Page 5 of 50 FirstFirst 123456789101112131415 ... LastLast
Results 41 to 50 of 493
Thread: can a carputer compete with a head unit for sound quality?
  1. #41
    Low Bitrate Blackrazor's Avatar
    Mar 2005
    Nelson, New Zealand
    Quote Originally Posted by edscholl
    that is absolutely NOT the point if you're into SQ! SQ, from a purely technical perspective, is ALL about accurately reproducing the sound of your source.
    No its not. SQ, from a purely technical perspective, is about creating a sound that is ambient, defined, lively, and that people enjoy as much as possible. You can have the worlds most accurate reproduction, and still have it sound nasty...
    Trying to recreate exactly the sound of 'the source' is an impossible goal, as the guys on the mixing desks and pre/post edit stages at recording studios have already tinkered to their hearts content anyway... whats on the CD is not 'the source', but the editors rendition of what the source SHOULD sound like
    If music was all about accuracy only, then noone would use tube amps, and we would have abandoned cone drivers long ago and worked on ways to fit electrostatic drivers in-car
  2. #42
    Mar 2005
    kansas
    I would have to say a carpc is way better than a typical or even high end HU. I mean think about all the ways that with the proper card and software you can fine tune your sound. Each vehicle is different and the acoustics are different for each vehicle and system. With a carpc you should be able to really fine tune the its acoustics to fit your car and system.
    just my 2 cents
  3. #43
    Mar 2005
    to the question a most definete yes... its good to see so many other people thinking outside the box so to speak and not being ruled by the.."you need a hu for sq"
    http://www.audio-one.co.uk/gallery/d...n&cat=0&pos=14
  4. #44
    Mar 2005
    the answer to the question.. a resounding.. yes, its good to see so many other people thinking outside the box.
    and not being ruled by the usual "you need a headunit for soundquality", "you cant get good sound quality from a computer"( my pet hate)
  5. #45
    Oct 2004
    what about the fact that most soundcards output around 1-2mv and a head unit outputs 5mv. considering most car amps are made for car headunits, is sound quality from the pc source worst because it is amplified wiht a 5mv signal ?
  6. #46
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    Quote Originally Posted by Gavc
    if you look at the signal noise to ratio of good soundcards it can be better than good headunits, so even if you have to amplify the signal more you can still end up with better sound, the only downside is that in lower voltage signals theres a higher tendancy to get more noise induced by the cables.
    Also i have no idea where you got 5mv and 1-2mv values from because they are terribly incorrect, try removing the m to get a closer value
    Signature: [==||========] 20% complete
  7. #47
    _
    Mar 2004
    Little Elm, Texas
    on the onboard sound on the M10000, it's something like .5v
    most headunits are in the 2-5v range
    Jan Bennett
  8. #48
    Mar 2001
    I just thought i would throw in another bone to this discussion.
    In the Home Audio world, there is something known as DRC.
    (Digital Room Correction) This means you use your PC to realtime
    correct for imperfections in the reproduction of the Source material.
    It can be used to optimize the sound for a particular listening position
    to make it very close to perfect....
    And as far as whether or not sound reproduction is supposed
    to enhance or just perfectly reproduce a source....that is a
    whole different philosophical discussion.
  9. #49
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Quote Originally Posted by plaiming2
    have a look at the alpine unit red is running if you are into that stuff, its nuts
  10. #50
    _
    Mar 2004
    Little Elm, Texas
    heh - yeah - it does all that time correction, and more....and it's tiny when you get down to it....
    Jan Bennett
  1. Replies: 15
    Last Post: 02-15-2006, 12:50 AM
  2. Alternate locations for head unit?
    By Raekwon in forum General MP3Car Discussion
    Last Post: 04-09-2003, 04:02 PM
  3. Replies: 0
    Last Post: 01-06-2003, 02:35 AM
  4. Slot load dvd in a head unit
    By mp3truckstereo in forum General Hardware Discussion
    Last Post: 09-01-2002, 11:17 PM
  5. Anyone using an FM tuner on their carputer instead of a head unit?
    By Szech in forum General Hardware Discussion
    Last Post: 02-14-2001, 03:07 PM
