Im not going for 5.1 sound.
As long as I get sound from my fronts and sub I will be happy enough
I am making sure that the Alpine will work 100% beforeIbut it as it would be a huge waste ofmoney if it was not going to work.
I think all 3 of the Alpine models I mentioned will accept the 5.1 SPDIF signal. You'll need to make sure your DVD software outputs the proper signal. Keep in mind that 5.1 in the car isn't really recommended. It can be hard to mount a proper center speaker and the small screen with big sound can be kinda wierd to watch, but yea. Some people do that. There are several threads on that if you search. I think we talked about it earlier in this thread as well.Originally Posted by AndrewK
Here's another thread on it.
Full Surround Sound
1999 Black Pontiac Trans Am
CarPC's in F-bodies
How To Relocate Climate Controls on the 97-02 F-body Cars
(AMD Sempron 3000+, Opus 150)
Car PC system is out, Alpine system is in.
So are you going for stereo sound?Originally Posted by AndrewK
That's what most of us in this thread use.
So I think you are asking if a 5.1 DVD will be downmixed to 2 channel? I think this has been talked about before. I can't remember, but I think the DVD software can be set to output 2 channel sound. For instance, if you use PowerDVD as your program, I think it can mix the 5.1 down to stereo and output it through the SPDIF. If you have the option, it's best to select the DVD's stereo soundtrack. I really haven't tried to play any DVD's yet on my system. I'm sure somebody knows. There may be some threads on that.
CarPC's in F-bodies
Yes, the Alpine will work 100%...there's proof all over this forum if you search. I not only get sound from my fronts and subs, i get undistorted, noise-free, digital sound.Originally Posted by AndrewK
PostCount++
- SrCsTc's Bezel
- Alpine W200/H701
- ED Nine.2X
- OZ Matrix Elites
- ED Nine.1
- Idmax 12's
I'm hoping you can answer that. I'd really like to know.Originally Posted by JasonWW
I re-adjusted my signal levels. I basically ended up increasing the amp gains a little and leaving the Alpine controller at 30. The noise floor is noticable at lower PC volumes, but no so much when the engine is on. I now have some extra volume if I need it by turning the Alpine controller up to 35. Changing the PC volume didn't seem to have any effect of the noise floor. I may try a different sound card later on and compare.
Anyway, I promised someone a few months ago I'd have some pics of my H700 controller and here they finally are. The H700 is green and orange. The 6 green chicklets buttons on the left are actually bulbs not LED's and have green gelcaps over them. I think they would be easy to change color.
I'm still trying to find a way to change the volume with a button. Anyone know about these rotary encoder things Alpine used?
CarPC's in F-bodies
I hope this isn't too old a thread to resurrect, but I've had an idea while reading it (took me three days). OK, here we go... (Forgive me if I ramble a bit, I've had chronic insomnia for three days now). At some point Toslink was brought up, which from what I understand is an optical output (Digital). Digital/Analogue Converters (DAC?) were also brought into the equation as well.
The fundamental problem with using the souncard of a PC as a H701 replacement, as far as I can tell, comes down to 2 things:
A. Software (which should be relatively easy for someone with the right programming skills to remedy, I think). and
B. A serious lack of RCA outputs for a competition system (I worked out I need a bare minimum of 5 stereo channels, 6 would be better, and an extra mono above that even better still - thats between 10 and 13 RCA plugs).
1st question: Can one of those Digital/Analogue Converters (DAC?) provide multiple RCA Analogue outputs from a single Toslink input?
2nd question: If so, is there a limit on how many Analogue channels per Toslink cable?
In other words, is it possible (theoretically at least) to run all of your digital processing, EQing, X/O control, Volume adjustment, control for individual speakers, and anything else you happen to need through the PC, then run the output out via a clean digital signal through the Toslink to a (DAC?), which then splits the signal into its respective Analogue RCA outputs, and to run them into your existing amplifiers?
If the (DAC?) can't split the signal that way, what about amps with digital input? Could the digital signal be split into multiple channels in digital?
I'll stop now to see what feedback I can get from everyone here, and keep going once I see what you say about it.
Thanks for reading![]()
Oh yeah, if this works...![]()
Let's see how much a carPC can REALLY do...
This thread is never too old!Originally Posted by Aetherion
I do not know the answer to this just yet, but it's a damn good question. Going to do some searching to see if I can find anything.The fundamental problem with using the souncard of a PC as a H701 replacement, as far as I can tell, comes down to 2 things:
I do know that many times EQs that have optical ins can spit out multiple Analog RCA outs, so I don't see why not, but for it to be done on a DAC its self...I dono
Jan Bennett
why would you need 5-6 stereo chans for a cometition system? even if you tri-amp your speakers (one amp for tweet, another for mid, and another for mid bass) and then you have mono for the sub, why would you need more then that for a 'competition' system? You don't see many systems with rear speakers.Originally Posted by Aetherion
i believe so, you would have to look outside of the car audio or home audio market though. you are looking into professional audio rack type components. most usb dac's only have a single set of rca's and will require some sort of active crossoverOriginally Posted by Aetherion
i'm confused. toslink is digital it'll give a full range of the signal and then it is then up to the processor to split it up into it's respective chans.Originally Posted by Aetherion
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
My Boat Pc worklog
I guess I missed the competition system part of his/her install?Originally Posted by scott_fx
I read this as, how many times can you split the signal. Not can i send X frequencies here and Y here.i'm confused. toslink is digital it'll give a full range of the signal and then it is then up to the processor to split it up into it's respective chans.
Jan Bennett
1 or 2 stereo channels for tweets (I may decide to go with 4 tweeters, not sure), 1 for midrange, 1 for midbass, 1 for subs (stereo so I can control both subs individually), plus a mono for centre. Then another stereo for the rears if I put them in, and also the option of adding extra midrange or midbass. You can never have too many outputs...Originally Posted by scott_fx
Ok, so you would need to make a little mini processor to split the digital signal into all the Analogue channels, if the DCA won't do it. That answers that question for me. (And if I'm confusing, put it down to almost no sleep in three days...)Originally Posted by scott_fx
