Page 20 of 47 FirstFirst ... 101112131415161718192021222324252627282930 ... LastLast
Results 191 to 200 of 462
Thread: Alpine PXA-H701 Questions
  1. #191
    Oct 2004
    NY
    something will have to move the gate.... I guess a cable or even a direct mechanical connection... maybe even one of those bigger knobs can work for you even?
  2. #192
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by JasonWW View Post
    Good lord woman! You really got into that whole bit-perfect thing. I never should have mentioned that to you.
    Just messing with ya.
    hey - when you're trying to achieve the level that we are, things like that are what can make or break your sucess.
    Jan Bennett
  3. #193
    _
    Mar 2004
    Little Elm, Texas
    New for 07. From Red's (above) page.
    Alpine's appearently coming out with a new H650 processor as well.
    what I simply don't get about that HU....it doesn't play any CDs....just iPod...strange...and there's a really long thread around here about the 650.
    Alpine PXE-H650
    and there was another one somewhere around here too.
    Jan Bennett
  4. #194
    _
    Mar 2004
    Little Elm, Texas
    If you run a good sound card the sound quality will be good, although not quite as good as the digital signal. There is a PCI sound card for about $25 that has excellent SQ. I can tell you all about it if you want.
    http://www.newegg.com/Product/Produc...82E16829120103
    It's a good card, and can achieve bit perfect...
    there's that bit perfect thing again....hehehe
    Jan Bennett
  5. #195
    Apr 2005
    Queens, New York
    Quote Originally Posted by RedGTiVR6 View Post
    But if i have a HU and PC i am still trying to figure out how to switch the inputs
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
  6. #196
    _
    Mar 2004
    Little Elm, Texas
    I understand, I was mostly responding to Jason's post.
    regarding how to switch....you would go aux in from the PC to the HU.
    Let me see if I remember the thread correctly..
    You're wanting to use the 701 and a regular hu, correct? And you still want to maintain a decent amount of sound quality...correct?
    Jan Bennett
  7. #197
    Apr 2005
    Queens, New York
    Correct. I was thinking...currently i have a SB Audigy 2 NX, and I can supply a power switch on the 5V line of the NX and cut the power on/off and that would switch the signal!
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
  8. #198
    Oct 2005
    Hou. TX
    Another option, but I'm not sure if you would like it is to use another soundcard based on the same chip as the AV-710 that has a optical input as well as output. If you had a HU that had a optical SPDIF out you could run it to the PC. Then the PC would be the only SPDIF signal going to the H701 and you wouldn't need to switch inputs on the H701.
    This may be a bad idea as it opens another can of worms like how would you switch from the PC to HU sound? What HU's even have SPDIF out, etc...?
    Here's a little chart that may help. It would also help to figure out what would be best to transfer through analog and what through digital depending on what the highest quality of music should have priority. It may not be that big a deal, though. Consider most folks are still running all analog setups and the SQ is still extremely high.
    1999 Black Pontiac Trans Am
    CarPC's in F-bodies
    How To Relocate Climate Controls on the 97-02 F-body Cars
    (AMD Sempron 3000+, Opus 150)
    Car PC system is out, Alpine system is in.
  9. #199
    Apr 2005
    Queens, New York
    Hey that looks like an option but what is the brown arrows going from the HU to 701/PC
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
  10. #200
    Oct 2005
    Hou. TX
    Quote Originally Posted by Cheekz185 View Post
    Brown arrows=brown text
    CarPC's in F-bodies
  1. Replies: 85
    Last Post: 07-09-2007, 04:44 AM
  2. alpine skin questions
    By hakhawk in forum RR Skins
    Last Post: 07-04-2005, 05:48 PM
  3. MP3 --> ALPINE head unit questions
    By WozzaWozza in forum Car Audio
    Last Post: 06-09-2005, 10:46 AM
  4. FS: Alpine Amps, Subs, 6.5" Monitors
    By coachreed in forum Classified Archive
    Last Post: 04-03-2005, 01:13 PM
  5. Alpine / PC Challenges all around...
    By acitrano in forum General Hardware Discussion
    Last Post: 11-10-2000, 07:45 AM
