Originally Posted by
enigma9o7
Unless I'm also ignorant, when the signal goes from your deck/pc to an amp optically, there's no volume control from the sending device... you adjust the volume with the amp. All that's going thru the fiber is the digitally encoded audio.... there are no levels involved, either the led/laser is on or off to indicate 1 or 0. I can set the volume to 0 on my deck and optical signal is not affected. The same thing happens with my home theatre components - i.e. I can set my HDTV volume to zero, but signal coming optical out into my amp doesn't change.
However, if the signal is coming from your deck/pc to an amp analog, then when you change the volume on your deck/pc it is changing the voltage levels going into the amp, so it does control volume, in essence your amp is applying the same amplification to whatever comes into it if you dont change it. i.e. if the amp does 3db gain, it'll apply that gain/increase to whatever voltage is coming in.
What I did in my car was run optical from my deck to the the phoenix gold 5.1 amp and use pacswix to have my steering wheel volume control adjust the amp volume. This worked for cds, mp3s & dvds. For the radio & tv, I didn't get sound from my deck on the optical (I wasn't lucky enough to get a deck with analog to pcm encoding) so I also ran rca's from my deck to the amp. I made one of my steering wheel buttons the input select on the amp, and then adjusted the volume on the deck so it was approx the same level as a CD via optical, then from there never touched the deck volume again.
