Page 16 of 47 FirstFirst ... 67891011121314151617181920212223242526 ... LastLast
Results 151 to 160 of 462
Thread: Alpine PXA-H701 Questions
  1. #151
    Oct 2005
    Hou. TX
    Quote Originally Posted by ready2play View Post
    So I can get the CDA-9885 and the PXA-H701, and I'm golden, with red buttons and all, right
    Not the 9885, the 9857.
    1999 Black Pontiac Trans Am
    CarPC's in F-bodies
    How To Relocate Climate Controls on the 97-02 F-body Cars
    (AMD Sempron 3000+, Opus 150)
    Car PC system is out, Alpine system is in.
  2. #152
    Oct 2005
    Hou. TX
    Now I'm confused...cause I'll be running a full carpc.....back to square one :sigh:
    With the carPC you'll have to control it through the faceplate sized controller. No way around that. Certain HU's have the controller circuitry built in, but are kind of a waste if you have the carPC.
    CarPC's in F-bodies
  3. #153
    Jan 2007
    But you posted the info from the 9885 saying it could be adjusted to red???
    "Never let a Dream Remain a Dream"
    CARDOMAIN
    Myspace
  4. #154
    Apr 2005
    Queens, New York
    Quote Originally Posted by JasonWW View Post
    Special AI-net connector.
    Do you mean audio from the PC to the HU? You can run an analog line out from the PC to the HU's aux input, but the SQ goes down. Most folks that run a PC don't run a HU and vice versa.
    well basically I want to have a HU and the PC.. I want the HU to control just the volume of the PC.I want to be able to switch from HU to PC. Is that possible.
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
  5. #155
    Jan 2007
    Ok....then back to square one, lol.
    CARDOMAIN
    Myspace
  6. #156
    Jan 2007
    Jason...I owe you a cookie for all this man, lol. I know you have to be getting frustrated, lmao
    CARDOMAIN
    Myspace
  7. #157
    Oct 2005
    Hou. TX
    Sorry if that was confusing. I think I clicked on the wrong user manual.
    CarPC's in F-bodies
  8. #158
    Oct 2005
    Hou. TX
    Quote Originally Posted by Cheekz185 View Post
    well basically I want to have a HU and the PC.. I want the HU to control just the volume of the PC. I want to be able to switch from HU to PC. Is that possible.
    Yes, but I don't think there is a way to digitally have the HU accept audio from the PC. Maybe the new ones can, I don't know. I do know that the HU's almost always have an aux stereo input so you can run a cable (probably a double ended headphone jack) form the sound card out to the HU aux in. The HU and H701 brain would work like Alpine intended and to get the PC sound you would select the aux input on the HU. You know, go from CD to radio to input 1 or whatever and BAM, music. I think Alpine also lets you set the volume level for each source so it will match up when you switch over. So you'd set you PC volume to max (as long as it doesn't clip) and leave it there.
    If you run a good sound card the sound quality will be good, although not quite as good as the digital signal. There is a PCI sound card for about $25 that has excellent SQ. I can tell you all about it if you want.
    Does that sound like what you want?
    CarPC's in F-bodies
  9. #159
    Apr 2005
    Queens, New York
    Well i was thinkg about getting the Auzentech x-Meridian Sound Card and connect the sound card to the h701 via Optical. But i guess that wont work rite! I have to go from the sound card to the AUX on the HU
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
  10. #160
    Oct 2005
    Hou. TX
    ready2play, I'm giving up on the red h700 hunt. I can't find anything. The buttons can be done, no problem, but the display is harder. I don't know what is creating the blue color. If it's a film in the display then it can be changed, if it's a blue back light, then that can be changed, but if it's a blue LCD of some kind, then your stuck with that.
    If it's any consolation, it's not really a blue screen. It's more a white with some blue mixed in. You can also change the contrast on it and I think that can make it more white. I'll have to get back to you on that.
    CarPC's in F-bodies
  1. Replies: 85
    Last Post: 07-09-2007, 05:44 AM
  2. alpine skin questions
    By hakhawk in forum RR Skins
    Last Post: 07-04-2005, 06:48 PM
  3. MP3 --> ALPINE head unit questions
    By WozzaWozza in forum Car Audio
    Last Post: 06-09-2005, 11:46 AM
  4. FS: Alpine Amps, Subs, 6.5" Monitors
    By coachreed in forum Classified Archive
    Last Post: 04-03-2005, 02:13 PM
  5. Alpine / PC Challenges all around...
    By acitrano in forum General Hardware Discussion
    Last Post: 11-10-2000, 08:45 AM
