Page 18 of 47 FirstFirst ... 8910111213141516171819202122232425262728 ... LastLast
Results 171 to 180 of 462
Thread: Alpine PXA-H701 Questions
  1. #171
    Oct 2004
    NY
    alright, the way I switch from the carpc to the headunit is simple... the head unit connects through ai-net, not optical....
    when the 700 see's a light on the toslink, it automatically switches to it...
    I had a switch rigged to the usb soundcard(a turtle beach roadie)... when it was turned on, the sound was the pc, when off it would switch back to the ai-net input automatically... as soon as the light goes out on the fiber optic it switches back...
    once in a great while it would not switch when the toslink went out, I then had to switch sources & it switches right away...
    I have 5 different sources to select from, the pc is just one of them.... switching is easy & no problem....
  2. #172
    Oct 2005
    Hou. TX
    Quote Originally Posted by ready2play View Post
    You wouldn't happen to know how to do this would you?
    A big magnifying glass, a micro soldering tip and very steady hands.
    Look at my raw pics from post 61. Check out how tiny they are.
    1999 Black Pontiac Trans Am
    CarPC's in F-bodies
    How To Relocate Climate Controls on the 97-02 F-body Cars
    (AMD Sempron 3000+, Opus 150)
    Car PC system is out, Alpine system is in.
  3. #173
    Oct 2004
    NY
    I guess a clear celophane may do the trick if it stays bright enough after being covered with it...... these displays are pretty bright so it may not be so bad.... only one way to find out
  4. #174
    Apr 2005
    Queens, New York
    Quote Originally Posted by turbocad6 View Post
    Well um what if i have a PCI soundcard lol!
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
  5. #175
    Oct 2005
    Hou. TX
    Quote Originally Posted by Cheekz185 View Post
    The PCI sound card should have an optical output to the H700 brain. The Optical version of the SPDIF signal is called a Toslink connection. Fiber optic, optical, all the same.
    CarPC's in F-bodies
  6. #176
    Jan 2007
    Well, I have steady hands...I used to do body piercings. But doing that over here in the sand wouldn't be a safe bet, lol.
    "Never let a Dream Remain a Dream"
    CARDOMAIN
    Myspace
  7. #177
    Oct 2004
    NY
    all you have to do is break the lightbeam in the fiberoptic link.... the souncard doesn't have to go on & off...
    there are even switches for fiber optic... if switched from a-b, & b has nothing... then it's off...
    I designed a gate that turned it on & off like a relay, but haven't built it yet...
    basicly the light beam has to be broken...
  8. #178
    Oct 2005
    Hou. TX
    CarPC's in F-bodies
  9. #179
    Oct 2004
    NY
    if your head also has a fiber optic out then you could use it too & just switch back & forth... there are switches for this, but there huge.... I also built one that was tiny & again worked kinda like a relay... if anyone needs these designs or wants to build something like this for there car let me know..
  10. #180
    Oct 2004
    NY
    yeah, bro, those dial switches ar monsterous... the problem is any light from the adjacent signal would be a bad thing, but there are much better & more compact ways of doing this than what I've seen....
  1. Replies: 85
    Last Post: 07-09-2007, 04:44 AM
  2. alpine skin questions
    By hakhawk in forum RR Skins
    Last Post: 07-04-2005, 05:48 PM
  3. MP3 --> ALPINE head unit questions
    By WozzaWozza in forum Car Audio
    Last Post: 06-09-2005, 10:46 AM
  4. FS: Alpine Amps, Subs, 6.5" Monitors
    By coachreed in forum Classified Archive
    Last Post: 04-03-2005, 01:13 PM
  5. Alpine / PC Challenges all around...
    By acitrano in forum General Hardware Discussion
    Last Post: 11-10-2000, 07:45 AM
