Page 2 of 47 FirstFirst 123456789101112 ... LastLast
Results 11 to 20 of 461
Thread: Alpine PXA-H701 Questions
  1. #11
    Low Bitrate unixxx's Avatar
    Sep 2005
    CA, USA
    Question
    Well, I bought the PXA-H701 and the RUX-C701, but didn't get the power cable, display -> DSP cable, nor the microphone. I'm just going to order the power and display cables from www.pacparts.com The question is what sort of microphone do I need for the speaker calibration. The official replacement one that pacparts is selling is $52.77. Would any standard PC microphone work or do I need to have this specific one. The DSP has the same mini jack on it that standard PC microphones use.
    # cd /home/fuzzymuzzle.com
    Intel Pentium M Dothan 750 1.8GHz 533MHz 2MB
    iBase MB896F w/ Intel 915GM
    [■■■■■■■■■■■■■■■■■■■■] 50% Done
    (Writing Front/Back End, Designing Electronics, and Completing Install)
  2. #12
    Maximum Bitrate 3onDubs's Avatar
    Aug 2005
    Anaheim Hills, Ca
    I'll go home and look at the microphone when I get off work, but from what I can remember, it looked like a pretty standard miniature microphone (like the ones that come with cell phones, but without the ear part). The only other thing that it had was a little clip so that it could clip to the headrest. Its not totally necessary to use though...i managed to adjust mine manually
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
  3. #13
    _
    Mar 2004
    Little Elm, Texas
    it's easy for someone who knows a bit about what they are doing to adjust, but if you are really green...it might be intimidating, thus the mic gets you going making things a bit easier for you
    Jan Bennett
  4. #14
    Oct 2004
    NY
    the mic is almost useless....... I through mine out
  5. #15
    _
    Mar 2004
    Little Elm, Texas
    unixx - do you have any tuning experience at all?
    if so, don't worry about it
    if you have NONE, get a mic (if it's just a generic mic that is) and let it get you a baseline to work from
    turbocad threw his out, but I know he's got some decent experience in tuning too, so it's kinda a moot point IMO...lol
    Jan Bennett
  6. #16
    Sep 2005
    CA, USA
    Smile
    I don't have any tuning experience. Per your guy's suggestions I think I'll just plug my PC microphone into it and let it auto calibrate. Thanks.
  7. #17
    Registered User
    I tried to use the pxa-701 measurement mic on my computer as a regular mic but it was horrible, it only worked if the mic was right next to my mouth so im guessing a regular mic will not work correctly on the pxa.
  8. #18
    Nov 2005
    with RUX in STAND ALONE mode you can use it with PC. You need the RUX always connected. You will not use the AINET protocol. You choose the INPUT (analog 1 2 3 or optical 1 2 3) and control the volume. You can also detache the RUX but then you will not have any control. Anyway you can control the volume by PC.
    Ask for any further question paololuca@inwind.it
  9. #19
    Nov 2005
    you can fully control by dva-9860
  10. #20
    Oct 2004
    NY
    doesn't the mic on the 700/01 only help set up time alignment? I don't think it does anything for actual tunning.....
    now the pxa-h900..... that's a different story.... the mic also does full spectrum tuning....., but as far as I remember the 700/01 is only for time alignment..... red, correct me if I'm wrong....
  1. Replies: 85
    Last Post: 07-09-2007, 05:44 AM
  2. alpine skin questions
    By hakhawk in forum RR Skins
    Last Post: 07-04-2005, 06:48 PM
  3. MP3 --> ALPINE head unit questions
    By WozzaWozza in forum Car Audio
    Last Post: 06-09-2005, 11:46 AM
  4. FS: Alpine Amps, Subs, 6.5" Monitors
    By coachreed in forum Classified Archive
    Last Post: 04-03-2005, 02:13 PM
  5. Alpine / PC Challenges all around...
    By acitrano in forum General Hardware Discussion
    Last Post: 11-10-2000, 08:45 AM
