Page 37 of 50 FirstFirst ... 272829303132333435363738394041424344454647 ... LastLast
Results 361 to 370 of 493
Thread: can a carputer compete with a head unit for sound quality?
  1. #361
    Newbie paco cj's Avatar
    Mar 2006
    Mexico
    PC is above HU
    THE FACT IS THATH A CARPC IS ABOVE HU BECOUSE YOU CAN PLAY A LOT OF MEDIA TYPES (im talking about better quality media) LIKE DVD HI DEFINITION MEDIA AND THINGS LIKE THAT AND IS UPGRADABL WITH A SIMPLY SOFTWARE UPDATE
  2. #362
    _
    Mar 2004
    Little Elm, Texas
    HOLY ****!
    REALLY?
    WOW!
    I DID NOT KNOW THAT!
    HOLY HELL THIS THREAD IS OLD!
    hehehehe
    Jan Bennett
  3. #363
    Maximum Bitrate 3onDubs's Avatar
    Aug 2005
    Anaheim Hills, Ca
    Differnet media types?
    And all this time i've been listening to .wav files!
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
  4. #364
    Low Bitrate Ub312g0d's Avatar
    Feb 2006
    Toronto Ontario
    The biggest difference that your going to see between a Soundcard in a carpc and a HeadUnit is the DAC's, and the opamps. These are some of the easiest things to cheap out on yet can make huge differences in the resulting sound. Im suprised that while I havent personally ever been to a SQ competition that everybody isn't running a carpc with at least an Emu based card. Even more surprising is the lack of dedicated DAC's. You could get untouchable sound with a soundcard with optical out and dedicated 5.1 dac for less then the high end decks I see people using.
  5. #365
    _
    Mar 2004
    Little Elm, Texas
    have you read the entire thread Ub312g0d?
    Jan Bennett
  6. #366
    Feb 2006
    Toronto Ontario
    most of it. whats wrong with the post. a high-quality DAC should be had.
  7. #367
    _
    Mar 2004
    Little Elm, Texas
    it's just pretty rehtorical that's all...
    not to mention, I'm already running what you're saying should be run (check my sig) as are an *** load of people on here.
    Read around on some of the threads some, you'll see that there are quite a few people (including myself) who are on the hunt for new options....since currently the 701 is the only viable option.
    Jan Bennett
  8. #368
    Oct 2005
    Hou. TX
    Quote Originally Posted by paco cj
    I'm not even sure that "DVD HI DEFINITION MEDIA" is a higher quality source than the typical CD.
  9. #369
    Feb 2006
    Toronto Ontario
    After looking at the 701 it does seem to be the only viable option for 5.1 digital. But what about something like the Bel Canto DAC-2. It was designed for home audio and only gives out 2ch audio but I hear lots of people are ony running 2 ch audio anyway. Would probably have to be run off an inverter which would need the power to be smoothed out a little bit first to get its full potential but would blow everything out of the water without going into the absolutely ridulous price range. If you want an eq as well a high quality eq could be paired with it.
  10. #370
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    hey ub312g0d...you should get involved with this thread... maybe you can bring something to the table-
    1/3 Octave Software EQ
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  1. Replies: 15
    Last Post: 02-14-2006, 11:50 PM
  2. Alternate locations for head unit?
    By Raekwon in forum General MP3Car Discussion
    Last Post: 04-09-2003, 03:02 PM
  3. Replies: 0
    Last Post: 01-06-2003, 01:35 AM
  4. Slot load dvd in a head unit
    By mp3truckstereo in forum General Hardware Discussion
    Last Post: 09-01-2002, 10:17 PM
  5. Anyone using an FM tuner on their carputer instead of a head unit?
    By Szech in forum General Hardware Discussion
    Last Post: 02-14-2001, 02:07 PM
