You guys are going on like you actually want to make it complicated. If Cheekz has to have a HU, then get a Alpine with the AI-net controller built in. Then run the SPDIF from the PC sound card to the H700 brain. Then use the HU to switch. That seems much simpler to me than making and modding a bunch of stuff.
BTW, I doubt that Turtle beach USB is going to have high sound quality. Might be OK, but I wouldn't use it.
Turbo, don't you think the audio data is sent through the AI-net as digital? Alpine may or may not be using the SPDIF protocol, they may be using something they designed. Still, I seriously doubt it would travel as analog. Consider that it must transfer 6 channels, right? Or would it only transfer 2 channels? I'm not sure. Still, there are just not enough wires in the AI-net cable for there to be 4 dedicated to the analog stereo or even 8 wires for the balanced signal plus the wires needed for the digital communication. I'm sure everything in the AI-net cable must be digital. That's what makes sense to me.
LinkBack URL
About LinkBacks
