Page 9 of 47 FirstFirst 12345678910111213141516171819 ... LastLast
Results 81 to 90 of 461
Thread: Alpine PXA-H701 Questions
  1. #81
    Oct 2004
    NY
    yes, you will be able to fully control the 701 through this head, but you have to still have the inputs come to the head unit I belive, alpine is really cool on the phone most times, that might be the best way to find out details is just call them..., unless you have an authorized alpine dealer close by, that looks like a really nice display on that head unit.......
  2. #82
    Maximum Bitrate Caelric's Avatar
    Sep 2005
    Bellevue, NE
    The whole point is that I would want to run a digital optical output to the PXA-H701 from my Sound Blaster, and it looks like there is no optical input on the head unit, only RCA inputs.
    I'll try giving them a call tomorrow. Thanks for the suggestion, I never thought of that.
    Dave
    2005 Infiniti G35 6MT Coupe Black/Black
    Core Duo CarPC
    CarDomain page
  3. #83
    Oct 2004
    NY
    from what I know of the 700/01, when it picks up an optical input it'll switch to it.... when the optical input goes away, it'll switch back to the ai-net(head unit)
    this shoudn't be a problem for you, just run the optical into the 701 & when you want to switch back to the ai-net is where it gets tricky... you will either need a hotkey with a script to turn the optical output on & off (james bond style), or unplug the optical cable or soundcard, or hook up a switch to turn the sound card off & on... this can screw with programs though sometimes...
    it is also possible to break the light beam of the optical to switch back to ai-net... & also switch to an alternate optical source as well...I'm building a gate switch for that.....
    I'd say call them & speak to someone, but this is how it works in my setup...
  4. #84
    Jul 2006
    Hi guys,
    im just making my new CarPC:
    AMD XP-M system with optical out soundcard.
    I was wondering how do I connect up my mono and 4 channel amp to the pc?
    I want to use my H701, so does the optical from the soundcard go into my H701?
    how do I go about connecting the amps to the carpc?
  5. #85
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by uberwerkz
    Hi guys,
    sounds like you are very confused here. lets try to clear this up. you go optical out from your soundcard into the h701. then you connect the rca outputs of the h701 to your amps. load up your drivers, make sure the h701 is set up for optical input and you're off to tuning land.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  6. #86
    Jul 2006
    Quote Originally Posted by scott_fx
    thats what I meant lol thanks Scott. Just waiting for my screen so I can get started
  7. #87
    Aug 2005
    south GA
    online retailer
    ok Red GTi VR6 / turbocad6 can you recommend any online retailer to purchse a 701 from? i live in BFE and will have to drive 1-1.5 hours -with a busy schedule - to just look at one if im lucky... .based you these posts ... ill take your word for the quality and functionality.
    96 cobra
    suspension: MM CC plates, H&R super sport, bilsteins, steeda:bump steer kit, X2's, moly SFC's, triax shifter. MGW handle, cobra knob. Audio:RUX-C701, PXA-H701, MRV-F545, MRD-M1005, SIR-SC-H1, DMHD1000, Polk/Momo MMC6500, MM2104
  8. #88
    _
    Mar 2004
    Little Elm, Texas
    NOT woofersetc.com
    they are known to sell counterfit products.
    Crutchfield sells it.
    http://www.crutchfield.com/S-WF5BzbK...0&I=500PXAH701
    http://www.abtelectronics.com/product/16615.html
    http://www.techronics.com/index.cfm?...FSyQFQodSDeZHw
    I cannot vouch for any of those companies though.
    I never purchase car audio equipment online.
    Jan Bennett
  9. #89
    Oct 2004
    NY
    yeah, I don't buy any new alpine stuff online either... except maybe if you find a GOOD seller on ebay maybe....
    I've got a good alpine dealer local to me that I buy from...
  10. #90
    Low Bitrate unixxx's Avatar
    Sep 2005
    CA, USA
    Talking
    I bought mine used on eBay w/ the RUX-C701 for $200 off. Could really care less if it's used. I did have to order the power and data cables from an Alpine parts center for $50 though. I bought my amp new from HookedOnTronics, 4.3/5 at ResellerRatings, for $100 off. Is there anyway I can tell whether it's genuine or not? It came in the original box with all the accessories/manual and was packed like new. They sell the RUX and PXA as well: http://www.hookedontronics.com/show_...st.jsp?cid=799 Assuming my amp is authentic (it works fine) they're a great store.
    # cd /home/fuzzymuzzle.com
    Intel Pentium M Dothan 750 1.8GHz 533MHz 2MB
    iBase MB896F w/ Intel 915GM
    [■■■■■■■■■■■■■■■■■■■■] 50% Done
    (Writing Front/Back End, Designing Electronics, and Completing Install)
  1. Replies: 85
    Last Post: 07-09-2007, 05:44 AM
  2. alpine skin questions
    By hakhawk in forum RR Skins
    Last Post: 07-04-2005, 06:48 PM
  3. MP3 --> ALPINE head unit questions
    By WozzaWozza in forum Car Audio
    Last Post: 06-09-2005, 11:46 AM
  4. FS: Alpine Amps, Subs, 6.5" Monitors
    By coachreed in forum Classified Archive
    Last Post: 04-03-2005, 02:13 PM
  5. Alpine / PC Challenges all around...
    By acitrano in forum General Hardware Discussion
    Last Post: 11-10-2000, 08:45 AM
