Page 23 of 47 FirstFirst ... 131415161718192021222324252627282930313233 ... LastLast
Results 221 to 230 of 462
Thread: Alpine PXA-H701 Questions
  1. #221
    _
    Mar 2004
    Little Elm, Texas
    I don't believe the AiNet stuff is RCA on any end. It's a special plug.
    Jan Bennett
  2. #222
    Oct 2005
    Hou. TX
    Quote Originally Posted by Cheekz185 View Post
    Hey I have the PC in the trunk. And the h701 will go in the trunk once I get it. The HU i am getting is going to be the Alpine CDA-9857 with the ainet. Quick question, the aiNet cable has a special plug to connect into the h701 but to connect to the HU is it rca?
    No, it should be the same on both ends of the cable. No RCA's at all. I'm sure Turbo can confirm this.
    With the H701 in the trunk, no worries about induced noise, analog should be fine.
    1999 Black Pontiac Trans Am
    CarPC's in F-bodies
    How To Relocate Climate Controls on the 97-02 F-body Cars
    (AMD Sempron 3000+, Opus 150)
    Car PC system is out, Alpine system is in.
  3. #223
    Apr 2005
    Queens, New York
    im only asking cuz this is the Ai-Net cable that i needed:
    http://www.crutchfield.com/S-KGv4GuR...650#morephotos
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
  4. #224
    Oct 2005
    Hou. TX
    With the AV-710 you need to forget the factory drivers completely and run the Envy24 Drivers V143d. This is the key. You plug into channels 7+8 on the card. Go into the driver and set it to high bitrate. There may be a few other small things, but this is the important stuff. I can give you more details if you need them as well as the driver.
    CarPC's in F-bodies
  5. #225
    Apr 2005
    Queens, New York
    Quote Originally Posted by JasonWW View Post
    Absolutely thanks!
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
  6. #226
    Oct 2005
    Hou. TX
    No, your not using that. The music signals are transfered inside the AI-net cable. That has nothing to do with the AI-net connector.
    CarPC's in F-bodies
  7. #227
    Oct 2004
    NY
    the 701 has an aux input that takes rca's, so you won't need an adaptor like that... that would be if you had to provide an input when the only available inputs are ai-net..... these adaptors are what has me belive that there is analog audio signals through the ai-net.... I'm not 100% sure though, but it would appear so just by adaptors such as these...
  8. #228
    Apr 2005
    Queens, New York
    Quote Originally Posted by turbocad6 View Post
    So what cable do i need? Does it come with the h701?
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
  9. #229
    Oct 2004
    NY
    from what I remember, you don't need any special cable at all, except for the conversion to regular rca's from your soundcard if it uses a 1/8" phono jack..., the aux comes in as regular rca's...
    I'm not 100& sure now if the aux input is at the 700 or at the head unit.... come to think of it, it might be at the head unit..... I've got to look again, haven't touched my wiring in over 1.5 years
    if the aux is at the headunit, & your head unit takes that behind the head, then you might have issues with the longer runs from back to front, again driving the need for a line driver maybe.... I'll go look at the 700 to see for sure.... if it was optical this wouldn't be an issue, but of course then there are the other issues originally mentioned,...
  10. #230
    Oct 2005
    Hou. TX
    Are you thinking that plugs into the AI-net connector? It looks like it plugs into the CD-changer input and turns it into a AUX in.
    CarPC's in F-bodies
  1. Replies: 85
    Last Post: 07-09-2007, 05:44 AM
  2. alpine skin questions
    By hakhawk in forum RR Skins
    Last Post: 07-04-2005, 06:48 PM
  3. MP3 --> ALPINE head unit questions
    By WozzaWozza in forum Car Audio
    Last Post: 06-09-2005, 11:46 AM
  4. FS: Alpine Amps, Subs, 6.5" Monitors
    By coachreed in forum Classified Archive
    Last Post: 04-03-2005, 02:13 PM
  5. Alpine / PC Challenges all around...
    By acitrano in forum General Hardware Discussion
    Last Post: 11-10-2000, 08:45 AM
