Page 19 of 47 FirstFirst ... 91011121314151617181920212223242526272829 ... LastLast
Results 181 to 190 of 462
Thread: Alpine PXA-H701 Questions
  1. #181
    Apr 2005
    Queens, New York
    Quote Originally Posted by turbocad6 View Post
    all you have to do is break the lightbeam in the fiberoptic link.... the souncard doesn't have to go on & off...
    I designed a gate that turned it on & off like a relay, but haven't built it yet...
    basicly the light beam has to be broken...
    Cna u elaborate on that? And the fiberoptic switches can you send me a link to one?
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
  2. #182
    Apr 2005
    Queens, New York
    What would be the best way to go abouts to switch the toslink?
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
  3. #183
    Oct 2004
    NY
    it's simple.... the toslink is really just a fiber optic cable... it transmits the signal through light down the cable.... if you took the cable & sliced it real straight with a razor, & then kept the two ends aimed at each other, it would transmit the signal exactly the same.... this is how connectors work...
    if you put the razor blade into your cut, the sound will be blocked(well, the digital signal that's being transmited as light will be blocked)
    there are splitters that can be used to build a switcher if your creative......
    I can give sketch diagram if you want...
  4. #184
    Apr 2005
    Queens, New York
    Absolutely.... On a scale of 1-10 how difficult is it to build this switcher?
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
  5. #185
    Oct 2005
    Hou. TX
    For anyone interested, it looks like the 2 cheapest Alpine HU's that can control the H700/1 do not turn red. The 9885 I looked at does, but it doesn't control the H700/1. Sorry about that confusion. I think Pete was the only one looking for red, right?
    The I-pod controller looking one still might do that, but we don't know right now. BTW, most of the Alpine HU's control the I-pod, it's just that one model looks and act's more like an I-pod and is missing the CD mechanism.
    1999 Black Pontiac Trans Am
    CarPC's in F-bodies
    How To Relocate Climate Controls on the 97-02 F-body Cars
    (AMD Sempron 3000+, Opus 150)
    Car PC system is out, Alpine system is in.
  6. #186
    Oct 2004
    NY
    alright... I had a mockup I did in a cad program but don't have it now, I'll draw a sketch... it can be as easy or as hard to build as you want it to be, how much space do you have to work with? I always wanted it to be as compact as possible...
  7. #187
    Apr 2005
    Queens, New York
    Lol i dont have much space...how big are we talking?
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
  8. #188
    Jan 2007
    Yeah...I think I was the only one looking for red
    "Never let a Dream Remain a Dream"
    CARDOMAIN
    Myspace
  9. #189
    Oct 2004
    NY
    those knobs are pretty big, depending on how you construct it it can be as small as the size of a pack of cigarettes really... it could be cable actuated or a small actuator like a door lock actuator...I designed the one I was going to do with a tiny RC car motor, spun one way for a split second & threw the gate... b was reversed... it was latched to each side with a magnet, could also be done with an interference notch & ball.... there are so many different ways to make something like this... technically if you made it out of cardboard it would work, the rest is up to you & how much effort you want to put into it, it could be a pain to do also.. might be easier to find something to start with, like maybe a small plastic drawer & just cut a few holes.... it could be simple too...
  10. #190
    Apr 2005
    Queens, New York
    Is there anyway to make the switch withought having to connect a power source?
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
  1. Replies: 85
    Last Post: 07-09-2007, 05:44 AM
  2. alpine skin questions
    By hakhawk in forum RR Skins
    Last Post: 07-04-2005, 06:48 PM
  3. MP3 --> ALPINE head unit questions
    By WozzaWozza in forum Car Audio
    Last Post: 06-09-2005, 11:46 AM
  4. FS: Alpine Amps, Subs, 6.5" Monitors
    By coachreed in forum Classified Archive
    Last Post: 04-03-2005, 02:13 PM
  5. Alpine / PC Challenges all around...
    By acitrano in forum General Hardware Discussion
    Last Post: 11-10-2000, 08:45 AM
