what do you mean it's been a long time....it's been 7 days since the last post?
Printable View
right, and if you read the thread you would see that the answer is no....as explained by the post just 7 days ago...
old thread i know but that PT5.1 doesnt seem like it was very well designed...
http://ampguts.realmofexcursion.com/....1/inside2.jpg
I beg to differ. It looks pretty well-designed to me. BTW, the amp I recommended can be found here. I've had it for a long time now, and it hasn't given me any problems.
I'll have to make my way across the "Falls" and see your set-up sometime. I haven't installed my PT ICBM 5.1 yet and could use some pointers on setting it up and config'ing it. Nice to see another vender for this. I wonder how his supply for the IR remote control is.
Pretty old thread. Thought I'd bump it to see if there's anything new, as I'm helping a mate plan his carpc and an amp with optical inputs would probably be the best way to do it.
Hi
I was wondering if anyone can help me..
I have a 5.1 pioneer setup in my car and would like to add a 5.1 hdd media player to the system and would like to use 5.1 sound from both sources from my head unit and the hdd player, after a little thinking I came up with a solution as follows:
If I was to buy a multi channel amplifier with both 5.1 rca input and optical input and was to connect the hdd to the amplifiers optical and the video to my pioneer unit I would have 5.1 sound but heres the part I'm not to sure about.... now my pioneer unit has a 5.1 rca output if I was to connect the 5.1 output to the amplifiers 5.1 rca input I should now have both sources 5.1 the hdd will be connected via optical and my pioneer avh systems 5.1 will be connected via 5.1 rca now all I should be doing is switching the source from the amplifier remote to listen to which ever one I prefer.
Does anyone think otherwise?? or will this work?
and most importantly which amplifier has this connectivity 5.1 rca input and optical input?
and where can i get one from?
Thanks in advance folks.
