Page 1 of 47 1234567891011 ... LastLast
Results 1 to 10 of 461
Thread: Alpine PXA-H701 Questions
    Low Bitrate unixxx's Avatar
    Sep 2005
    CA, USA
    Smile Alpine PXA-H701 Questions
    Ok guys, I've been thinking about buying the Alpine PXA-H701 DSP, for a number of reasons:
    *Dolby Digital, Dolby Pro Logic, PCM, DTS
    *If the centre speaker is turned “OFF”, the centre
    channel's audio signals are added to the audio
    signals output from the front speakers.
    *Alpine Brand
    *Three S/PDIF TOSLINK inputs
    *Three analog RCA Inputs (two combined with proprietary Ai-NET connections)
    *Extremely configurable
    *A s!@# load of other awesome features
    European Manual: http://www.restricted.alpine-electro...XA-H710_EN.pdf
    However, before I invest in one I have a few questions I hope you guys can help me with:
    *Will all of the features of the DSP be unlocked with the RUX-C701 and no Alpine head unit; the manual says:
    The PXA-H701 can be used with any head unit. However, only an Alpine Ai-NET compatible head unit will be able to
    take full advantage of all the features and functions of this processor.
    *What are the "Front 2" outputs for? SUVs with three rows of seating? Tweeters?
    *Finally, is the European version the same as the American one as the European site is the only one that actually has the manual (for the European version).
    Sorry if these questions seem obvious, manuals aren't always straight forward Thanks.
    # cd /home/fuzzymuzzle.com
    Intel Pentium M Dothan 750 1.8GHz 533MHz 2MB
    iBase MB896F w/ Intel 915GM
    [■■■■■■■■■■■■■■■■■■■■] 50% Done
    (Writing Front/Back End, Designing Electronics, and Completing Install)
    Maximum Bitrate 3onDubs's Avatar
    Aug 2005
    Anaheim Hills, Ca
    All of the features will be unlocked with the C701 since its only purpose for being built was to control the H701.
    The Alpine H701 has a built in active crossover that can replace your passive crossovers going to your front door components (which consist of a tweeter and a midrange). The outputs on the Alpine are labeled Front 1, Front 2, Rear, and Subwoofer. This allows for the option of amping your tweeter seperately with seperate inputs. Front 1 could control your tweeters, Front 2 would then control your midranges, and the rear and subwoofer would be the same as before. It's just an option for added flexibility. If you would rather just use your passive crossovers that came with your components, than you can just use either Front 1 or Front 2 (but not both).
    As for the European Version, I'm pretty sure that it is the same version because my owner's manual was written in three languages (French, Spanish, and English). That's not necessarily proof, but I wouldn't doubt they are the exact same product.
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
    Apr 2005
    i have that setup. it's friggen nutty. the 5.1 sounds sick. it's got optical inputs, use an audigy platinum and it's unbelievable. thing is, unless you have a projector mounted in your grill projecting like a drive in movie, you're hearing xwing fighters in star wars louder than hell, on an itty bitty 7 inch screen
    Sep 2005
    CA, USA
    Smile
    3onDubs: Great, thanks for clarifying and answering all of my questions
    dirtylarry: I know... All of this wonderful audio and such a small screen
    I think I'm definately going to go with the Alpine DSP. The Panasonic CY-AC300EX doesn't have nearly as many features and seems to be popping up for sale all of the time Would you guys get a 5 channel amp (sub amp integrated) or a 4 channel amp and a seperate sub amp. I'm going to have phantom center so I don't need six channels. Thanks.
    Dec 2005
    Alberta, Canada
    Dont mean to jack the thread but I had a question about the PXA myself. I was wondering the whole unit can be controlled from the Alpine DVA-9860 or would I have to go with $1500 Alpine DVA-9965
    Sep 2005
    CA, USA
    Smile
    The European manual says:
    The control unit for the PXA-H701 is sold separately. The operation method
    using this control unit (sold separately) is printed in this instruction manual.
    However, if you use head units such as the IVA-D300 series or the IVA-D900
    series, you can also operate the PXA-H701 from these head units (Items
    such as AUTO TCR and navigation system voice guidance interruption
    settings can only be operated from the Control Unit). For more details on the
    head unit operation, see “External Audio Processor (Optional)” in the
    instruction manual for the head unit.
    It looks like all you need is Ai-NET support in your Alpine head unit:
    Good luck!
    _
    Mar 2004
    Little Elm, Texas
    you won't be dissapointed by going with the alpine....it's a great unit, best for the money out there!
    Jan Bennett
    Sep 2005
    Bay Area, CA
    The H701 is da bomb. Any AINET head unit can turn it on remotely and control its volume (from what I'm told), but only the IVAs and the DVAs can change its settings from the HU.
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    i have 2.1 in my car and the sound is so much better then my old pci soundcard to an audio control 24sx and I still have it hooked up with analog not digital!
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Newbie bob^'s Avatar
    Jun 2005
    Geelong - Australia
    DVA-9560 can control everything except auto time alignment. Manual is the way to go anyway.
    2004 Ford Falcon XR6
  1. Replies: 85
    Last Post: 07-09-2007, 05:44 AM
  2. alpine skin questions
    By hakhawk in forum RR Skins
    Last Post: 07-04-2005, 06:48 PM
  3. MP3 --> ALPINE head unit questions
    By WozzaWozza in forum Car Audio
    Last Post: 06-09-2005, 11:46 AM
  4. FS: Alpine Amps, Subs, 6.5" Monitors
    By coachreed in forum Classified Archive
    Last Post: 04-03-2005, 02:13 PM
  5. Alpine / PC Challenges all around...
    By acitrano in forum General Hardware Discussion
    Last Post: 11-10-2000, 08:45 AM
