Page 35 of 47 FirstFirst ... 252627282930313233343536373839404142434445 ... LastLast
Results 341 to 350 of 462
Thread: Alpine PXA-H701 Questions
  1. #341
    Oct 2005
    Hou. TX
    I probably will. We may have to just swap the guts as your housing is painted, right?
    I've looked all over locally for the TR7, but every place that has them wants $50-$70 for them which is rediculous. I'll probably order one online for 25 bucks including shipping.
    I did just get in my Alpine XM tuner, the old style. I didn't realize it needed a special 2 into 1 antenna adaptor to work with the newer antennas. I can't wait to get that bad boy working.
    I'm having one issue though. I picked up a AI-net cable locally, but it seems to cause a 58 second turn on delay. Very weird. Once it turns on, it works fine. I just tried the cable that came with the XM tuner and it fixed the problem so I know it's the cable. Anyone ever have that happen to them?
    One other note about the AI-net cable. It obviously can have at least 2 different analog music signals going through it at the same time. I was thinking the 2 big connectors in the middle where for the audio, but with the XM tuner installed the analog XM music has to travel to the HU (I assume) and then back to the H700 simultainiously. Does anyone have a clue about this?
    1999 Black Pontiac Trans Am
    CarPC's in F-bodies
    How To Relocate Climate Controls on the 97-02 F-body Cars
    (AMD Sempron 3000+, Opus 150)
    Car PC system is out, Alpine system is in.
  2. #342
    Oct 2004
    NY
    yeah, mine is painted black, the guts can be switched though.
    tr-7's are cheap online, I used to always keep a few around, there good for SOOO many things besides the alpine bypass really, I use them for a lot of things really, there great as timers or flip flops or sequencers.
    ai-net cables are expensive too & used ones can be a headache, most install them carefully, but when the time comes to guit the car they never get as much care & if there pulled too hard on removal they screw up... never had the issue your talking about though, usually they work or they don't.
  3. #343
    Low Bitrate hypnotiq's Avatar
    Aug 2005
    Hey guys,
    Thanks for answering my questions earlier, but i have a few more if you don't mind. I just bought the h701/rux combo for 534 shipped , but i realized i don't really have anywhere to mount the controller. So i just plan on taking it out whenever I plan on tuning my system.
    Say I took out my rux in order to tune my H701 which is in the trunk, how would i power the rux? Can it run off of the H701, or does it need its own individual power/negative wires?
    _
    Mar 2004
    Little Elm, Texas
    The RUX only has one cable going from it to the brain. That's how it gets it's power.
    Jan Bennett
  5. #345
    Aug 2005
    Ah, great thats what I was hoping for.
    On a sidenote, I hope this is the right place to ask, but could you recommend an external soundcard/dac thats sole purpose is to connect to the H701. Of course that would mean it has optical out. The reason I'm asking this in the H701 thread, and not the external soundcard thread, is because I'm not looking for a card that has a bunch of processing capabilities since the H701 will handle that. Instead, i'm looking for the cheapest card that won't bottleneck my sound quality before it reaches the processor.
    Thanks for all your help.
    PS. If the answer is found somewhere else, I apologize, but I did try searching a bit.
  6. #346
    Oct 2005
    Hou. TX
    The Chaintech AV-710 sounded real nice and is real cheap. With the right drivers it is very basic and reliable and will hibernate, too. It can do bit perfect as well.
    CarPC's in F-bodies
  7. #347
    Aug 2005
    That looks like a really good card, but i'm using a laptop so i'm limited to only usb cards
  8. #348
    Oct 2005
    Hou. TX
    Quote Originally Posted by hypnotiq View Post
    Ohh.
    Does the laptop have an optional SPDIF output? Sometimes docking stations will have it integrated.
    Other than that, the only ones I know of are the high end Sound Blasters like Red is running. I really can't help you much there. You may have to search for it as I'm sure it has to have been talked about before.
    CarPC's in F-bodies
  9. #349
    Aug 2005
    My laptop is a dell 600m. It doesn't have a spdif out, but the docking station i'm using does. Sorry for my ignorance, but what can that be used for?
  10. #350
    Oct 2004
    NY
    then you can go from the spdif to the alpine, no addl soundcard needed really
  1. Replies: 85
    Last Post: 07-09-2007, 04:44 AM
  2. alpine skin questions
    By hakhawk in forum RR Skins
    Last Post: 07-04-2005, 05:48 PM
  3. MP3 --> ALPINE head unit questions
    By WozzaWozza in forum Car Audio
    Last Post: 06-09-2005, 10:46 AM
  4. FS: Alpine Amps, Subs, 6.5" Monitors
    By coachreed in forum Classified Archive
    Last Post: 04-03-2005, 01:13 PM
  5. Alpine / PC Challenges all around...
    By acitrano in forum General Hardware Discussion
    Last Post: 11-10-2000, 07:45 AM
