One popular way one can tune their system is by watching the frequency levels on the RTA while tweaking the frequencies with an equalizer. Access to an RTA, however, can be difficult and expensive.
If you are content with a rough tune to get rid of the major resonances and peaks, and cannot afford an RTA, you can purchase a Radio Shack sound pressure level meter (dB meter) for $40.00 (digital).
The Radio Shack meter is fairly consistent (standard deviation is about 0.5-1.0dB) and accurate - especially when measuring the midrange. It maxes out at 125dB. Various corrections are available on the internet in order to improve accuracy. When measuring using "slow" response and "C" weighting, the following corrections seem to be most accurate:
10Hz +20.5
12.5Hz +16.5
16Hz +11.5
20Hz +7.5
25Hz +5
31.5Hz +3
40Hz +2.5
50Hz +1.5
63Hz +1.5
80Hz +1.5
100Hz +2
125Hz +0.5
160Hz -0.5
200Hz -0.5
250Hz +0.5
315Hz -0.5
400Hz 0
500Hz -0.5
630Hz 0
800Hz 0
1KHz 0
1.25Khz 0
1.6KHz -0.5
2Khz -1.5
2.5Khz -1.5
3.15Khz -1.5
4KHz -2
5KHz -2
6.3KHz -2
8KHz -2
10Khz -1
12.5KHz +0.5
16KHz 0
20KHz +1
After purchasing the SPL meter , you would then make a test tone CD filled with test tones of various frequencies at a 1/3 octave step. You can then measure the dB of various frequencies and either boost or cut the frequency with an equalizer. You can download the MadPSI test tone CD by right clicking and "save target as..."
this link. The file is compressed by WinRar, and each sound file is in mp3 format (high quality variable bit rate). The compressed file should have the following mp3 files:
20Hz
30Hz
40Hz
50Hz
60Hz
70Hz
80Hz
90Hz
100Hz
125Hz
150Hz
175Hz
200Hz
225Hz
250Hz
275Hz
300Hz
350Hz
500Hz
600Hz
800Hz
1000Hz
1200Hz
1600Hz
2000Hz
2200Hz
2500Hz
3200Hz
4000Hz
5000Hz
6000Hz
8000Hz
10000Hz
12000Hz
14000Hz
16000Hz
18000Hz
20000Hz
Brown noise
Pink noise
White noise
