Page 6 of 6 FirstFirst 123456
Results 51 to 58 of 58
Thread: Processor Options
  1. #51
    Maximum Bitrate Ruffy's Avatar
    Sep 2006
    Georgia
    Just an update
    Rockford Fosgate has released beta versions of software to control their 3SIXTY Line of processors.
    They have two lines, the 3Sixty.1 and the 3Sixty.2
    Both provide a Bluetooth interface to control the tuning of the unit. before you needed a PDA to tune it, now you dont.
    The 3sixty.1 can be found for under $300, the 3Sixty.2 can be found for under $400. NO OTHER HARDWARE/SOFTWARE purchase required!
    Info page here, with software download
    http://www.rockfordfosgate.com/produ...n_US&p_status=
    Pictures of the software running. Are below
    3Sixty.1
    3Sixty.2
    Quote Originally Posted by RedGTiVR6 View Post
    1/4" and 1/8" can still be individual channels...just like RCA!
    btw - what RCAs are you running?
    Knukonceptz Blue Klarity from sub Amp to Audiocontrol 4xs Crossover
    Soundstream 3.0 from A/b Amp to Audiocontrol
    JL Audio XA-CLRAIC2-3 from Audiocontrol to Silverstone EB01 USB Dac
    I plan on replacing all my cabling in the future with custom made cables. Right now Im building my own usb cables because I cant find anything under 3ft thats cheap. Found 6" at 10 dollars, I need at least 3 very short usb cables so I decided to make my own on the cheap.
    Already made 2, one for my usb hub(4") and one for my usb dac(8")
    Next one up is for my carnetix 2140, then possibly another for whatever sound processor I get if I get one, IE the Alpine PXE-h650 if it ever gets released
    Car : 00' Chrysler 300M
    Speakers : Rainbow Audio SLC 265 | Subs : Diamond Audio D6 12" Subs X2
    Amp's : Hifonics ZXi 6006 AB | Hifonics BXi 1606 D
    CarPC: HP Laptop AMD Sempron 3000+ | 1.5GB RAM | DVD+RW | 80GB 5400RPM HD | ATI R200 Video
  2. #52
    Mar 2007
    RF 3sixty.2 windows software. The first, if not only, carputer friendly processor out there, connected via bluetooth:
  3. #53
    _
    Mar 2004
    Little Elm, Texas
    Hrmm - they must have realized that limiting themselves to the Palm base was pointless.
    I'd be interested to see some reviews of this piece....*goes off to hunt them down*
    Jan Bennett
  4. #54
    FLAC XC-C30's Avatar
    Jun 2006
    Abele, Belgium
    for them that don't mind going partially analogue....: AudioControl EQX
    Xenia & Isabelle, totally in love!
    'T SQiekenkot: VOLVO 740GL 2.3
    CarPC: none at the moment
    CLARION HX-D2
    CLARION APA4300HX => Fountek NeoCd1.0 + TB W4-1337SD
    CLARION APA4300HX => CSS Trio8
    CLARION APA2100 => Dayton IB385-8
  5. #55
    Raw Wave Defiler's Avatar
    Jan 2002
    Temple Terrace, Fl.
    Even though it's way out of my, as well as 95% of everyone else's, budget here on the forums...The Alpine PXI-H990
    Aura MR62 (F and R)
    My Current MP3s
    IamDefiler.com
  6. #56
    _
    Mar 2004
    Little Elm, Texas
    I'd like to not that the above post is not 100% accurate (yes, this is just a technicality...nothing major).
    The post states 900, when infact the processor linked to is the 990.
    The 900 is the original version of the F#1 processor. It can handle 11 channels of audio processing while the 990 can only handle 8. The 900 connects via serial while I believe hte 990 connects via USB.
    Also of EXTREME importance is that the 990 REQUIRES the Alpine F#1 CD player while the 900 does not.
    Jan Bennett
  7. #57
    Jan 2002
    Temple Terrace, Fl.
    Oops! My mistake. I did mean to have the text for the link state 990 even though I was aware of the 900. Changing now. And you are correct, the 990 is USB.
    BTW. I also had PXA not PXI.
    "That's what I love about you. Your attention to detail." Ace Ventura - Pet Detective.
    Aura MR62 (F and R)
    My Current MP3s
    IamDefiler.com
  8. #58
    Sep 2007
    Seattle, WA
    I have had 4 or 5 of the below, and it's really not an option (it's a closed system, which includes a head unit that controls the main processor brain (heck, it even converts the FM/AM from up front to digital to pipe it to the back)).
    The only input is a clarion (and McIntosh) specific optical input that needs to see a changer to work.
    No real way of connecting in a CarPC to this bad boy (heck, even an Aux in is sort of a chore, involving finding a dead changer and hacking it to make it think it has a changer connected while an AUX In signal is connected).
    Juan
    • Clarion ADCS1
      • Tuner -
        • 18 FM/6 AM
        • Station category search tuning
        • 60 station memory call letter display
        • Magi-Tune(tm)+FM
      • CD -
        • Full logic CD controls
        • Programmable play 99 tracks
        • Track music search FF/FB
        • Audible FF/FB
        • Last position memory
      • CD changer control -
        • 100 CD title memory display
        • Direct disc select
        • Multi-changer control capability
        • Audible FF/FB
      • DSP -
        • 5 preset sound balance memories
        • 5 sound field memories
        • 7 adjustable sound field parameters
      • EQ -
        • 4 channel, 6 band digital parametric EQ
        • Selectable center frequencies, 31 points, 1/3 octave
        • Adjustable Q
      • X-over -
        • 14 channel digital crossover
        • Selectable crossover points
        • Selectable crossover slopes 12dB, 24dB, 36dB/octave
        • Phase selectors
        • Adjustable gain controls
        • Independent adjustable time alignments
        • 5 preset memories
      • Audio -
        • Digital audio controls
        • Digital fiber optic connections
        • 20 bit 4 channel D/A converters
        • 8 times oversampling
      • General -
        • Switchable illumination
        • User infrared remote control
        • Programming infrared remote control
        • RS-232 port for parameter programming from computer
