of course there is gonna be a differance between $2 and $20 cable but when you start spending ridiculous amounts of money like on monster cable you are wasting your time, its not the the quality of the cable isnt better, its that the differance it makes is negligable, its a far better idea to buy reasonable cables and use the money you save to get better amps or components or whatever
LinkBack URL
About LinkBacks
) substitute for the alpine pxa 700? I have heard pioneer also has some good dsp processors but are a lot less reviewed in the internet...
" - I have yet to see someone prove to me that using ludicrously expensive cables with gold plated tips and massive conductors for line level signals improves the transmission of audio signals to any reasonable degree. Good shielding IS important at line levels, but i have yet to hear the difference between a $120 sheilded monster cable and a $20 "standard" cable on the same setup, and i have also never seen a difference when i've put a scope on the cables (under 500khz mind you, but everything above that is going to be filtered in the
