Page 6 of 14 FirstFirst 1234567891011121314 LastLast
Results 51 to 60 of 139
Thread: Induced noise/Ground loop trouble shooting guide.
  1. #51
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by Red GTi VR6
    ok - so is there noise when it's JUST the hu?
    Can you possibly find a link to the type of cables you're using?
    There is no noise from the headunit IF the cable is disconnected from the computer, but once connected, there is noise as long as the carputer is getting power, wether on or off. If I plug an ipod into the HU using the same cable, there is no noise.
    The cable I have has a 1/8 mini plug on both ends, that is three conductors. Both end would fit into the earphone jack of an IPOD, so if you at a pair of headphones, you will see what kind of connectors it has on both ends. This also fits directly into my HU's aux in jack. The connectors have a 6 foot length of 2 conductor and a 3rd that is a shield. I would give you a link, but I am currently on my Blackberry, and don't have the "luxury" of navigating between windows to cut and paste a link, sorry.
    EDIT: Got to a computer, here is the link http://www.allelectronics.com/cgi-bin/item/CB-121/117/6"#39;_CABLE_W__3.5MM_STEREO_PHONE_PLUGS_.html
    Michael
  2. #52
    Falls Church, VA
    When you hook up the ipod, are you running it off of the ipod battery or do you have it powered by the cig lighter?
    If its the first, its telling you that the head unit is producing noise outside of ground loops, which it is not. If its the later, im amazed
    You have a ground loop between your PC and HU. No way around it. Grab a ground loop isolator and test it. If the noise goes away then its 100% a ground loop between the PC and the deck
    But then the problem is which is the culpret?
    I would yank the deck, connect it to the same power source as the PC and leave the deck right on top of the PC. Hook it up to a speaker and a very small RCA. Check if the noise goes away. Ground the chassis of the deck to the same point, check to see if the noise goes away. If the noise is still there, then we are in trouble.
    I'm going to go out on a limb and say that the rampage deck's internals are pretty crappy. They have not isolated the aux in on the deck from chassis gound forcing a ground loop no matter what you do. Your only choice is a new deck or ground loop isolator to make up for the bad design.
    Maybe its time to invest ina new deck with a decent design? Any available on the classified forum?
  3. #53
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by Will Albers
    By the ipod battery, so I guess you not amazed
    I'm tending to think that is the case.
    Well, they ARE taking power and ground from the same wires in the same physical location.
    I'll try a different, single speaker on the HU, but the car is 10 years old, and I am almost sure that there is no crossover or external amp to cause problems. Can I use an 8 ohm speaker, or do I need a 4 ohm one??
    [QUOTE=Will Albers] Ground the chassis of the deck to the same point, check to see if the noise goes away. If the noise is still there, then we are in trouble.
    Well, I grounded the HU chassis to the same wires that ground the carputer and the HU, it made no difference. Only grounding the carputer chassis helped with the RFI a little, but I am more concerned with the engine whine.
    [QUOTE=Will Albers]I'm going to go out on a limb and say that the rampage deck's internals are pretty crappy. They have not isolated the aux in on the deck from chassis gound forcing a ground loop no matter what you do. Your only choice is a new deck or ground loop isolator to make up for the bad design.
    Then a GLI it is. I am fine with a bandaid, as long as the booboo goes away.
    Hmmmm, I will think about it, but chances are, unless it is ACTUALLY the HU, I will still have engine whine.
  4. #54
    Variable Bitrate nemo1's Avatar
    Jun 2006
    Aeroplane sound
    Hi All,
    I am having the same problem. I am connecting the output of my sound card to the HU. I get the aeroplane sound. Tried sound card to headphones and its ok then tried using PDA to Hu and it is also ok but when I connect sound card to HU the problem is there again. I ask around about the noise isolator and the sales person tells me that it will reduce the bass level if I install the noise isolator. Any way to fix this? Pls. help..
    Many many thanks
  5. #55
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    So, the GLI fixed the problem.
    Michael
  6. #56
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    Quote Originally Posted by nemo1
    Hi All,
    Many many thanks
    if you check my post a few threads above u will see i had similar problems.. what did solve my problem is that I removed the ground from the HU ISO plug and i ran a 12 AWG ( i wish i had 10 awg..) from the HU case to the PC case.. that took away most of the noise.. then i bought a ground loop isolator which did not effect the sound quality at all.. i feel that it is even better (as it removed the noises even those that u don't notice) and bass is even better. and that removed all the remaining noises.. so veeery happy now.
    I tottaly disagree that isolators effect the sound quality.. if u think of it they are just magnetic transformers with a 1:1 ratio..they let music pass through (magnetically) but DC current is blocked.
  7. #57
    Jun 2006
    Thank You Nomader...I will try it out and post the outcome...
  8. #58
    Jun 2006
    Nomader...after reading your threads, I noticed that you are using a Blaupunkt HU. I am also using a Blaupunkt HU, there are many cables running out from the HU ISO plug, how do you know which one is the ground?
    thanks again
  9. #59
    Apr 2006
    Greece
    As far as I know all Blaupunkt HU use the ISO plug.. it is the black cable (usually) DO NOT run the unit without any ground cable at all.. very dangerous it will burn your HU or cables as it will ground itself through any other cable it will find (speaker etc.).
    take your time.. remove the connectors cut the small ground wire in the ISO plug. then ground it either on the pc case or into the same position you have grounded your pc (this cable sould be as short as possible and as thick as possible) try which gives you less noise. try to remove as much noise as possible before using the isolator. (sounds easier saying it than doing it)
    you can download the manual of your HU from the blaupunkt site, if you don't have it. it has the diagams..if it is different than this one
  10. #60
    Falls Church, VA
    Quote Originally Posted by Wiredwrx
    Michael
    Thats good, sort of. Its a ground loop between the deck and PC, the GLI is a band-aid. I would still like to know the culpret (deck ) but if its workin, let it be and enjoy!
  1. I tried everything, can't get rid of this ground loop
    By intense in forum General Hardware Discussion
    Last Post: 07-10-2005, 09:58 AM
