
    INFO: Restoring module CUserModule7 device objects...
    INFO: Restoring module CDiagnosticsModule device objects...
    INFO: Restoring module CXMRadioChooseStationsModule device objects...
    INFO: Restoring module CShutdownModule device objects...
    INFO: Restoring module CDisplaySettingsModule device objects...
    INFO: Restoring module CConfigureRelayPluginSettingsModule device objects...
    INFO: Restoring module CUserModule6 device objects...
    INFO: Restoring module CNAVRouteTypeModule device objects...
    INFO: Restoring module CHDRadioModule device objects...
    INFO: Restoring module CiPodModule device objects...
    INFO: Restoring module CRipMediaMusicModule device objects...
    INFO: Restoring module CMusicSettingsModule device objects...
    INFO: Restoring module CShortcutsModule device objects...
    INFO: Restoring module CChooseRelaysSettingsModule device objects...
    INFO: Restoring module CBluetoothImportModule device objects...
    INFO: Restoring module CUserModule1 device objects...
    INFO: Restoring module CNAVFindAddress device objects...
    INFO: Restoring module CVehicleModule device objects...
    INFO: Restoring module CDVDInfoModule device objects...
    INFO: Restoring module CVideoSettingsModule device objects...
    INFO: Restoring module CXMRadioSettingsModule device objects...
    INFO: Restoring module CVisualizationModule device objects...
    INFO: Restoring module CColorSettingsModule device objects...
    INFO: Restoring module CWMEqualizerModule device objects...
    INFO: Restoring module CBluetoothImportCSVModule device objects...
    INFO: Restoring module CUserModule0 device objects...
    INFO: Restoring module CPackageListModule device objects...
    INFO: Restoring module CVehicleSettingsModule device objects...
    INFO: Restoring module CDVDSelectAudioStreamModule device objects...
    INFO: Restoring module CXMRadioSettingsModuleWizard device objects...
    INFO: Restoring module CRadioSettingsModule device objects...
    INFO: Restoring module CSystemInformationModule device objects...
    INFO: Restoring module CKeyboardSettingsModule device objects...
    INFO: Restoring module CNetShareBrowserModule device objects...
    INFO: Restoring module CBluetoothVolumeModule device objects...
    INFO: Restoring module CBluetoothSettingsModuleWizard device objects...
    INFO: Restoring module CUserModule3 device objects...
    INFO: Restoring module {03531B5D-1128-46B1-B412-1B6679485D5D}\ProcessSatellites device objects...
    INFO: Restoring module CRipMediaVideosModule device objects...
    INFO: Restoring module CNAVFullScreenModule device objects...
    INFO: Restoring module CPicturesModule device objects...
    INFO: Restoring module CGirderPluginSettingsModule device objects...
    INFO: Restoring module CLCUserNameRenameModule device objects...
    INFO: Restoring module CAboutModule device objects...
    INFO: Restoring module CProcessShutdownModule device objects...
    INFO: Restoring module CSkinSettingsModule device objects...
    INFO: Restoring module CUserNameRenameModule device objects...
    INFO: Restoring module CFileSearchRenameModule device objects...
    INFO: Restoring module CBluetoothCallLogModule device objects...
    INFO: Restoring module CBluetoothMainModule device objects...
    INFO: Restoring module CUserModule2 device objects...
    INFO: Restoring module CAddPackageModule device objects...
    INFO: Restoring module CNAVCustomPOIModule device objects...
    INFO: Restoring module CLaunchCastFilterStationsModule device objects...
    INFO: Restoring module CMusicAlbumStringColModule device objects...
    INFO: Restoring module CVoiceInputSettingsModule device objects...
    INFO: Restoring module CBluetoothEditPhoneBookEntryModule device objects...
    INFO: Restoring module CConfigureRearviewCameraSettingsModule device objects...
    INFO: Restoring module CGirderSettingsModule device objects...
    INFO: Restoring module CLaunchCastModule device objects...
    INFO: Restoring module CMusicNowPlayingModule device objects...
    INFO: Restoring module CMusicSearchModule device objects...
    INFO: Restoring module CMusicSearchResultsModule device objects...
    INFO: Restoring module CSetTimeSettingsModule device objects...
    INFO: Restoring module CStartupSettingsModule device objects...
    INFO: Restoring module CFileSearchResultsModule device objects...
    INFO: Restoring module CGestureSettingsModule device objects...
    INFO: Restoring module CEnhancedAudioModule device objects...
    INFO: Restoring module CBluetoothPhoneStatusModule device objects...
    INFO: Restoring module CBluetoothPairingModule device objects...
    INFO: Restoring module CWebServicesSettingsModule device objects...
    INFO: Restoring module CScriptListModule device objects...
    INFO: Restoring module CUpdateListModule device objects...
    INFO: Restoring module CNAVSettingsModuleWizard device objects...
    INFO: Restoring module CNAVFindNearbyModule device objects...
    INFO: Restoring module CNAVStatusModule device objects...
    INFO: Restoring module CDVDOptionsModule device objects...
    INFO: Restoring module CLaunchCastSettingsModule device objects...
    INFO: Restoring module CInputOptionsSettingsModule device objects...
    INFO: Restoring module CMoveFileModule device objects...
    INFO: Restoring module CVehicleGraphOBDIIModule device objects...
    INFO: Restoring module CDVDSettingsModule device objects...
    INFO: Restoring module CMusicSongStringColModule device objects...
    INFO: Restoring module CMusicModule device objects...
    INFO: Restoring module CInputSettingsModule device objects...
    INFO: Restoring module CPasswordRenameModule device objects...
    INFO: Restoring module CConfigureRelaySetSettingsModule device objects...
    INFO: Restoring module CBluetoothActiveCallModule device objects...
    INFO: Restoring module CWSPasswordRenameModule device objects...
    INFO: Restoring module CNAVStartModule device objects...
    INFO: Restoring module CNAVFindLatLongModule device objects...
    INFO: Restoring module CNAVDirectionsModule device objects...
    INFO: Restoring module CXMRadioModule device objects...
    INFO: Restoring module CDisplaySettingsModuleWizard device objects...
    INFO: Restoring module CRipMediaSelectTypeModule device objects...
    INFO: Restoring module CRelaySettingsModule device objects...
    INFO: Restoring module CRelaySetSettingsModule device objects...
    INFO: Restoring module CGlyphSettingsModule device objects...
    INFO: Restoring module CAppSoundsModule device objects...
    INFO: Restoring module CBluetoothDialNumberModule device objects...
    INFO: Restoring module CRelayControlModule device objects...
    INFO: Restoring module CVideosModule device objects...
    INFO: Restoring module CSlideshowModule device objects...
    INFO: Restoring module CRipMediaPicturesModule device objects...
    INFO: Restoring module CXMRadioStationListModule device objects...
    INFO: Restoring module CXMRadioStatusModule device objects...
    INFO: Restoring module CLaunchCastStationGuideModule device objects...
    INFO: Restoring module CMusicStartModule device objects...
    INFO: Restoring module CMusicGenreStringColModule device objects...
    INFO: Restoring module CMusicArtistAlbumModule device objects...
    INFO: Restoring module CSimpleSettingsModule device objects...
    INFO: Restoring module CSetTimeSettingsModuleWizard device objects...
    INFO: Restoring module CRelayRenameModule device objects...
    INFO: Restoring module CBluetoothOptionsModule device objects...
    INFO: Restoring module CUserModule9 device objects...
    INFO: Restoring media manager CDVDManager device objects...
    INFO: Restoring media manager CiPodManager device objects...
    INFO: Restoring media manager CLaunchCastManager device objects...
    INFO: Restoring media manager CXMRadioManager device objects...
    INFO: Restoring media manager CRadioManager device objects...
    INFO: Restoring media manager CTVManager device objects...
    INFO: Restoring media manager CVideoFileManager device objects...
    INFO: Restoring media manager CAudioFileManager device objects...
    INFO: CAppData::Exec - Executing Module CStartModule
    INFO: CDrawWnd::OnSettingsChange...
    INFO: CSoundController::OnSettingsChange
    INFO: CAppData::OnSettingsChange - Setting thread execution state...
    INFO: Applying settings change to module CNAVFindResultsModule...
    INFO: Applying settings change to module CNAVFavoritesRenameModule...
    INFO: Applying settings change to module CNAVStreetSettingsModule...
    INFO: Applying settings change to module CNAVMapOnlyModule...
    INFO: Applying settings change to module CTVOptionsModule...
    INFO: Applying settings change to module CStartModule...
    INFO: Applying settings change to module CRipMediaTransferModule...
    INFO: Applying settings change to module CNetSyncSettingsModule...
    INFO: Applying settings change to module CUserModule8...
    INFO: Applying settings change to module CWSUserNameRenameModule...
    INFO: Applying settings change to module CRemoteMediaDestinationModule...
    INFO: Applying settings change to module CScriptRemoveModule...
    INFO: Applying settings change to module CNAVFindPlacesListModule...
    INFO: Applying settings change to module CFullScreenDVDModule...
    INFO: Applying settings change to module CLCPasswordRenameModule...
    INFO: Applying settings change to module CShutdownSettingsModule...
    INFO: Applying settings change to module CVolumeModule...
    INFO: Applying settings change to module CBluetoothSettingsModule...
    INFO: Applying settings change to module CBluetoothPairedDevicesModule...
    INFO: Applying settings change to module CNAVPOIModule...
    INFO: Applying settings change to module CDiagnosticsViewCodeModule...
    INFO: Applying settings change to module CHelpModule...
    INFO: Applying settings change to module CYahooSearchModule...
    INFO: Applying settings change to module CMediaDestinationRename...
    INFO: Applying settings change to module CRipMediaSettingsModule...
    INFO: Applying settings change to module CNetComputerBrowserModule...
    INFO: Applying settings change to module CBluetoothSendTonesModule...
    INFO: Applying settings change to module CBluetoothStartModule...
    INFO: Applying settings change to module CNAVShowRouteModule...
    INFO: Applying settings change to module CRipMediaPOIModule...
    INFO: Applying settings change to module CNAVMapModule...
    INFO: Applying settings change to module CFullScreenTVModule...
    INFO: Applying settings change to module CFullScreenVideoFileModule...
    INFO: Applying settings change to module CMusicVMODStartModule...
    INFO: Applying settings change to module CMusicArtistStringColModule...
    INFO: Applying settings change to module CMusicPlaylistModule...
    INFO: Applying settings change to module CGeneralSettingsModule...
    INFO: Applying settings change to module CRenameModule...
    INFO: Applying settings change to module CBluetoothPhoneBookEntryModule...
    INFO: Applying settings change to module CUserModule5...
    INFO: Applying settings change to module CNAVFindPlaceModule...
    INFO: Applying settings change to module CNAVDBFindPlaceModule...
    INFO: Applying settings change to module CRearviewCameraModule...
    INFO: Applying settings change to module CRearviewCameraSettingsModule...
    INFO: Applying settings change to module CDVDSelectSubPictureStreamModule...
    INFO: Applying settings change to module CPictureSettingsModule...
    INFO: Applying settings change to module CMusicSelectFolderModule...
    INFO: Applying settings change to module CExternalAppsModule...
    INFO: Applying settings change to module CRelayPluginSettingsModule...
    INFO: Applying settings change to module CBluetoothImportBluetoothModule...
    INFO: Applying settings change to module CUserModule4...
    INFO: Applying settings change to module {1FB0936A-FD23-4A41-86E3-61C3F3977B0F}\main...
    INFO: Applying settings change to module CNAVSettingsModule...
    INFO: Applying settings change to module COBDIISettingsModule...
    INFO: Applying settings change to module CMusicPlaylistContentsModule...
    INFO: Applying settings change to module CMainSettingsModule...
    INFO: Applying settings change to module CSyncSourceModule...
    INFO: Applying settings change to module CMultiMonSettingsModule...
    INFO: Applying settings change to module CCalibrateDisplayModule...
    INFO: Applying settings change to module CStartupSettingsModuleWizard...
    INFO: Applying settings change to module CSystemRestoreModule...
    INFO: Applying settings change to module CBalanceFaderModule...
    INFO: Applying settings change to module CBluetoothPhoneBookModule...
    INFO: Applying settings change to module CBluetoothPairedDeviceStatusModule...
    INFO: Applying settings change to module CUserModule7...
    INFO: Applying settings change to module CDiagnosticsModule...
    INFO: Applying settings change to module CXMRadioChooseStationsModule...
    INFO: Applying settings change to module CShutdownModule...
    INFO: Applying settings change to module CDisplaySettingsModule...
    INFO: Applying settings change to module CConfigureRelayPluginSettingsModule...
    INFO: Applying settings change to module CUserModule6...
    INFO: Applying settings change to module CNAVRouteTypeModule...
    INFO: Applying settings change to module CHDRadioModule...
    INFO: Applying settings change to module CiPodModule...
    INFO: Applying settings change to module CRipMediaMusicModule...
    INFO: Applying settings change to module CMusicSettingsModule...
    INFO: Applying settings change to module CShortcutsModule...
    INFO: Applying settings change to module CChooseRelaysSettingsModule...
    INFO: Applying settings change to module CBluetoothImportModule...
    INFO: Applying settings change to module CUserModule1...
    INFO: Applying settings change to module CNAVFindAddress...
    INFO: Applying settings change to module CVehicleModule...
    INFO: Applying settings change to module CDVDInfoModule...
    INFO: Applying settings change to module CVideoSettingsModule...
    INFO: Applying settings change to module CXMRadioSettingsModule...
    INFO: Applying settings change to module CVisualizationModule...
    INFO: Applying settings change to module CColorSettingsModule...
    INFO: Applying settings change to module CWMEqualizerModule...
    INFO: Applying settings change to module CBluetoothImportCSVModule...
    INFO: Applying settings change to module CUserModule0...
    INFO: Applying settings change to module CPackageListModule...
    INFO: Applying settings change to module CVehicleSettingsModule...
    INFO: Applying settings change to module CDVDSelectAudioStreamModule...
    INFO: Applying settings change to module CXMRadioSettingsModuleWizard...
    INFO: Applying settings change to module CRadioSettingsModule...
    INFO: Applying settings change to module CSystemInformationModule...
    INFO: Applying settings change to module CKeyboardSettingsModule...
    INFO: Applying settings change to module CNetShareBrowserModule...
    INFO: Applying settings change to module CBluetoothVolumeModule...
    INFO: Applying settings change to module CBluetoothSettingsModuleWizard...
    INFO: Applying settings change to module CUserModule3...
    INFO: Applying settings change to module {03531B5D-1128-46B1-B412-1B6679485D5D}\ProcessSatellites...
    INFO: Applying settings change to module CRipMediaVideosModule...
    INFO: Applying settings change to module CNAVFullScreenModule...
    INFO: Applying settings change to module CPicturesModule...
    INFO: Applying settings change to module CGirderPluginSettingsModule...
    INFO: Applying settings change to module CLCUserNameRenameModule...
    INFO: Applying settings change to module CAboutModule...
    INFO: Applying settings change to module CProcessShutdownModule...
    INFO: Applying settings change to module CSkinSettingsModule...
    INFO: Applying settings change to module CUserNameRenameModule...
    INFO: Applying settings change to module CFileSearchRenameModule...
    INFO: Applying settings change to module CBluetoothCallLogModule...
    INFO: Applying settings change to module CBluetoothMainModule...
    INFO: Applying settings change to module CUserModule2...
    INFO: Applying settings change to module CAddPackageModule...
    INFO: Applying settings change to module CNAVCustomPOIModule...
    INFO: Applying settings change to module CLaunchCastFilterStationsModule...
    INFO: Applying settings change to module CMusicAlbumStringColModule...
    INFO: Applying settings change to module CVoiceInputSettingsModule...
    INFO: Applying settings change to module CBluetoothEditPhoneBookEntryModule...
    INFO: Applying settings change to module CConfigureRearviewCameraSettingsModule...
    INFO: Applying settings change to module CGirderSettingsModule...
    INFO: Applying settings change to module CLaunchCastModule...
    INFO: Applying settings change to module CMusicNowPlayingModule...
    INFO: Applying settings change to module CMusicSearchModule...
    INFO: Applying settings change to module CMusicSearchResultsModule...
    INFO: Applying settings change to module CSetTimeSettingsModule...
    INFO: Applying settings change to module CStartupSettingsModule...
    INFO: Applying settings change to module CFileSearchResultsModule...
    INFO: Applying settings change to module CGestureSettingsModule...
    INFO: Applying settings change to module CEnhancedAudioModule...
    INFO: Applying settings change to module CBluetoothPhoneStatusModule...
    INFO: Applying settings change to module CBluetoothPairingModule...
    INFO: Applying settings change to module CWebServicesSettingsModule...
    INFO: Applying settings change to module CScriptListModule...
    INFO: Applying settings change to module CUpdateListModule...
    INFO: Applying settings change to module CNAVSettingsModuleWizard...
    INFO: Applying settings change to module CNAVFindNearbyModule...
    INFO: Applying settings change to module CNAVStatusModule...
    INFO: Applying settings change to module CDVDOptionsModule...
    INFO: Applying settings change to module CLaunchCastSettingsModule...
    INFO: Applying settings change to module CInputOptionsSettingsModule...
    INFO: Applying settings change to module CMoveFileModule...
    INFO: Applying settings change to module CVehicleGraphOBDIIModule...
    INFO: Applying settings change to module CDVDSettingsModule...
    INFO: Applying settings change to module CMusicSongStringColModule...
    INFO: Applying settings change to module CMusicModule...
    INFO: Applying settings change to module CInputSettingsModule...
    INFO: Applying settings change to module CPasswordRenameModule...
    INFO: Applying settings change to module CConfigureRelaySetSettingsModule...
    INFO: Applying settings change to module CBluetoothActiveCallModule...
    INFO: Applying settings change to module CWSPasswordRenameModule...
    INFO: Applying settings change to module CNAVStartModule...
    INFO: Applying settings change to module CNAVFindLatLongModule...
    INFO: Applying settings change to module CNAVDirectionsModule...
    INFO: Applying settings change to module CXMRadioModule...
    INFO: Applying settings change to module CDisplaySettingsModuleWizard...
    INFO: Applying settings change to module CRipMediaSelectTypeModule...
    INFO: Applying settings change to module CRelaySettingsModule...
    INFO: Applying settings change to module CRelaySetSettingsModule...
    INFO: Applying settings change to module CGlyphSettingsModule...
    INFO: Applying settings change to module CAppSoundsModule...
    INFO: Applying settings change to module CBluetoothDialNumberModule...
    INFO: Applying settings change to module CRelayControlModule...
    INFO: Applying settings change to module CVideosModule...
    INFO: Applying settings change to module CSlideshowModule...
    INFO: Applying settings change to module CRipMediaPicturesModule...
    INFO: Applying settings change to module CXMRadioStationListModule...
    INFO: Applying settings change to module CXMRadioStatusModule...
    INFO: Applying settings change to module CLaunchCastStationGuideModule...
    INFO: Applying settings change to module CMusicStartModule...
    INFO: Applying settings change to module CMusicGenreStringColModule...
    INFO: Applying settings change to module CMusicArtistAlbumModule...
    INFO: Applying settings change to module CSimpleSettingsModule...
    INFO: Applying settings change to module CSetTimeSettingsModuleWizard...
    INFO: Applying settings change to module CRelayRenameModule...
    INFO: Applying settings change to module CBluetoothOptionsModule...
    INFO: Applying settings change to module CUserModule9...
    INFO: Applying settings change to overlay CDVDManagerExtendedOverlay...
    INFO: Applying settings change to overlay CNAVScrollMapOverlay...
    INFO: Applying settings change to overlay CFullscreenTVOverlay...
    INFO: Applying settings change to overlay CFullscreenDVDOverlay...
    INFO: Applying settings change to overlay CFullscreenVideoStoppedInfoOverlay...
    INFO: Applying settings change to overlay CFullscreenVideoOverlay...
    INFO: Applying settings change to overlay CMuteOverlay...
    INFO: Applying settings change to overlay CUserOverlay3...
    INFO: Applying settings change to overlay CUserExtendedOverlay2...
    INFO: Applying settings change to overlay CTVManagerOverlay...
    INFO: Applying settings change to overlay FileOptionsOverlay...
    INFO: Applying settings change to overlay CKeyPadNumbersOverlay...
    INFO: Applying settings change to overlay CMultiMonEnabledOverlay...
    INFO: Applying settings change to overlay CComboSelectOverlay...
    INFO: Applying settings change to overlay CRearCameraPropOverlay...
    INFO: Applying settings change to overlay CFunctionNameOverlay...
    INFO: Applying settings change to overlay CUserExtendedOverlay5...
    INFO: Applying settings change to overlay CWebServicesOverlay...
    INFO: Applying settings change to overlay CDVDTray...
    INFO: Applying settings change to overlay CTVChannelChangeOverlay...
    INFO: Applying settings change to overlay CListSearchOverlay...
    INFO: Applying settings change to overlay CUserOverlay4...
    INFO: Applying settings change to overlay CiPodManagerExtendedOverlay...
    INFO: Applying settings change to overlay CNAVViewDirectionOverlay...
    INFO: Applying settings change to overlay CSafeModulesOverlay...
    INFO: Applying settings change to overlay CUserExtendedOverlay4...
    INFO: Applying settings change to overlay CFullscreenVideoInfoOverlay...
    INFO: Applying settings change to overlay CSlideshowOverlay...
    INFO: Applying settings change to overlay CMediaChangeOverlay...
    INFO: Applying settings change to overlay CVolumeOverlay...
    INFO: Applying settings change to overlay CUserOverlay5...
    INFO: Applying settings change to overlay CSatRadioTray...
    INFO: Applying settings change to overlay CXMRadioManagerOverlay...
    INFO: Applying settings change to overlay CNAVFullscreenOverlay...
    INFO: Applying settings change to overlay CBluetoothIncomingCallOverlay...
    INFO: Applying settings change to overlay CUserExtendedOverlay7...
    INFO: Applying settings change to overlay CRadioManagerExtendedOverlay...
    INFO: Applying settings change to overlay CUserOverlay6...
    INFO: Applying settings change to overlay CRadioManagerOverlay...
    INFO: Applying settings change to overlay CDVDManagerOverlay...
    INFO: Applying settings change to overlay CNAVClickedLocationOverlay...
    INFO: Applying settings change to overlay CLaunchCastLoadedOverlay...
    INFO: Applying settings change to overlay CUserExtendedOverlay6...
    INFO: Applying settings change to overlay CMediaTimeOverlay...
    INFO: Applying settings change to overlay CVideoTray...
    INFO: Applying settings change to overlay CTVTray...
    INFO: Applying settings change to overlay CRadioTray...
    INFO: Applying settings change to overlay CLaunchCastTray...
    INFO: Applying settings change to overlay CNAVGPSTrackingOverlay...
    INFO: Applying settings change to overlay CNAVViewFullscreenOverlay...
    INFO: Applying settings change to overlay CVisTitleOverlay...
    INFO: Applying settings change to overlay CGestureModule...
    INFO: Applying settings change to overlay CBluetoothVoiceRecognitionOverlay...
    INFO: Applying settings change to overlay CUserOverlay7...
    INFO: Applying settings change to overlay CMusicTray...
    INFO: Applying settings change to overlay CiPodMusicTray...
    INFO: Applying settings change to overlay CBluetoothConnectedOverlay...
    INFO: Applying settings change to overlay CUserExtendedOverlay9...
    INFO: Applying settings change to overlay CNetworkCommOverlay...
    INFO: Applying settings change to overlay CAlwaysVisibleOverlay...
    INFO: Applying settings change to overlay CUserExtendedOverlay1...
    INFO: Applying settings change to overlay CUserOverlay0...
    INFO: Applying settings change to overlay CAudioFileManagerExtendedOverlay...
    INFO: Applying settings change to overlay CVideoFileManagerOverlay...
    INFO: Applying settings change to overlay CLaunchCastManagerExtendedOverlay...
    INFO: Applying settings change to overlay CLaunchCastManagerOverlay...
    INFO: Applying settings change to overlay CTVPropOverlay...
    INFO: Applying settings change to overlay CHDRadioKeypadOverlay...
    INFO: Applying settings change to overlay CUserExtendedOverlay8...
    INFO: Applying settings change to overlay CUserOverlay8...
    INFO: Applying settings change to overlay CVideoFileManagerExtendedOverlay...
    INFO: Applying settings change to overlay CNAVCurrentDirectionOverlay...
    INFO: Applying settings change to overlay CNAVViewListOverlay...
    INFO: Applying settings change to overlay CVoiceInputModule...
    INFO: Applying settings change to overlay CBluetoothActiveCallOverlay...
    INFO: Applying settings change to overlay CUserOverlay1...
    INFO: Applying settings change to overlay CUserExtendedOverlay0...
    INFO: Applying settings change to overlay CMediaPlaySpeedOverlay...
    INFO: Applying settings change to overlay CKeyPadLettersOverlay...
    INFO: Applying settings change to overlay CNAVViewStatusOverlay...
    INFO: Applying settings change to overlay CRearviewCameraOverlay...
    INFO: Applying settings change to overlay CFullscreenVideoResumeInfoOverlay...
    INFO: Applying settings change to overlay CRipMediaOverlay...
    INFO: Applying settings change to overlay CUserOverlay9...
    INFO: Applying settings change to overlay CTVManagerExtendedOverlay...
    INFO: Applying settings change to overlay CNAVVirtualEarthOverlay...
    INFO: Applying settings change to overlay CGirderModule...
    INFO: Applying settings change to overlay CMusicLoadedOverlay...
    INFO: Applying settings change to overlay CUserExtendedOverlay3...
    INFO: Applying settings change to overlay CUserOverlay2...
    INFO: Applying settings change to overlay CKeyPadWebOverlay...
    INFO: Applying settings change to overlay CAudioFileManagerOverlay...
    INFO: Applying settings change to overlay CXMRadioManagerExtendedOverlay...
    INFO: Applying settings change to overlay CiPodManagerOverlay...
    INFO: Applying settings change to overlay CVisAlbumArtOverlay...
    INFO: Applying settings change to overlay CRelayModule...
    INFO: Applying settings change to overlay CKeyPadAlwaysVisibleOverlay...
    INFO: Applying settings change to media manager CDVDManager...
    INFO: Applying settings change to media manager CiPodManager...
    INFO: Applying settings change to media manager CLaunchCastManager...
    INFO: Applying settings change to media manager CXMRadioManager...
    INFO: Applying settings change to media manager CRadioManager...
    INFO: Applying settings change to media manager CTVManager...
    INFO: Applying settings change to media manager CVideoFileManager...
    INFO: Applying settings change to media manager CAudioFileManager...
    INFO: CAudioFileManager::OnSettingsChange - Could not set volume, audio interface has not been created yet!
    INFO: Performing GPS Startup...
    INFO: CNAVGPSController : COM port 6 opened successfully
    INFO: THREAD ID:3448 = CNAVGPSController::Thread
    INFO: GPS Startup Completed
    INFO: Finished Applying Settings
    INFO: CUVAppData::OnSettingsChange - Done.
    INFO: Performing CDVDManager startup...
    INFO: Performing CiPodManager startup...
    INFO: Performing CLaunchCastManager startup...
    INFO: Performing CXMRadioManager startup...
    INFO: Performing CRadioManager startup...
    INFO: Performing CTVManager startup...
    INFO: Performing CVideoFileManager startup...
    INFO: Performing CAudioFileManager startup...
    INFO: Performing CDVDManagerExtendedOverlay startup...
    INFO: Performing CNAVScrollMapOverlay startup...
    INFO: Performing CFullscreenTVOverlay startup...
    INFO: Performing CFullscreenDVDOverlay startup...
    INFO: Performing CFullscreenVideoStoppedInfoOverlay startup...
    INFO: Performing CFullscreenVideoOverlay startup...
    INFO: Performing CMuteOverlay startup...
    INFO: Performing CUserOverlay3 startup...
    INFO: Performing CUserExtendedOverlay2 startup...
    INFO: Performing CTVManagerOverlay startup...
    INFO: Performing FileOptionsOverlay startup...
    INFO: Performing CKeyPadNumbersOverlay startup...
    INFO: Performing CMultiMonEnabledOverlay startup...
    INFO: Performing CComboSelectOverlay startup...
    INFO: Performing CRearCameraPropOverlay startup...
    INFO: Performing CFunctionNameOverlay startup...
    INFO: Performing CUserExtendedOverlay5 startup...
    INFO: Performing CWebServicesOverlay startup...
    INFO: Performing CDVDTray startup...
    INFO: Performing CTVChannelChangeOverlay startup...
    INFO: Performing CListSearchOverlay startup...
    INFO: Performing CUserOverlay4 startup...
    INFO: Performing CiPodManagerExtendedOverlay startup...
    INFO: Performing CNAVViewDirectionOverlay startup...
    INFO: Performing CSafeModulesOverlay startup...
    INFO: Performing CUserExtendedOverlay4 startup...
    INFO: Performing CFullscreenVideoInfoOverlay startup...
    INFO: Performing CSlideshowOverlay startup...
    INFO: Performing CMediaChangeOverlay startup...
    INFO: Performing CVolumeOverlay startup...
    INFO: Performing CUserOverlay5 startup...
    INFO: Performing CSatRadioTray startup...
    INFO: Performing CXMRadioManagerOverlay startup...
    INFO: Performing CNAVFullscreenOverlay startup...
    INFO: Performing CBluetoothIncomingCallOverlay startup...
    INFO: Performing CUserExtendedOverlay7 startup...
    INFO: Performing CRadioManagerExtendedOverlay startup...
    INFO: Performing CUserOverlay6 startup...
    INFO: Performing CRadioManagerOverlay startup...
    INFO: Performing CDVDManagerOverlay startup...
    INFO: Performing CNAVClickedLocationOverlay startup...
    INFO: Performing CLaunchCastLoadedOverlay startup...
    INFO: Performing CUserExtendedOverlay6 startup...
    INFO: Performing CMediaTimeOverlay startup...
    INFO: Performing CVideoTray startup...
    INFO: Performing CTVTray startup...
    INFO: Performing CRadioTray startup...
    INFO: Performing CLaunchCastTray startup...
    INFO: Performing CNAVGPSTrackingOverlay startup...
    INFO: Performing CNAVViewFullscreenOverlay startup...
    INFO: Performing CVisTitleOverlay startup...
    INFO: Performing CGestureModule startup...
    INFO: Performing CBluetoothVoiceRecognitionOverlay startup...
    INFO: Performing CUserOverlay7 startup...
    INFO: Performing CMusicTray startup...
    INFO: Performing CiPodMusicTray startup...
    INFO: Performing CBluetoothConnectedOverlay startup...
    INFO: Performing CUserExtendedOverlay9 startup...
    INFO: Performing CNetworkCommOverlay startup...
    INFO: THREAD ID:2160 = CSenderThread::StaticSendingThread
    INFO: THREAD ID:3472 = CNetworkCommOverlay::StaticCheckInternetThread
    INFO: Performing CAlwaysVisibleOverlay startup...
    INFO: Performing CUserExtendedOverlay1 startup...
    INFO: Performing CUserOverlay0 startup...
    INFO: Performing CAudioFileManagerExtendedOverlay startup...
    INFO: Performing CVideoFileManagerOverlay startup...
    INFO: Performing CLaunchCastManagerExtendedOverlay startup...
    INFO: Performing CLaunchCastManagerOverlay startup...
    INFO: Performing CTVPropOverlay startup...
    INFO: Performing CHDRadioKeypadOverlay startup...
    INFO: Performing CUserExtendedOverlay8 startup...
    INFO: Performing CUserOverlay8 startup...
    INFO: Performing CVideoFileManagerExtendedOverlay startup...
    INFO: Performing CNAVCurrentDirectionOverlay startup...
    INFO: Performing CNAVViewListOverlay startup...
    INFO: Performing CVoiceInputModule startup...
    INFO: Performing CBluetoothActiveCallOverlay startup...
    INFO: Performing CUserOverlay1 startup...
    INFO: Performing CUserExtendedOverlay0 startup...
    INFO: Performing CMediaPlaySpeedOverlay startup...
    INFO: Performing CKeyPadLettersOverlay startup...
    INFO: Performing CNAVViewStatusOverlay startup...
    INFO: Performing CRearviewCameraOverlay startup...
    INFO: Performing CFullscreenVideoResumeInfoOverlay startup...
    INFO: Performing CRipMediaOverlay startup...
    INFO: Performing CUserOverlay9 startup...
    INFO: Performing CTVManagerExtendedOverlay startup...
    INFO: Performing CNAVVirtualEarthOverlay startup...
    INFO: Performing CGirderModule startup...
    INFO: Performing CMusicLoadedOverlay startup...
    INFO: Performing CUserExtendedOverlay3 startup...
    INFO: Performing CUserOverlay2 startup...
    INFO: Performing CKeyPadWebOverlay startup...
    INFO: Performing CAudioFileManagerOverlay startup...
    INFO: Performing CXMRadioManagerExtendedOverlay startup...
    INFO: Performing CiPodManagerOverlay startup...
    INFO: Performing CVisAlbumArtOverlay startup...
    INFO: Performing CRelayModule startup...
    INFO: Performing CKeyPadAlwaysVisibleOverlay startup...
    INFO: Performing CNAVFindResultsModule startup...
    INFO: Performing CNAVFavoritesRenameModule startup...
    INFO: Performing CNAVStreetSettingsModule startup...
    INFO: Performing CNAVMapOnlyModule startup...
    INFO: Performing CTVOptionsModule startup...
    INFO: Performing CStartModule startup...
    INFO: Performing CRipMediaTransferModule startup...
    INFO: Performing CNetSyncSettingsModule startup...
    WARNING: CNetSyncSettingsModule::OnStartup - Could not open sync settings file (C:\Documents and Settings\Alok Car PC\My Documents\StreetDeck\NetSync.dat) to get encrypted password!
    INFO: Performing CUserModule8 startup...
    INFO: Performing CWSUserNameRenameModule startup...
    INFO: Performing CRemoteMediaDestinationModule startup...
    INFO: Performing CScriptRemoveModule startup...
    INFO: Performing CNAVFindPlacesListModule startup...
    INFO: Performing CFullScreenDVDModule startup...
    INFO: Performing CLCPasswordRenameModule startup...
    INFO: Performing CShutdownSettingsModule startup...
    INFO: Performing CVolumeModule startup...
    INFO: Performing CBluetoothSettingsModule startup...
    INFO: Performing CBluetoothPairedDevicesModule startup...
    INFO: Performing CNAVPOIModule startup...
    INFO: Performing CDiagnosticsViewCodeModule startup...
    INFO: Performing CHelpModule startup...
    INFO: Performing CYahooSearchModule startup...
    INFO: Performing CMediaDestinationRename startup...
    INFO: Performing CRipMediaSettingsModule startup...
    INFO: Performing CNetComputerBrowserModule startup...
    INFO: Performing CBluetoothSendTonesModule startup...
    INFO: Performing CBluetoothStartModule startup...
    INFO: Performing CNAVShowRouteModule startup...
    INFO: Performing CRipMediaPOIModule startup...
    INFO: Performing CNAVMapModule startup...
    INFO: Performing CFullScreenTVModule startup...
    INFO: Performing CFullScreenVideoFileModule startup...
    INFO: Performing CMusicVMODStartModule startup...
    INFO: Performing CMusicArtistStringColModule startup...
    INFO: Performing CMusicPlaylistModule startup...
    INFO: Performing CGeneralSettingsModule startup...
    INFO: Performing CRenameModule startup...
    INFO: Performing CBluetoothPhoneBookEntryModule startup...
    INFO: Performing CUserModule5 startup...
    INFO: Performing CNAVFindPlaceModule startup...
    INFO: Performing CNAVDBFindPlaceModule startup...
    INFO: Performing CRearviewCameraModule startup...
    INFO: Performing CRearviewCameraSettingsModule startup...
    INFO: Performing CDVDSelectSubPictureStreamModule startup...
    INFO: Performing CPictureSettingsModule startup...
    INFO: Performing CMusicSelectFolderModule startup...
    INFO: Performing CExternalAppsModule startup...
    INFO: Performing CRelayPluginSettingsModule startup...
    INFO: Performing CBluetoothImportBluetoothModule startup...
    INFO: Performing CUserModule4 startup...
    INFO: Performing {1FB0936A-FD23-4A41-86E3-61C3F3977B0F}\main startup...
    INFO: Performing CNAVSettingsModule startup...
    INFO: Performing COBDIISettingsModule startup...
    INFO: Performing CMusicPlaylistContentsModule startup...
    INFO: Performing CMainSettingsModule startup...
    INFO: Performing CSyncSourceModule startup...
    INFO: Performing CMultiMonSettingsModule startup...
    INFO: Performing CCalibrateDisplayModule startup...
    INFO: Performing CStartupSettingsModuleWizard startup...
    INFO: Performing CSystemRestoreModule startup...
    INFO: Performing CBalanceFaderModule startup...
    INFO: Performing CBluetoothPhoneBookModule startup...
    INFO: Performing CBluetoothPairedDeviceStatusModule startup...
    INFO: Performing CUserModule7 startup...
    INFO: Performing CDiagnosticsModule startup...
    INFO: Performing CXMRadioChooseStationsModule startup...
    INFO: Performing CShutdownModule startup...
    INFO: Performing CDisplaySettingsModule startup...
    INFO: Performing CConfigureRelayPluginSettingsModule startup...
    INFO: Performing CUserModule6 startup...
    INFO: Performing CNAVRouteTypeModule startup...
    INFO: Performing CHDRadioModule startup...
    INFO: Performing CiPodModule startup...
    INFO: Performing CRipMediaMusicModule startup...
    INFO: Performing CMusicSettingsModule startup...
    INFO: Performing CShortcutsModule startup...
    INFO: Performing CChooseRelaysSettingsModule startup...
    INFO: Performing CBluetoothImportModule startup...
    INFO: Performing CUserModule1 startup...
    INFO: Performing CNAVFindAddress startup...
    INFO: Performing CVehicleModule startup...
    INFO: Performing CDVDInfoModule startup...
    INFO: Performing CVideoSettingsModule startup...
    INFO: Performing CXMRadioSettingsModule startup...
    INFO: Performing CVisualizationModule startup...
    INFO: Performing CColorSettingsModule startup...
    INFO: Performing CWMEqualizerModule startup...
    INFO: Performing CBluetoothImportCSVModule startup...
    INFO: Performing CUserModule0 startup...
    INFO: Performing CPackageListModule startup...
    INFO: Performing CVehicleSettingsModule startup...
    INFO: Performing CDVDSelectAudioStreamModule startup...
    INFO: Performing CXMRadioSettingsModuleWizard startup...
    INFO: Performing CRadioSettingsModule startup...
    INFO: Performing CSystemInformationModule startup...
    INFO: Performing CKeyboardSettingsModule startup...
    INFO: Performing CNetShareBrowserModule startup...
    INFO: Performing CBluetoothVolumeModule startup...
    INFO: Performing CBluetoothSettingsModuleWizard startup...
    INFO: Performing CUserModule3 startup...
    INFO: Performing {03531B5D-1128-46B1-B412-1B6679485D5D}\ProcessSatellites startup...
    INFO: Performing CRipMediaVideosModule startup...
    INFO: Performing CNAVFullScreenModule startup...
    INFO: Performing CPicturesModule startup...
    INFO: Performing CGirderPluginSettingsModule startup...
    INFO: Performing CLCUserNameRenameModule startup...
    INFO: Performing CAboutModule startup...
    INFO: Performing CProcessShutdownModule startup...
    INFO: Performing CSkinSettingsModule startup...
    INFO: Performing CUserNameRenameModule startup...
    INFO: Performing CFileSearchRenameModule startup...
    INFO: Performing CBluetoothCallLogModule startup...
    INFO: Performing CBluetoothMainModule startup...
    INFO: Performing CUserModule2 startup...
    INFO: Performing CAddPackageModule startup...
    INFO: Performing CNAVCustomPOIModule startup...
    INFO: Performing CLaunchCastFilterStationsModule startup...
    INFO: Performing CMusicAlbumStringColModule startup...
    INFO: Performing CVoiceInputSettingsModule startup...
    INFO: Performing CBluetoothEditPhoneBookEntryModule startup...
    INFO: Performing CConfigureRearviewCameraSettingsModule startup...
    INFO: Performing CGirderSettingsModule startup...
    INFO: Performing CLaunchCastModule startup...
    INFO: Performing CMusicNowPlayingModule startup...
    INFO: Performing CMusicSearchModule startup...
    INFO: Performing CMusicSearchResultsModule startup...
    INFO: Performing CSetTimeSettingsModule startup...
    INFO: Performing CStartupSettingsModule startup...
    INFO: Performing CFileSearchResultsModule startup...
    INFO: Performing CGestureSettingsModule startup...
    INFO: Performing CEnhancedAudioModule startup...
    INFO: Performing CBluetoothPhoneStatusModule startup...
    INFO: Performing CBluetoothPairingModule startup...
    INFO: Performing CWebServicesSettingsModule startup...
    INFO: Performing CScriptListModule startup...
    INFO: Performing CUpdateListModule startup...
    INFO: Performing CNAVSettingsModuleWizard startup...
    INFO: Performing CNAVFindNearbyModule startup...
    INFO: Performing CNAVStatusModule startup...
    INFO: Performing CDVDOptionsModule startup...
    INFO: Performing CLaunchCastSettingsModule startup...
    INFO: Performing CInputOptionsSettingsModule startup...
    INFO: Performing CMoveFileModule startup...
    INFO: Performing CVehicleGraphOBDIIModule startup...
    INFO: Performing CDVDSettingsModule startup...
    INFO: Performing CMusicSongStringColModule startup...
    INFO: Performing CMusicModule startup...
    INFO: Performing CInputSettingsModule startup...
    INFO: Performing CPasswordRenameModule startup...
    INFO: Performing CConfigureRelaySetSettingsModule startup...
    INFO: Performing CBluetoothActiveCallModule startup...
    INFO: Performing CWSPasswordRenameModule startup...
    INFO: Performing CNAVStartModule startup...
    INFO: Performing CNAVFindLatLongModule startup...
    INFO: Performing CNAVDirectionsModule startup...
    INFO: Performing CXMRadioModule startup...
    INFO: Performing CDisplaySettingsModuleWizard startup...
    INFO: Performing CRipMediaSelectTypeModule startup...
    INFO: Performing CRelaySettingsModule startup...
    INFO: Performing CRelaySetSettingsModule startup...
    INFO: Performing CGlyphSettingsModule startup...
    INFO: Performing CAppSoundsModule startup...
    INFO: Performing CBluetoothDialNumberModule startup...
    INFO: Performing CRelayControlModule startup...
    INFO: Performing CVideosModule startup...
    INFO: Performing CSlideshowModule startup...
    INFO: Performing CRipMediaPicturesModule startup...
    INFO: Performing CXMRadioStationListModule startup...
    INFO: Performing CXMRadioStatusModule startup...
    INFO: Performing CLaunchCastStationGuideModule startup...
    INFO: Performing CMusicStartModule startup...
    INFO: Performing CMusicGenreStringColModule startup...
    INFO: Performing CMusicArtistAlbumModule startup...
    INFO: Performing CSimpleSettingsModule startup...
    INFO: Performing CSetTimeSettingsModuleWizard startup...
    INFO: Performing CRelayRenameModule startup...
    INFO: Performing CBluetoothOptionsModule startup...
    INFO: Performing CUserModule9 startup...
    INFO: CDrawWnd::Create - Initialization completed!
    INFO: CDrawWnd::Create - Program initialization completed in 18 seconds.
    INFO: CStreetDeckApp::InitInstance - Register All Started!
    INFO: CStreetDeckApp::InitInstance - Register All Finished!
    INFO: Loading Sounds...
    INFO: CSoundController::LoadSounds...
    INFO: CSoundController::LoadSounds...Finished
    INFO: CAppData::Exec - Executing Module CVehicleModule
    INFO: CAppData::Exec - Executing Module CVehicleGraphOBDIIModule
    INFO: THREAD ID:3792 = CVehicleGraphOBDIIModule
    INFO: CModule::StaticSupportThread - CVehicleGraphOBDIIModule...
    WARNING: CVehicleGraphOBDIIModule::InitPlugin - Could not connect to port 7
    INFO: CModule::StaticSupportThread - CVehicleGraphOBDIIModule finished thread (RetVal=-1)
    INFO: Message Box:
    OBD II Error!
    An error occured while quering the OBD II device! Please see the OBD II plugin's log for details.
    INFO: CAppData::Exec - Executing Module CShutdownModule
    INFO: CShutdownModule::OnEnter - Shutdown started (4)
    INFO: Saving script options for GPS status...
    INFO: Saving script options for Weather...
    INFO: CAppData::SaveXMLSettings - Saving XML Settings...
    INFO: CProcessShutdownModule::Exit - The initial shutdown sequence has completed processing. (Shutdown Option = 4)
    INFO: CAppData::QueryShutdown - Shutdown Allowed!
    INFO: Peforming NAV Shutdown...
    INFO: CNAVGPSController:isconnect - Disconnecting GPS device
    INFO: Performing CNAVFindResultsModule shutdown...
    INFO: Performing CNAVFavoritesRenameModule shutdown...
    INFO: Performing CNAVStreetSettingsModule shutdown...
    INFO: Performing CNAVMapOnlyModule shutdown...
    INFO: Performing CTVOptionsModule shutdown...
    INFO: Performing CStartModule shutdown...
    INFO: Performing CRipMediaTransferModule shutdown...
    INFO: Performing CNetSyncSettingsModule shutdown...
    INFO: Performing CUserModule8 shutdown...
    INFO: Performing CWSUserNameRenameModule shutdown...
    INFO: Performing CRemoteMediaDestinationModule shutdown...
    INFO: Performing CScriptRemoveModule shutdown...
    INFO: Performing CNAVFindPlacesListModule shutdown...
    INFO: Performing CFullScreenDVDModule shutdown...
    INFO: Performing CLCPasswordRenameModule shutdown...
    INFO: Performing CShutdownSettingsModule shutdown...
    INFO: Performing CVolumeModule shutdown...
    INFO: Performing CBluetoothSettingsModule shutdown...
    INFO: Performing CBluetoothPairedDevicesModule shutdown...
    INFO: Performing CNAVPOIModule shutdown...
    INFO: Performing CDiagnosticsViewCodeModule shutdown...
    INFO: Performing CHelpModule shutdown...
    INFO: Performing CYahooSearchModule shutdown...
    INFO: Performing CMediaDestinationRename shutdown...
    INFO: Performing CRipMediaSettingsModule shutdown...
    INFO: Performing CNetComputerBrowserModule shutdown...
    INFO: Performing CBluetoothSendTonesModule shutdown...
    INFO: Performing CBluetoothStartModule shutdown...
    INFO: CBluetoothCSRDevice::StopMicrophoneAudio - Stopping Microphone Audio Stream
    INFO: CBluetoothCSRDevice::StopMicrophoneAudio - Microphone Audio Stream Stopped!
    INFO: CBluetoothCSRDevice::StopSpeakerAudio - Stopping Speaker Audio Stream
    INFO: CBluetoothCSRDevice::StopSpeakerAudio - Speaker Audio Stream Stopped!
    INFO: Performing CNAVShowRouteModule shutdown...
    INFO: Performing CRipMediaPOIModule shutdown...
    INFO: Performing CNAVMapModule shutdown...
    INFO: Performing CFullScreenTVModule shutdown...
    INFO: Performing CFullScreenVideoFileModule shutdown...
    INFO: Performing CMusicVMODStartModule shutdown...
    INFO: Performing CMusicArtistStringColModule shutdown...
    INFO: Performing CMusicPlaylistModule shutdown...
    INFO: Performing CGeneralSettingsModule shutdown...
    INFO: Performing CRenameModule shutdown...
    INFO: Performing CBluetoothPhoneBookEntryModule shutdown...
    INFO: Performing CUserModule5 shutdown...
    INFO: Performing CNAVFindPlaceModule shutdown...
    INFO: Performing CNAVDBFindPlaceModule shutdown...
    INFO: Performing CRearviewCameraModule shutdown...
    INFO: Performing CRearviewCameraSettingsModule shutdown...
    INFO: Performing CDVDSelectSubPictureStreamModule shutdown...
    INFO: Performing CPictureSettingsModule shutdown...
    INFO: Performing CMusicSelectFolderModule shutdown...
    INFO: Performing CExternalAppsModule shutdown...
    INFO: Performing CRelayPluginSettingsModule shutdown...
    INFO: Performing CBluetoothImportBluetoothModule shutdown...
    INFO: Performing CUserModule4 shutdown...
    INFO: Performing {1FB0936A-FD23-4A41-86E3-61C3F3977B0F}\main shutdown...
    INFO: Performing CNAVSettingsModule shutdown...
    INFO: Performing COBDIISettingsModule shutdown...
    INFO: Performing CMusicPlaylistContentsModule shutdown...
    INFO: Performing CMainSettingsModule shutdown...
    INFO: Performing CSyncSourceModule shutdown...
    INFO: Performing CMultiMonSettingsModule shutdown...
    INFO: Performing CCalibrateDisplayModule shutdown...
    INFO: Performing CStartupSettingsModuleWizard shutdown...
    INFO: Performing CSystemRestoreModule shutdown...
    INFO: Performing CBalanceFaderModule shutdown...
    INFO: Performing CBluetoothPhoneBookModule shutdown...
    INFO: Performing CBluetoothPairedDeviceStatusModule shutdown...
    INFO: Performing CUserModule7 shutdown...
    INFO: Performing CDiagnosticsModule shutdown...
    INFO: Performing CXMRadioChooseStationsModule shutdown...
    INFO: Performing CShutdownModule shutdown...
    INFO: Performing CDisplaySettingsModule shutdown...
    INFO: Performing CConfigureRelayPluginSettingsModule shutdown...
    INFO: Performing CUserModule6 shutdown...
    INFO: Performing CNAVRouteTypeModule shutdown...
    INFO: Performing CHDRadioModule shutdown...
    INFO: Performing CiPodModule shutdown...
    INFO: Performing CRipMediaMusicModule shutdown...
    INFO: Performing CMusicSettingsModule shutdown...
    INFO: Performing CShortcutsModule shutdown...
    INFO: Performing CChooseRelaysSettingsModule shutdown...
    INFO: Performing CBluetoothImportModule shutdown...
    INFO: Performing CUserModule1 shutdown...
    INFO: Performing CNAVFindAddress shutdown...
    INFO: Performing CVehicleModule shutdown...
    INFO: Performing CDVDInfoModule shutdown...
    INFO: Performing CVideoSettingsModule shutdown...
    INFO: Performing CXMRadioSettingsModule shutdown...
    INFO: Performing CVisualizationModule shutdown...
    INFO: Performing CColorSettingsModule shutdown...
    INFO: Performing CWMEqualizerModule shutdown...
    INFO: Performing CBluetoothImportCSVModule shutdown...
    INFO: Performing CUserModule0 shutdown...
    INFO: Performing CPackageListModule shutdown...
    INFO: Performing CVehicleSettingsModule shutdown...
    INFO: Performing CDVDSelectAudioStreamModule shutdown...
    INFO: Performing CXMRadioSettingsModuleWizard shutdown...
    INFO: Performing CRadioSettingsModule shutdown...
    INFO: Performing CSystemInformationModule shutdown...
    INFO: Performing CKeyboardSettingsModule shutdown...
    INFO: Performing CNetShareBrowserModule shutdown...
    INFO: Performing CBluetoothVolumeModule shutdown...
    INFO: Performing CBluetoothSettingsModuleWizard shutdown...
    INFO: Performing CUserModule3 shutdown...
    INFO: Performing {03531B5D-1128-46B1-B412-1B6679485D5D}\ProcessSatellites shutdown...
    INFO: Performing CRipMediaVideosModule shutdown...
    INFO: Performing CNAVFullScreenModule shutdown...
    INFO: Performing CPicturesModule shutdown...
    INFO: Performing CGirderPluginSettingsModule shutdown...
    INFO: Performing CLCUserNameRenameModule shutdown...
    INFO: Performing CAboutModule shutdown...
    INFO: Performing CProcessShutdownModule shutdown...
    INFO: Performing CSkinSettingsModule shutdown...
    INFO: Performing CUserNameRenameModule shutdown...
    INFO: Performing CFileSearchRenameModule shutdown...
    INFO: Performing CBluetoothCallLogModule shutdown...
    INFO: Performing CBluetoothMainModule shutdown...
    INFO: Performing CUserModule2 shutdown...
    INFO: Performing CAddPackageModule shutdown...
    INFO: Performing CNAVCustomPOIModule shutdown...
    INFO: Performing CLaunchCastFilterStationsModule shutdown...
    INFO: Performing CMusicAlbumStringColModule shutdown...
    INFO: Performing CVoiceInputSettingsModule shutdown...
    INFO: Performing CBluetoothEditPhoneBookEntryModule shutdown...
    INFO: Performing CConfigureRearviewCameraSettingsModule shutdown...
    INFO: Performing CGirderSettingsModule shutdown...
    INFO: Performing CLaunchCastModule shutdown...
    INFO: Performing CMusicNowPlayingModule shutdown...
    INFO: Performing CMusicSearchModule shutdown...
    INFO: Performing CMusicSearchResultsModule shutdown...
    INFO: Performing CSetTimeSettingsModule shutdown...
    INFO: Performing CStartupSettingsModule shutdown...
    INFO: Performing CFileSearchResultsModule shutdown...
    INFO: Performing CGestureSettingsModule shutdown...
    INFO: Performing CEnhancedAudioModule shutdown...
    INFO: Performing CBluetoothPhoneStatusModule shutdown...
    INFO: Performing CBluetoothPairingModule shutdown...
    INFO: Performing CWebServicesSettingsModule shutdown...
    INFO: Performing CScriptListModule shutdown...
    INFO: Performing CUpdateListModule shutdown...
    INFO: Performing CNAVSettingsModuleWizard shutdown...
    INFO: Performing CNAVFindNearbyModule shutdown...
    INFO: Performing CNAVStatusModule shutdown...
    INFO: Performing CDVDOptionsModule shutdown...
    INFO: Performing CLaunchCastSettingsModule shutdown...
    INFO: Performing CInputOptionsSettingsModule shutdown...
    INFO: Performing CMoveFileModule shutdown...
    INFO: Performing CVehicleGraphOBDIIModule shutdown...
    INFO: Performing CDVDSettingsModule shutdown...
    INFO: Performing CMusicSongStringColModule shutdown...
    INFO: Performing CMusicModule shutdown...
    INFO: Performing CInputSettingsModule shutdown...
    INFO: Performing CPasswordRenameModule shutdown...
    INFO: Performing CConfigureRelaySetSettingsModule shutdown...
    INFO: Performing CBluetoothActiveCallModule shutdown...
    INFO: Performing CWSPasswordRenameModule shutdown...
    INFO: Performing CNAVStartModule shutdown...
    INFO: Performing CNAVFindLatLongModule shutdown...
    INFO: Performing CNAVDirectionsModule shutdown...
    INFO: Performing CXMRadioModule shutdown...
    INFO: Performing CDisplaySettingsModuleWizard shutdown...
    INFO: Performing CRipMediaSelectTypeModule shutdown...
    INFO: Performing CRelaySettingsModule shutdown...
    INFO: Performing CRelaySetSettingsModule shutdown...
    INFO: Performing CGlyphSettingsModule shutdown...
    INFO: Performing CAppSoundsModule shutdown...
    INFO: Performing CBluetoothDialNumberModule shutdown...
    INFO: Performing CRelayControlModule shutdown...
    INFO: Performing CVideosModule shutdown...
    INFO: Performing CSlideshowModule shutdown...
    INFO: Performing CRipMediaPicturesModule shutdown...
    INFO: Performing CXMRadioStationListModule shutdown...
    INFO: Performing CXMRadioStatusModule shutdown...
    INFO: Performing CLaunchCastStationGuideModule shutdown...
    INFO: Performing CMusicStartModule shutdown...
    INFO: Performing CMusicGenreStringColModule shutdown...
    INFO: Performing CMusicArtistAlbumModule shutdown...
    INFO: Performing CSimpleSettingsModule shutdown...
    INFO: Performing CSetTimeSettingsModuleWizard shutdown...
    INFO: Performing CRelayRenameModule shutdown...
    INFO: Performing CBluetoothOptionsModule shutdown...
    INFO: Performing CUserModule9 shutdown...
    INFO: Performing CDVDManagerExtendedOverlay shutdown...
    INFO: Performing CNAVScrollMapOverlay shutdown...
    INFO: Performing CFullscreenTVOverlay shutdown...
    INFO: Performing CFullscreenDVDOverlay shutdown...
    INFO: Performing CFullscreenVideoStoppedInfoOverlay shutdown...
    INFO: Performing CFullscreenVideoOverlay shutdown...
    INFO: Performing CMuteOverlay shutdown...
    INFO: Performing CUserOverlay3 shutdown...
    INFO: Performing CUserExtendedOverlay2 shutdown...
    INFO: Performing CTVManagerOverlay shutdown...
    INFO: Performing FileOptionsOverlay shutdown...
    INFO: Performing CKeyPadNumbersOverlay shutdown...
    INFO: Performing CMultiMonEnabledOverlay shutdown...
    INFO: Performing CComboSelectOverlay shutdown...
    INFO: Performing CRearCameraPropOverlay shutdown...
    INFO: Performing CFunctionNameOverlay shutdown...
    INFO: Performing CUserExtendedOverlay5 shutdown...
    INFO: Performing CWebServicesOverlay shutdown...
    INFO: Performing CDVDTray shutdown...
    INFO: Performing CTVChannelChangeOverlay shutdown...
    INFO: Performing CListSearchOverlay shutdown...
    INFO: Performing CUserOverlay4 shutdown...
    INFO: Performing CiPodManagerExtendedOverlay shutdown...
    INFO: Performing CNAVViewDirectionOverlay shutdown...
    INFO: Performing CSafeModulesOverlay shutdown...
    INFO: Performing CUserExtendedOverlay4 shutdown...
    INFO: Performing CFullscreenVideoInfoOverlay shutdown...
    INFO: Performing CSlideshowOverlay shutdown...
    INFO: Performing CMediaChangeOverlay shutdown...
    INFO: Performing CVolumeOverlay shutdown...
    INFO: Performing CUserOverlay5 shutdown...
    INFO: Performing CSatRadioTray shutdown...
    INFO: Performing CXMRadioManagerOverlay shutdown...
    INFO: Performing CNAVFullscreenOverlay shutdown...
    INFO: Performing CBluetoothIncomingCallOverlay shutdown...
    INFO: Performing CUserExtendedOverlay7 shutdown...
    INFO: Performing CRadioManagerExtendedOverlay shutdown...
    INFO: Performing CUserOverlay6 shutdown...
    INFO: Performing CRadioManagerOverlay shutdown...
    INFO: Performing CDVDManagerOverlay shutdown...
    INFO: Performing CNAVClickedLocationOverlay shutdown...
    INFO: Performing CLaunchCastLoadedOverlay shutdown...
    INFO: Performing CUserExtendedOverlay6 shutdown...
    INFO: Performing CMediaTimeOverlay shutdown...
    INFO: Performing CVideoTray shutdown...
    INFO: Performing CTVTray shutdown...
    INFO: Performing CRadioTray shutdown...
    INFO: Performing CLaunchCastTray shutdown...
    INFO: Performing CNAVGPSTrackingOverlay shutdown...
    INFO: Performing CNAVViewFullscreenOverlay shutdown...
    INFO: Performing CVisTitleOverlay shutdown...
    INFO: Performing CGestureModule shutdown...
    INFO: Performing CBluetoothVoiceRecognitionOverlay shutdown...
    INFO: Performing CUserOverlay7 shutdown...
    INFO: Performing CMusicTray shutdown...
    INFO: Performing CiPodMusicTray shutdown...
    INFO: Performing CBluetoothConnectedOverlay shutdown...
    INFO: Performing CUserExtendedOverlay9 shutdown...
    INFO: Performing CNetworkCommOverlay shutdown...
    INFO: Performing CAlwaysVisibleOverlay shutdown...
    INFO: Performing CUserExtendedOverlay1 shutdown...
    INFO: Performing CUserOverlay0 shutdown...
    INFO: Performing CAudioFileManagerExtendedOverlay shutdown...
    INFO: Performing CVideoFileManagerOverlay shutdown...
    INFO: Performing CLaunchCastManagerExtendedOverlay shutdown...
    INFO: Performing CLaunchCastManagerOverlay shutdown...
    INFO: Performing CTVPropOverlay shutdown...
    INFO: Performing CHDRadioKeypadOverlay shutdown...
    INFO: Performing CUserExtendedOverlay8 shutdown...
    INFO: Performing CUserOverlay8 shutdown...
    INFO: Performing CVideoFileManagerExtendedOverlay shutdown...
    INFO: Performing CNAVCurrentDirectionOverlay shutdown...
    INFO: Performing CNAVViewListOverlay shutdown...
    INFO: Performing CVoiceInputModule shutdown...
    INFO: Performing CBluetoothActiveCallOverlay shutdown...
    INFO: Performing CUserOverlay1 shutdown...
    INFO: Performing CUserExtendedOverlay0 shutdown...
    INFO: Performing CMediaPlaySpeedOverlay shutdown...
    INFO: Performing CKeyPadLettersOverlay shutdown...
    INFO: Performing CNAVViewStatusOverlay shutdown...
    INFO: Performing CRearviewCameraOverlay shutdown...
    INFO: Performing CFullscreenVideoResumeInfoOverlay shutdown...
    INFO: Performing CRipMediaOverlay shutdown...
    INFO: Performing CUserOverlay9 shutdown...
    INFO: Performing CTVManagerExtendedOverlay shutdown...
    INFO: Performing CNAVVirtualEarthOverlay shutdown...
    INFO: Performing CGirderModule shutdown...
    INFO: Performing CMusicLoadedOverlay shutdown...
    INFO: Performing CUserExtendedOverlay3 shutdown...
    INFO: Performing CUserOverlay2 shutdown...
    INFO: Performing CKeyPadWebOverlay shutdown...
    INFO: Performing CAudioFileManagerOverlay shutdown...
    INFO: Performing CXMRadioManagerExtendedOverlay shutdown...
    INFO: Performing CiPodManagerOverlay shutdown...
    INFO: Performing CVisAlbumArtOverlay shutdown...
    INFO: Performing CRelayModule shutdown...
    INFO: Performing CKeyPadAlwaysVisibleOverlay shutdown...
    INFO: Performing CDVDManager shutdown...
    INFO: Performing CiPodManager shutdown...
    INFO: Performing CLaunchCastManager shutdown...
    INFO: Performing CXMRadioManager shutdown...
    INFO: Performing XM Shutdown...
    INFO: Performing CRadioManager shutdown...
    INFO: Performing CTVManager shutdown...
    INFO: Performing CVideoFileManager shutdown...
    INFO: Performing CAudioFileManager shutdown...
    INFO: CAppData::PerformShutdown - Shutdown complete!
    INFO: CAppData::PerformShutdown - Shutdown finished at (12:26:59)!
    INFO: CProcessShutdownModule::Exit - Closing...
    INFO: CDrawWnd::Cleanup3Denvironment...
    INFO: CDrawWnd::InvalidateDeviceObjects...
    INFO: Invalidating module CNAVFindResultsModule...
    INFO: Invalidating module CNAVFavoritesRenameModule...
    INFO: Invalidating module CNAVStreetSettingsModule...
    INFO: Invalidating module CNAVMapOnlyModule...
    INFO: Invalidating module CTVOptionsModule...
    INFO: Invalidating module CStartModule...
    INFO: Invalidating module CRipMediaTransferModule...
    INFO: Invalidating module CNetSyncSettingsModule...
    INFO: Invalidating module CUserModule8...
    INFO: Invalidating module CWSUserNameRenameModule...
    INFO: Invalidating module CRemoteMediaDestinationModule...
    INFO: Invalidating module CScriptRemoveModule...
    INFO: Invalidating module CNAVFindPlacesListModule...
    INFO: Invalidating module CFullScreenDVDModule...
    INFO: Invalidating module CLCPasswordRenameModule...
    INFO: Invalidating module CShutdownSettingsModule...
    INFO: Invalidating module CVolumeModule...
    INFO: Invalidating module CBluetoothSettingsModule...
    INFO: Invalidating module CBluetoothPairedDevicesModule...
    INFO: Invalidating module CNAVPOIModule...
    INFO: Invalidating module CDiagnosticsViewCodeModule...
    INFO: Invalidating module CHelpModule...
    INFO: Invalidating module CYahooSearchModule...
    INFO: Invalidating module CMediaDestinationRename...
    INFO: Invalidating module CRipMediaSettingsModule...
    INFO: Invalidating module CNetComputerBrowserModule...
    INFO: Invalidating module CBluetoothSendTonesModule...
    INFO: Invalidating module CBluetoothStartModule...
    INFO: Invalidating module CNAVShowRouteModule...
    INFO: Invalidating module CRipMediaPOIModule...
    INFO: Invalidating module CNAVMapModule...
    INFO: Invalidating module CFullScreenTVModule...
    INFO: Invalidating module CFullScreenVideoFileModule...
    INFO: Invalidating module CMusicVMODStartModule...
    INFO: Invalidating module CMusicArtistStringColModule...
    INFO: Invalidating module CMusicPlaylistModule...
    INFO: Invalidating module CGeneralSettingsModule...
    INFO: Invalidating module CRenameModule...
    INFO: Invalidating module CBluetoothPhoneBookEntryModule...
    INFO: Invalidating module CUserModule5...
    INFO: Invalidating module CNAVFindPlaceModule...
    INFO: Invalidating module CNAVDBFindPlaceModule...
    INFO: Invalidating module CRearviewCameraModule...
    INFO: Invalidating module CRearviewCameraSettingsModule...
    INFO: Invalidating module CDVDSelectSubPictureStreamModule...
    INFO: Invalidating module CPictureSettingsModule...
    INFO: Invalidating module CMusicSelectFolderModule...
    INFO: Invalidating module CExternalAppsModule...
    INFO: Invalidating module CRelayPluginSettingsModule...
    INFO: Invalidating module CBluetoothImportBluetoothModule...
    INFO: Invalidating module CUserModule4...
    INFO: Invalidating module {1FB0936A-FD23-4A41-86E3-61C3F3977B0F}\main...
    INFO: Invalidating module CNAVSettingsModule...
    INFO: Invalidating module COBDIISettingsModule...
    INFO: Invalidating module CMusicPlaylistContentsModule...
    INFO: Invalidating module CMainSettingsModule...
    INFO: Invalidating module CSyncSourceModule...
    INFO: Invalidating module CMultiMonSettingsModule...
    INFO: Invalidating module CCalibrateDisplayModule...
    INFO: Invalidating module CStartupSettingsModuleWizard...
    INFO: Invalidating module CSystemRestoreModule...
    INFO: Invalidating module CBalanceFaderModule...
    INFO: Invalidating module CBluetoothPhoneBookModule...
    INFO: Invalidating module CBluetoothPairedDeviceStatusModule...
    INFO: Invalidating module CUserModule7...
    INFO: Invalidating module CDiagnosticsModule...
    INFO: Invalidating module CXMRadioChooseStationsModule...
    INFO: Invalidating module CShutdownModule...
    INFO: Invalidating module CDisplaySettingsModule...
    INFO: Invalidating module CConfigureRelayPluginSettingsModule...
    INFO: Invalidating module CUserModule6...
    INFO: Invalidating module CNAVRouteTypeModule...
    INFO: Invalidating module CHDRadioModule...
    INFO: Invalidating module CiPodModule...
    INFO: Invalidating module CRipMediaMusicModule...
    INFO: Invalidating module CMusicSettingsModule...
    INFO: Invalidating module CShortcutsModule...
    INFO: Invalidating module CChooseRelaysSettingsModule...
    INFO: Invalidating module CBluetoothImportModule...
    INFO: Invalidating module CUserModule1...
    INFO: Invalidating module CNAVFindAddress...
    INFO: Invalidating module CVehicleModule...
    INFO: Invalidating module CDVDInfoModule...
    INFO: Invalidating module CVideoSettingsModule...
    INFO: Invalidating module CXMRadioSettingsModule...
    INFO: Invalidating module CVisualizationModule...
    INFO: Invalidating module CColorSettingsModule...
    INFO: Invalidating module CWMEqualizerModule...
    INFO: Invalidating module CBluetoothImportCSVModule...
    INFO: Invalidating module CUserModule0...
    INFO: Invalidating module CPackageListModule...
    INFO: Invalidating module CVehicleSettingsModule...
    INFO: Invalidating module CDVDSelectAudioStreamModule...
    INFO: Invalidating module CXMRadioSettingsModuleWizard...
    INFO: Invalidating module CRadioSettingsModule...
    INFO: Invalidating module CSystemInformationModule...
    INFO: Invalidating module CKeyboardSettingsModule...
    INFO: Invalidating module CNetShareBrowserModule...
    INFO: Invalidating module CBluetoothVolumeModule...
    INFO: Invalidating module CBluetoothSettingsModuleWizard...
    INFO: Invalidating module CUserModule3...
    INFO: Invalidating module {03531B5D-1128-46B1-B412-1B6679485D5D}\ProcessSatellites...
    INFO: Invalidating module CRipMediaVideosModule...
    INFO: Invalidating module CNAVFullScreenModule...
    INFO: Invalidating module CPicturesModule...
    INFO: Invalidating module CGirderPluginSettingsModule...
    INFO: Invalidating module CLCUserNameRenameModule...
    INFO: Invalidating module CAboutModule...
    INFO: Invalidating module CProcessShutdownModule...
    INFO: Invalidating module CSkinSettingsModule...
    INFO: Invalidating module CUserNameRenameModule...
    INFO: Invalidating module CFileSearchRenameModule...
    INFO: Invalidating module CBluetoothCallLogModule...
    INFO: Invalidating module CBluetoothMainModule...
    INFO: Invalidating module CUserModule2...
    INFO: Invalidating module CAddPackageModule...
    INFO: Invalidating module CNAVCustomPOIModule...
    INFO: Invalidating module CLaunchCastFilterStationsModule...
    INFO: Invalidating module CMusicAlbumStringColModule...
    INFO: Invalidating module CVoiceInputSettingsModule...
    INFO: Invalidating module CBluetoothEditPhoneBookEntryModule...
    INFO: Invalidating module CConfigureRearviewCameraSettingsModule...
    INFO: Invalidating module CGirderSettingsModule...
    INFO: Invalidating module CLaunchCastModule...
    INFO: Invalidating module CMusicNowPlayingModule...
    INFO: Invalidating module CMusicSearchModule...
    INFO: Invalidating module CMusicSearchResultsModule...
    INFO: Invalidating module CSetTimeSettingsModule...
    INFO: Invalidating module CStartupSettingsModule...
    INFO: Invalidating module CFileSearchResultsModule...
    INFO: Invalidating module CGestureSettingsModule...
    INFO: Invalidating module CEnhancedAudioModule...
    INFO: Invalidating module CBluetoothPhoneStatusModule...
    INFO: Invalidating module CBluetoothPairingModule...
    INFO: Invalidating module CWebServicesSettingsModule...
    INFO: Invalidating module CScriptListModule...
    INFO: Invalidating module CUpdateListModule...
    INFO: Invalidating module CNAVSettingsModuleWizard...
    INFO: Invalidating module CNAVFindNearbyModule...
    INFO: Invalidating module CNAVStatusModule...
    INFO: Invalidating module CDVDOptionsModule...
    INFO: Invalidating module CLaunchCastSettingsModule...
    INFO: Invalidating module CInputOptionsSettingsModule...
    INFO: Invalidating module CMoveFileModule...
    INFO: Invalidating module CVehicleGraphOBDIIModule...
    INFO: Invalidating module CDVDSettingsModule...
    INFO: Invalidating module CMusicSongStringColModule...
    INFO: Invalidating module CMusicModule...
    INFO: Invalidating module CInputSettingsModule...
    INFO: Invalidating module CPasswordRenameModule...
    INFO: Invalidating module CConfigureRelaySetSettingsModule...
    INFO: Invalidating module CBluetoothActiveCallModule...
    INFO: Invalidating module CWSPasswordRenameModule...
    INFO: Invalidating module CNAVStartModule...
    INFO: Invalidating module CNAVFindLatLongModule...
    INFO: Invalidating module CNAVDirectionsModule...
    INFO: Invalidating module CXMRadioModule...
    INFO: Invalidating module CDisplaySettingsModuleWizard...
    INFO: Invalidating module CRipMediaSelectTypeModule...
    INFO: Invalidating module CRelaySettingsModule...
    INFO: Invalidating module CRelaySetSettingsModule...
    INFO: Invalidating module CGlyphSettingsModule...
    INFO: Invalidating module CAppSoundsModule...
    INFO: Invalidating module CBluetoothDialNumberModule...
    INFO: Invalidating module CRelayControlModule...
    INFO: Invalidating module CVideosModule...
    INFO: Invalidating module CSlideshowModule...
    INFO: Invalidating module CRipMediaPicturesModule...
    INFO: Invalidating module CXMRadioStationListModule...
    INFO: Invalidating module CXMRadioStatusModule...
    INFO: Invalidating module CLaunchCastStationGuideModule...
    INFO: Invalidating module CMusicStartModule...
    INFO: Invalidating module CMusicGenreStringColModule...
    INFO: Invalidating module CMusicArtistAlbumModule...
    INFO: Invalidating module CSimpleSettingsModule...
    INFO: Invalidating module CSetTimeSettingsModuleWizard...
    INFO: Invalidating module CRelayRenameModule...
    INFO: Invalidating module CBluetoothOptionsModule...
    INFO: Invalidating module CUserModule9...
    INFO: Invalidating overlay CDVDManagerExtendedOverlay...
    INFO: Invalidating overlay CNAVScrollMapOverlay...
    INFO: Invalidating overlay CFullscreenTVOverlay...
    INFO: Invalidating overlay CFullscreenDVDOverlay...
    INFO: Invalidating overlay CFullscreenVideoStoppedInfoOverlay...
    INFO: Invalidating overlay CFullscreenVideoOverlay...
    INFO: Invalidating overlay CMuteOverlay...
    INFO: Invalidating overlay CUserOverlay3...
    INFO: Invalidating overlay CUserExtendedOverlay2...
    INFO: Invalidating overlay CTVManagerOverlay...
    INFO: Invalidating overlay FileOptionsOverlay...
    INFO: Invalidating overlay CKeyPadNumbersOverlay...
    INFO: Invalidating overlay CMultiMonEnabledOverlay...
    INFO: Invalidating overlay CComboSelectOverlay...
    INFO: Invalidating overlay CRearCameraPropOverlay...
    INFO: Invalidating overlay CFunctionNameOverlay...
    INFO: Invalidating overlay CUserExtendedOverlay5...
    INFO: Invalidating overlay CWebServicesOverlay...
    INFO: Invalidating overlay CDVDTray...
    INFO: Invalidating overlay CTVChannelChangeOverlay...
    INFO: Invalidating overlay CListSearchOverlay...
    INFO: Invalidating overlay CUserOverlay4...
    INFO: Invalidating overlay CiPodManagerExtendedOverlay...
    INFO: Invalidating overlay CNAVViewDirectionOverlay...
    INFO: Invalidating overlay CSafeModulesOverlay...
    INFO: Invalidating overlay CUserExtendedOverlay4...
    INFO: Invalidating overlay CFullscreenVideoInfoOverlay...
    INFO: Invalidating overlay CSlideshowOverlay...
    INFO: Invalidating overlay CMediaChangeOverlay...
    INFO: Invalidating overlay CVolumeOverlay...
    INFO: Invalidating overlay CUserOverlay5...
    INFO: Invalidating overlay CSatRadioTray...
    INFO: Invalidating overlay CXMRadioManagerOverlay...
    INFO: Invalidating overlay CNAVFullscreenOverlay...
    INFO: Invalidating overlay CBluetoothIncomingCallOverlay...
    INFO: Invalidating overlay CUserExtendedOverlay7...
    INFO: Invalidating overlay CRadioManagerExtendedOverlay...
    INFO: Invalidating overlay CUserOverlay6...
    INFO: Invalidating overlay CRadioManagerOverlay...
    INFO: Invalidating overlay CDVDManagerOverlay...
    INFO: Invalidating overlay CNAVClickedLocationOverlay...
    INFO: Invalidating overlay CLaunchCastLoadedOverlay...
    INFO: Invalidating overlay CUserExtendedOverlay6...
    INFO: Invalidating overlay CMediaTimeOverlay...
    INFO: Invalidating overlay CVideoTray...
    INFO: Invalidating overlay CTVTray...
    INFO: Invalidating overlay CRadioTray...
    INFO: Invalidating overlay CLaunchCastTray...
    INFO: Invalidating overlay CNAVGPSTrackingOverlay...
    INFO: Invalidating overlay CNAVViewFullscreenOverlay...
    INFO: Invalidating overlay CVisTitleOverlay...
    INFO: Invalidating overlay CGestureModule...
    INFO: Invalidating overlay CBluetoothVoiceRecognitionOverlay...
    INFO: Invalidating overlay CUserOverlay7...
    INFO: Invalidating overlay CMusicTray...
    INFO: Invalidating overlay CiPodMusicTray...
    INFO: Invalidating overlay CBluetoothConnectedOverlay...
    INFO: Invalidating overlay CUserExtendedOverlay9...
    INFO: Invalidating overlay CNetworkCommOverlay...
    INFO: Invalidating overlay CAlwaysVisibleOverlay...
    INFO: Invalidating overlay CUserExtendedOverlay1...
    INFO: Invalidating overlay CUserOverlay0...
    INFO: Invalidating overlay CAudioFileManagerExtendedOverlay...
    INFO: Invalidating overlay CVideoFileManagerOverlay...
    INFO: Invalidating overlay CLaunchCastManagerExtendedOverlay...
    INFO: Invalidating overlay CLaunchCastManagerOverlay...
    INFO: Invalidating overlay CTVPropOverlay...
    INFO: Invalidating overlay CHDRadioKeypadOverlay...
    INFO: Invalidating overlay CUserExtendedOverlay8...
    INFO: Invalidating overlay CUserOverlay8...
    INFO: Invalidating overlay CVideoFileManagerExtendedOverlay...
    INFO: Invalidating overlay CNAVCurrentDirectionOverlay...
    INFO: Invalidating overlay CNAVViewListOverlay...
    INFO: Invalidating overlay CVoiceInputModule...
    INFO: Invalidating overlay CBluetoothActiveCallOverlay...
    INFO: Invalidating overlay CUserOverlay1...
    INFO: Invalidating overlay CUserExtendedOverlay0...
    INFO: Invalidating overlay CMediaPlaySpeedOverlay...
    INFO: Invalidating overlay CKeyPadLettersOverlay...
    INFO: Invalidating overlay CNAVViewStatusOverlay...
    INFO: Invalidating overlay CRearviewCameraOverlay...
    INFO: Invalidating overlay CFullscreenVideoResumeInfoOverlay...
    INFO: Invalidating overlay CRipMediaOverlay...
    INFO: Invalidating overlay CUserOverlay9...
    INFO: Invalidating overlay CTVManagerExtendedOverlay...
    INFO: Invalidating overlay CNAVVirtualEarthOverlay...
    INFO: Invalidating overlay CGirderModule...
    INFO: Invalidating overlay CMusicLoadedOverlay...
    INFO: Invalidating overlay CUserExtendedOverlay3...
    INFO: Invalidating overlay CUserOverlay2...
    INFO: Invalidating overlay CKeyPadWebOverlay...
    INFO: Invalidating overlay CAudioFileManagerOverlay...
    INFO: Invalidating overlay CXMRadioManagerExtendedOverlay...
    INFO: Invalidating overlay CiPodManagerOverlay...
    INFO: Invalidating overlay CVisAlbumArtOverlay...
    INFO: Invalidating overlay CRelayModule...
    INFO: Invalidating overlay CKeyPadAlwaysVisibleOverlay...
    INFO: CDrawWnd:eleteDeviceObjects...
    INFO: Deleting device objects for CNAVFindResultsModule...
    INFO: Deleting device objects for CNAVFavoritesRenameModule...
    INFO: Deleting device objects for CNAVStreetSettingsModule...
    INFO: Deleting device objects for CNAVMapOnlyModule...
    INFO: Deleting device objects for CTVOptionsModule...
    INFO: Deleting device objects for CStartModule...
    INFO: Deleting device objects for CRipMediaTransferModule...
    INFO: Deleting device objects for CNetSyncSettingsModule...
    INFO: Deleting device objects for CUserModule8...
    INFO: Deleting device objects for CWSUserNameRenameModule...
    INFO: Deleting device objects for CRemoteMediaDestinationModule...
    INFO: Deleting device objects for CScriptRemoveModule...
    INFO: Deleting device objects for CNAVFindPlacesListModule...
    INFO: Deleting device objects for CFullScreenDVDModule...
    INFO: Deleting device objects for CLCPasswordRenameModule...
    INFO: Deleting device objects for CShutdownSettingsModule...
    INFO: Deleting device objects for CVolumeModule...
    INFO: Deleting device objects for CBluetoothSettingsModule...
    INFO: Deleting device objects for CBluetoothPairedDevicesModule...
    INFO: Deleting device objects for CNAVPOIModule...
    INFO: Deleting device objects for CDiagnosticsViewCodeModule...
    INFO: Deleting device objects for CHelpModule...
    INFO: Deleting device objects for CYahooSearchModule...
    INFO: Deleting device objects for CMediaDestinationRename...
    INFO: Deleting device objects for CRipMediaSettingsModule...
    INFO: Deleting device objects for CNetComputerBrowserModule...
    INFO: Deleting device objects for CBluetoothSendTonesModule...
    INFO: Deleting device objects for CBluetoothStartModule...
    INFO: Deleting device objects for CNAVShowRouteModule...
    INFO: Deleting device objects for CRipMediaPOIModule...
    INFO: Deleting device objects for CNAVMapModule...
    INFO: Deleting device objects for CFullScreenTVModule...
    INFO: Deleting device objects for CFullScreenVideoFileModule...
    INFO: Deleting device objects for CMusicVMODStartModule...
    INFO: Deleting device objects for CMusicArtistStringColModule...
    INFO: Deleting device objects for CMusicPlaylistModule...
    INFO: Deleting device objects for CGeneralSettingsModule...
    INFO: Deleting device objects for CRenameModule...
    INFO: Deleting device objects for CBluetoothPhoneBookEntryModule...
    INFO: Deleting device objects for CUserModule5...
    INFO: Deleting device objects for CNAVFindPlaceModule...
    INFO: Deleting device objects for CNAVDBFindPlaceModule...
    INFO: Deleting device objects for CRearviewCameraModule...
    INFO: Deleting device objects for CRearviewCameraSettingsModule...
    INFO: Deleting device objects for CDVDSelectSubPictureStreamModule...
    INFO: Deleting device objects for CPictureSettingsModule...
    INFO: Deleting device objects for CMusicSelectFolderModule...
    INFO: Deleting device objects for CExternalAppsModule...
    INFO: Deleting device objects for CRelayPluginSettingsModule...
    INFO: Deleting device objects for CBluetoothImportBluetoothModule...
    INFO: Deleting device objects for CUserModule4...
    INFO: Deleting device objects for {1FB0936A-FD23-4A41-86E3-61C3F3977B0F}\main...
    INFO: Deleting device objects for CNAVSettingsModule...
    INFO: Deleting device objects for COBDIISettingsModule...
    INFO: Deleting device objects for CMusicPlaylistContentsModule...
    INFO: Deleting device objects for CMainSettingsModule...
    INFO: Deleting device objects for CSyncSourceModule...
    INFO: Deleting device objects for CMultiMonSettingsModule...
    INFO: Deleting device objects for CCalibrateDisplayModule...
    INFO: Deleting device objects for CStartupSettingsModuleWizard...
    INFO: Deleting device objects for CSystemRestoreModule...
    INFO: Deleting device objects for CBalanceFaderModule...
    INFO: Deleting device objects for CBluetoothPhoneBookModule...
    INFO: Deleting device objects for CBluetoothPairedDeviceStatusModule...
    INFO: Deleting device objects for CUserModule7...
    INFO: Deleting device objects for CDiagnosticsModule...
    INFO: Deleting device objects for CXMRadioChooseStationsModule...
    INFO: Deleting device objects for CShutdownModule...
    INFO: Deleting device objects for CDisplaySettingsModule...
    INFO: Deleting device objects for CConfigureRelayPluginSettingsModule...
    INFO: Deleting device objects for CUserModule6...
    INFO: Deleting device objects for CNAVRouteTypeModule...
    INFO: Deleting device objects for CHDRadioModule...
    INFO: Deleting device objects for CiPodModule...
    INFO: Deleting device objects for CRipMediaMusicModule...
    INFO: Deleting device objects for CMusicSettingsModule...
    INFO: Deleting device objects for CShortcutsModule...
    INFO: Deleting device objects for CChooseRelaysSettingsModule...
    INFO: Deleting device objects for CBluetoothImportModule...
    INFO: Deleting device objects for CUserModule1...
    INFO: Deleting device objects for CNAVFindAddress...
    INFO: Deleting device objects for CVehicleModule...
    INFO: Deleting device objects for CDVDInfoModule...
    INFO: Deleting device objects for CVideoSettingsModule...
    INFO: Deleting device objects for CXMRadioSettingsModule...
    INFO: Deleting device objects for CVisualizationModule...
    INFO: Deleting device objects for CColorSettingsModule...
    INFO: Deleting device objects for CWMEqualizerModule...
    INFO: Deleting device objects for CBluetoothImportCSVModule...
    INFO: Deleting device objects for CUserModule0...
    INFO: Deleting device objects for CPackageListModule...
    INFO: Deleting device objects for CVehicleSettingsModule...
    INFO: Deleting device objects for CDVDSelectAudioStreamModule...
    INFO: Deleting device objects for CRadioSettingsModule...
    INFO: Deleting device objects for CSystemInformationModule...
    INFO: Deleting device objects for CKeyboardSettingsModule...
    INFO: Deleting device objects for CNetShareBrowserModule...
    INFO: Deleting device objects for CBluetoothVolumeModule...
    INFO: Deleting device objects for CUserModule3...
    INFO: Deleting device objects for {03531B5D-1128-46B1-B412-1B6679485D5D}\ProcessSatellites...
    INFO: Deleting device objects for CRipMediaVideosModule...
    INFO: Deleting device objects for CNAVFullScreenModule...
    INFO: Deleting device objects for CPicturesModule...
    INFO: Deleting device objects for CGirderPluginSettingsModule...
    INFO: Deleting device objects for CLCUserNameRenameModule...
    INFO: Deleting device objects for CAboutModule...
    INFO: Deleting device objects for CProcessShutdownModule...
    INFO: Deleting device objects for CSkinSettingsModule...
    INFO: Deleting device objects for CUserNameRenameModule...
    INFO: Deleting device objects for CFileSearchRenameModule...
    INFO: Deleting device objects for CBluetoothCallLogModule...
    INFO: Deleting device objects for CBluetoothMainModule...
    INFO: Deleting device objects for CUserModule2...
    INFO: Deleting device objects for CAddPackageModule...
    INFO: Deleting device objects for CNAVCustomPOIModule...
    INFO: Deleting device objects for CLaunchCastFilterStationsModule...
    INFO: Deleting device objects for CMusicAlbumStringColModule...
    INFO: Deleting device objects for CVoiceInputSettingsModule...
    INFO: Deleting device objects for CBluetoothEditPhoneBookEntryModule...
    INFO: Deleting device objects for CConfigureRearviewCameraSettingsModule...
    INFO: Deleting device objects for CGirderSettingsModule...
    INFO: Deleting device objects for CLaunchCastModule...
    INFO: Deleting device objects for CMusicNowPlayingModule...
    INFO: Deleting device objects for CMusicSearchModule...
    INFO: Deleting device objects for CMusicSearchResultsModule...
    INFO: Deleting device objects for CSetTimeSettingsModule...
    INFO: Deleting device objects for CStartupSettingsModule...
    INFO: Deleting device objects for CFileSearchResultsModule...
    INFO: Deleting device objects for CGestureSettingsModule...
    INFO: Deleting device objects for CEnhancedAudioModule...
    INFO: Deleting device objects for CBluetoothPhoneStatusModule...
    INFO: Deleting device objects for CBluetoothPairingModule...
    INFO: Deleting device objects for CWebServicesSettingsModule...
    INFO: Deleting device objects for CScriptListModule...
    INFO: Deleting device objects for CUpdateListModule...
    INFO: Deleting device objects for CNAVFindNearbyModule...
    INFO: Deleting device objects for CNAVStatusModule...
    INFO: Deleting device objects for CDVDOptionsModule...
    INFO: Deleting device objects for CLaunchCastSettingsModule...
    INFO: Deleting device objects for CInputOptionsSettingsModule...
    INFO: Deleting device objects for CMoveFileModule...
    INFO: Deleting device objects for CVehicleGraphOBDIIModule...
    INFO: Deleting device objects for CDVDSettingsModule...
    INFO: Deleting device objects for CMusicSongStringColModule...
    INFO: Deleting device objects for CMusicModule...
    INFO: Deleting device objects for CInputSettingsModule...
    INFO: Deleting device objects for CPasswordRenameModule...
    INFO: Deleting device objects for CConfigureRelaySetSettingsModule...
    INFO: Deleting device objects for CBluetoothActiveCallModule...
    INFO: Deleting device objects for CWSPasswordRenameModule...
    INFO: Deleting device objects for CNAVStartModule...
    INFO: Deleting device objects for CNAVFindLatLongModule...
    INFO: Deleting device objects for CNAVDirectionsModule...
    INFO: Deleting device objects for CXMRadioModule...
    INFO: Deleting device objects for CRipMediaSelectTypeModule...
    INFO: Deleting device objects for CRelaySettingsModule...
    INFO: Deleting device objects for CRelaySetSettingsModule...
    INFO: Deleting device objects for CGlyphSettingsModule...
    INFO: Deleting device objects for CAppSoundsModule...
    INFO: Deleting device objects for CBluetoothDialNumberModule...
    INFO: Deleting device objects for CRelayControlModule...
    INFO: Deleting device objects for CVideosModule...
    INFO: Deleting device objects for CSlideshowModule...
    INFO: Deleting device objects for CRipMediaPicturesModule...
    INFO: Deleting device objects for CXMRadioStationListModule...
    INFO: Deleting device objects for CXMRadioStatusModule...
    INFO: Deleting device objects for CLaunchCastStationGuideModule...
    INFO: Deleting device objects for CMusicStartModule...
    INFO: Deleting device objects for CMusicGenreStringColModule...
    INFO: Deleting device objects for CMusicArtistAlbumModule...
    INFO: Deleting device objects for CSimpleSettingsModule...
    INFO: Deleting device objects for CRelayRenameModule...
    INFO: Deleting device objects for CBluetoothOptionsModule...
    INFO: Deleting device objects for CUserModule9...
    INFO: Deleting device objects for CDVDManagerExtendedOverlay...
    INFO: Deleting device objects for CNAVScrollMapOverlay...
    INFO: Deleting device objects for CFullscreenTVOverlay...
    INFO: Deleting device objects for CFullscreenDVDOverlay...
    INFO: Deleting device objects for CFullscreenVideoStoppedInfoOverlay...
    INFO: Deleting device objects for CFullscreenVideoOverlay...
    INFO: Deleting device objects for CMuteOverlay...
    INFO: Deleting device objects for CUserOverlay3...
    INFO: Deleting device objects for CUserExtendedOverlay2...
    INFO: Deleting device objects for CTVManagerOverlay...
    INFO: Deleting device objects for FileOptionsOverlay...
    INFO: Deleting device objects for CKeyPadNumbersOverlay...
    INFO: Deleting device objects for CMultiMonEnabledOverlay...
    INFO: Deleting device objects for CComboSelectOverlay...
    INFO: Deleting device objects for CRearCameraPropOverlay...
    INFO: Deleting device objects for CFunctionNameOverlay...
    INFO: Deleting device objects for CUserExtendedOverlay5...
    INFO: Deleting device objects for CWebServicesOverlay...
    INFO: Deleting device objects for CDVDTray...
    INFO: Deleting device objects for CTVChannelChangeOverlay...
    INFO: Deleting device objects for CListSearchOverlay...
    INFO: Deleting device objects for CUserOverlay4...
    INFO: Deleting device objects for CiPodManagerExtendedOverlay...
    INFO: Deleting device objects for CNAVViewDirectionOverlay...
    INFO: Deleting device objects for CSafeModulesOverlay...
    INFO: Deleting device objects for CUserExtendedOverlay4...
    INFO: Deleting device objects for CFullscreenVideoInfoOverlay...
    INFO: Deleting device objects for CSlideshowOverlay...
    INFO: Deleting device objects for CMediaChangeOverlay...
    INFO: Deleting device objects for CVolumeOverlay...
    INFO: Deleting device objects for CUserOverlay5...
    INFO: Deleting device objects for CSatRadioTray...
    INFO: Deleting device objects for CXMRadioManagerOverlay...
    INFO: Deleting device objects for CNAVFullscreenOverlay...
    INFO: Deleting device objects for CBluetoothIncomingCallOverlay...
    INFO: Deleting device objects for CUserExtendedOverlay7...
    INFO: Deleting device objects for CRadioManagerExtendedOverlay...
    INFO: Deleting device objects for CUserOverlay6...
    INFO: Deleting device objects for CRadioManagerOverlay...
    INFO: Deleting device objects for CDVDManagerOverlay...
    INFO: Deleting device objects for CNAVClickedLocationOverlay...
    INFO: Deleting device objects for CLaunchCastLoadedOverlay...
    INFO: Deleting device objects for CUserExtendedOverlay6...
    INFO: Deleting device objects for CMediaTimeOverlay...
    INFO: Deleting device objects for CVideoTray...
    INFO: Deleting device objects for CTVTray...
    INFO: Deleting device objects for CRadioTray...
    INFO: Deleting device objects for CLaunchCastTray...
    INFO: Deleting device objects for CNAVGPSTrackingOverlay...
    INFO: Deleting device objects for CNAVViewFullscreenOverlay...
    INFO: Deleting device objects for CVisTitleOverlay...
    INFO: Deleting device objects for CGestureModule...
    INFO: Deleting device objects for CBluetoothVoiceRecognitionOverlay...
    INFO: Deleting device objects for CUserOverlay7...
    INFO: Deleting device objects for CMusicTray...
    INFO: Deleting device objects for CiPodMusicTray...
    INFO: Deleting device objects for CBluetoothConnectedOverlay...
    INFO: Deleting device objects for CUserExtendedOverlay9...
    INFO: Deleting device objects for CNetworkCommOverlay...
    INFO: Deleting device objects for CAlwaysVisibleOverlay...
    INFO: Deleting device objects for CUserExtendedOverlay1...
    INFO: Deleting device objects for CUserOverlay0...
    INFO: Deleting device objects for CAudioFileManagerExtendedOverlay...
    INFO: Deleting device objects for CVideoFileManagerOverlay...
    INFO: Deleting device objects for CLaunchCastManagerExtendedOverlay...
    INFO: Deleting device objects for CLaunchCastManagerOverlay...
    INFO: Deleting device objects for CTVPropOverlay...
    INFO: Deleting device objects for CHDRadioKeypadOverlay...
    INFO: Deleting device objects for CUserExtendedOverlay8...
    INFO: Deleting device objects for CUserOverlay8...
    INFO: Deleting device objects for CVideoFileManagerExtendedOverlay...
    INFO: Deleting device objects for CNAVCurrentDirectionOverlay...
    INFO: Deleting device objects for CNAVViewListOverlay...
    INFO: Deleting device objects for CVoiceInputModule...
    INFO: Deleting device objects for CBluetoothActiveCallOverlay...
    INFO: Deleting device objects for CUserOverlay1...
    INFO: Deleting device objects for CUserExtendedOverlay0...
    INFO: Deleting device objects for CMediaPlaySpeedOverlay...
    INFO: Deleting device objects for CKeyPadLettersOverlay...
    INFO: Deleting device objects for CNAVViewStatusOverlay...
    INFO: Deleting device objects for CRearviewCameraOverlay...
    INFO: Deleting device objects for CFullscreenVideoResumeInfoOverlay...
    INFO: Deleting device objects for CRipMediaOverlay...
    INFO: Deleting device objects for CUserOverlay9...
    INFO: Deleting device objects for CTVManagerExtendedOverlay...
    INFO: Deleting device objects for CNAVVirtualEarthOverlay...
    INFO: Deleting device objects for CGirderModule...
    INFO: Deleting device objects for CMusicLoadedOverlay...
    INFO: Deleting device objects for CUserExtendedOverlay3...
    INFO: Deleting device objects for CUserOverlay2...
    INFO: Deleting device objects for CKeyPadWebOverlay...
    INFO: Deleting device objects for CAudioFileManagerOverlay...
    INFO: Deleting device objects for CXMRadioManagerExtendedOverlay...
    INFO: Deleting device objects for CiPodManagerOverlay...
    INFO: Deleting device objects for CVisAlbumArtOverlay...
    INFO: Deleting device objects for CRelayModule...
    INFO: Deleting device objects for CKeyPadAlwaysVisibleOverlay...
    INFO: Deleting device objects for CDVDManager...
    INFO: Deleting device objects for CiPodManager...
    INFO: CMediaManager::Unload
    INFO: Deleting device objects for CLaunchCastManager...
    INFO: Deleting device objects for CXMRadioManager...
    INFO: Deleting device objects for CRadioManager...
    INFO: Deleting device objects for CTVManager...
    INFO: Deleting device objects for CVideoFileManager...
    INFO: Deleting device objects for CAudioFileManager...
    INFO: Deleting device objects for GPS status...
    INFO: CScriptProject::CleanUp - CleanUp scripted module {03531B5D-1128-46B1-B412-1B6679485D5D}\ProcessSatellites...
    INFO: Deleting device objects for Weather...
    INFO: CScriptProject::CleanUp - CleanUp scripted module {1FB0936A-FD23-4A41-86E3-61C3F3977B0F}\main...
    INFO: CUVAppData::OnDeleteDeviceObjects - Deleting navigation objects...
    INFO: CNAVController::~CNAVController - Deleting Navigation object
    INFO: CNAVController::~CNAVController - Navigation components unloaded.
    INFO: CDrawWnd::Cleanup3Denvironment - Cleanup complete
    Here is another log file that I found that maybe relevant...
    Log Started: Feb 26, 2008 - 12:26
    CELM323::SendATCommand - Timeout while waiting for AT command return value!
    CELM323::Reset Failed to reset ELM device!
    is back. FKA Robert Wray
    Fiberoptic's Avatar
    Jul 1978
    Baltimore, MD
    Blog Entries
    143
    Are you sure you are connecting to the right com port? Does this match the com port you are using in your elm scan software?
    Lok
    Lok is offline
    VENDOR - Portal Media Lok's Avatar
    Feb 2008
    Yes it is the same com port #7.
    Dec 2004
    Miami, FL
    I'm in the same boat, any progress?
    Would it help if I also put up my log?
    Lok
    Lok is offline
    Feb 2008
    As there been any progress???? I know my system specs were not up to par however I have upgraded them and I still have the same issue. It has been nearly a month since I have bought this unit with no luck. I know you would like us to rely on forums to solve our issues but it seems like this process is just taking way too long. Please respond so I (and now it seems like maxxell also) knows what you guys are working on exactly. So far all you have asked me to do is check the com port, which a 5 year old probably knows to check. My point is please show me that you are doing something to solve this because at the rate we are going I don't think this will be solved until next year.
    Dec 2004
    Miami, FL
    To be fair, my 5 year old doesn't know what a com port is. But yes, I too am eagerly watching this page waiting for a resolution.
    Mar 2007
    Check the BAUD rate on com #7. On my one from OBDPRO's, it only works if the BAUD rate is 9600. You can configure the BAUD rate by going to your Device manager and playing around with COM #7.
    Try that and report back with your findings.
    Dec 2004
    Miami, FL
    Glad somebody has looked into it. However, to no avail, unfortunately. When I load up Scantool (as recommended for download by mp3car staff), it works whether I SET the baud to 9600 or 38400 (or similar). Those are my only options within scantool. However, neither of those settings works with streetdeck when set in control panel. In fact, 9600 was the default. I tried the 38k baud to see whether it made any difference, and no it doesnt.
    I di note that when scantool had a different entry than control panel, it didn't work. They just had to agree, regardless of the entry. Anyone know Streetdeck's default baud rate/
    Lok
    Lok is offline
    Feb 2008
    Hey guys I got an email back from mp3car like follows:
    Alok,
    According to our records you are using a non-supported hardware
    configuration. It is unfortunate you have decided to criticize us when we are
    trying to help support you on hardware that is not designed for
    StreetDeck.
    "I have a 600MHz ULV embedded processor, 2 GB ram, 128 MB Onboard
    Video, USB 2.0, 40 GB HD, etc. Custom made computer"
    We are doing our best to solve this even though this is outside the
    range of what we support. There are hundreds of people successfully using
    the elmscan products.
    Perhaps you should try them elmscan on a laptop or other supported
    hardware as a troubleshooting step. Run StreetDeck in demo mode and try
    the proper com port.
    Please report your findings in the post i mentioned before
    http://www.mp3car.com/vbulletin/tracker.php?itemid=76
    To which I replied:
    Date:
    Mon, 3 Mar 2008 09:19:02 -0800 (PST)
    Subject: RE: [Ticket#439-6938] Technical Support - 27012 - ElmScan 5 USB OBD-II Scan Tool
    To: sales@mp3car.com
    According to my records I sent you an email on March 3rd (2 weeks ago) stating that the issue persists even though I upgraded my system (look above). Just for your info my system is now a Dual Core 2 Ghz with 2 GB of Ram and the issue persists. You may want to check your record keeping before you start pointing fingers. Also how do you explain all the other guys that are having issues? You cannot say a product is working when there are intermittent results! Stop wasting time and solve the problem!
    Alok
    You other guys on the forum, do you think I have a right to criticize them? Especially after the way they are treating me
    Lok
    Lok is offline
    Feb 2008
    "It is unfortunate you have decided to criticize us when we are
    StreetDeck. " - Mp3Car Staff
    Please show me how you have helped me solve this problem in any way. Don't point fingers without having your facts straight.
  1. Replies: 7
    Last Post: 11-25-2007, 07:58 AM
  2. Module Dependency Tree (StreetDeck)
    By debugger in forum DigitalMods (Scripts / API)
    Last Post: 03-31-2007, 11:56 AM
  3. How to poop at work...
    By BoyNextDoor in forum Off Topic
    Last Post: 05-02-2006, 01:11 AM
  4. Frodo: Work Harder, Work Faster..
    By hevnsnt in forum FrodoPlayer
    Last Post: 09-24-2004, 04:09 PM
  5. Replies: 4
    Last Post: 11-18-2002, 09:59 PM
