Page 6 of 12 FirstFirst 123456789101112 LastLast
Results 51 to 60 of 119
Thread: 5.1 Amplifiers with Optical inputs
  1. #51
    _
    Mar 2004
    Little Elm, Texas
    what do you mean it's been a long time....it's been 7 days since the last post?
    Jan Bennett
  2. #52
    Sep 2007
    Quote Originally Posted by RedGTiVR6 View Post
    it said since the list was updated, the list with the audio amps with optical input
    * Pessimists are people without dreams.
    * Got the CA18DET love.
  3. #53
    _
    Mar 2004
    Little Elm, Texas
    right, and if you read the thread you would see that the answer is no....as explained by the post just 7 days ago...
    Jan Bennett
  4. #54
    mst
    mst is offline
    Constant Bitrate mst's Avatar
    Nov 2003
    France
  5. #55
    Maximum Bitrate Megalomaniac's Avatar
    Jan 2006
    The Colony, TX
    Quote Originally Posted by ajscomp372 View Post
    I recommend the Performance Teknique ICBM-5.1. It has an optical input, and is also able to decode dolby digital 5.1. It does not require a head unit, is controlled by an IR remote, and can be purchased online. Just Google it and you'll find it.
    old thread i know but that PT5.1 doesnt seem like it was very well designed...
    screen name here use to be MegaloRESE15"
  6. #56
    Low Bitrate ajscomp372's Avatar
    Mar 2006
    Buffalo, NY
    I beg to differ. It looks pretty well-designed to me. BTW, the amp I recommended can be found here. I've had it for a long time now, and it hasn't given me any problems.
  7. #57
    Variable Bitrate jschrauwen's Avatar
    Jul 2006
    Frankford, Ontario, Canada
    I'll have to make my way across the "Falls" and see your set-up sometime. I haven't installed my PT ICBM 5.1 yet and could use some pointers on setting it up and config'ing it. Nice to see another vender for this. I wonder how his supply for the IR remote control is.
    http://gickr.com/results4/anim_5055e...a2b3b197c9.gif
    1990 RHD JDM 300ZX TT 2+2 5sp T-Top
    491RWHP / 18psi / 94 octane
  8. #58
    Constant Bitrate S2K12's Avatar
    May 2006
    Perth, Western Australia.
    Pretty old thread. Thought I'd bump it to see if there's anything new, as I'm helping a mate plan his carpc and an amp with optical inputs would probably be the best way to do it.
  9. #59
    Jul 2006
    Quote Originally Posted by S2K12 View Post
    Nice to see another Z here.
    I'll have an eye on this thread to see what amp you decide on with optical input.
    cheers,
    John
  10. #60
    Oct 2008
    Two sources, Both 5.1.. One AMP?
    Hi
    I was wondering if anyone can help me..
    I have a 5.1 pioneer setup in my car and would like to add a 5.1 hdd media player to the system and would like to use 5.1 sound from both sources from my head unit and the hdd player, after a little thinking I came up with a solution as follows:
    If I was to buy a multi channel amplifier with both 5.1 rca input and optical input and was to connect the hdd to the amplifiers optical and the video to my pioneer unit I would have 5.1 sound but heres the part I'm not to sure about.... now my pioneer unit has a 5.1 rca output if I was to connect the 5.1 output to the amplifiers 5.1 rca input I should now have both sources 5.1 the hdd will be connected via optical and my pioneer avh systems 5.1 will be connected via 5.1 rca now all I should be doing is switching the source from the amplifier remote to listen to which ever one I prefer.
    Does anyone think otherwise?? or will this work?
    and most importantly which amplifier has this connectivity 5.1 rca input and optical input?
    and where can i get one from?
    Thanks in advance folks.
  1. Hifonics Zeus AMP for DIGITAL 5.1 decoding!!!
    By kenski in forum Car Audio
    Last Post: 04-22-2010, 04:27 PM
  2. Clarion DSP -- Optical inputs
    By justav6 in forum General Hardware Discussion
    Last Post: 01-03-2008, 01:51 PM
  3. For those who want true 5.1 Dolby Digital and DTS
    By antimatter in forum Car Audio
    Last Post: 06-29-2007, 12:54 PM
  4. Comments on 5.1 car amplifiers
    By ptk in forum Car Audio
    Last Post: 07-31-2005, 02:31 PM
  5. 5.1 and stereo
    By mbaratta in forum Car Audio
    Last Post: 05-25-2004, 08:09 PM
