Page 11 of 13 FirstFirst ... 2345678910111213 LastLast
Results 101 to 110 of 122
Thread: Ultimate USB, Firewire, External Soundcard List
  1. #101
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by emperorjj1 View Post
    will pcmcia cards work for car pc applications?
    im lookign at the audigy 2 ZS notebook by creative labs
    http://us.creative.com/products/prod...ct=10769&nav=3
    Any card will work with a CarPC application....you just have to have the means to connect it.
    The 2ZS Notebook is what I was running for the first 2.5 years. You just need aboard with a PCMCIA slot on it.
    That card is also capable of bit-perfect as well via the optical out.
    Jan Bennett
  2. #102
    Low Bitrate emperorjj1's Avatar
    Jun 2007
    Las Cruces NM
    cool I think with the dvd audio support and 5.1 its perfect for me... now to find a compatable mobo
  3. #103
    May 2007
    hey guys, have a car pc and the sound quality is ****. been told to get a usb soundcard. now at the moment i have 4 speakers, 4 tweaters and a twin sub. i want to run the sound from the pc through an rca cable as i have the cables already installed and thats what i'm using at the moment. Now i have no idea what i'm looking at so could someone give me some pointers on what they would recommend.
  4. #104
    Apr 2007
    So this External Sound card thing is a real challenge unless you want to spend a lot on some kind of mixer? I'm looking at the M-Audio Firewire solo. Has anybody tried this? Are there issues with input/output line levels? It has two unbalanced inputs and two balanced outputs. Does this mean I could do HD radio and XM on the inputs? I am installing in a BMW E46 with stock amp & speakers. Stock amp expects balanced inputs, which I was going to do with a SVEN4, but the Solo has two balanced outputs. Could I use these as front/rear channels with a TRS to RCA adapter? or are these mono outputs that I would have to use as left & right channels (per software settings) and then split into front/rear. Forgive the noob questions. I'm close to doing the install, but would really like the sound solution at least designed. BTW I'm using a mac mini running XP.
    Thanks for any advice and sorry to be so long winded.
  5. #105
    Raw Wave Defiler's Avatar
    Jan 2002
    Temple Terrace, Fl.
    I found a couple I will add to the wiki since this list is getting too big for the first post.
    Aura MR62 (F and R)
    My Current MP3s
    IamDefiler.com
  6. #106
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    Quote Originally Posted by Defiler View Post
    Cool thanks. I did some rearranging and I still need to move the old ones over too.
  7. #107
    Feb 2008
    Ok i'm still confussed ...is there a good usb sound card that will work with carPc? 1ghz cpu and 256 ram? I use a usb creative audigi2 nx ..and i can't play videos because the sound card uses my cpu 100% ..and if i disable eax the cpu si 98% ..so i need a usb sound card that doesn't use my cpu so much and it can give me sound quality 5.1 like usb creative audigi2 nx help plzzzzzz
  8. #108
    Quote Originally Posted by NaMeLeS5 View Post
    Uninstall the old soundcard drivers and the USB drivers for the audigy and reinstall the audigy soundcard.
    I use one with a 1.5ghz via and it's been absolutely fine for me!
  9. #109
    Feb 2008
    Quote Originally Posted by BiG K View Post
    No that's not yet...because you have 1.5ghz cpu and i have 1ghz cpu( so there;s no solusion for me?:?
  10. #110
    _
    Mar 2004
    Little Elm, Texas
    Anyone on here have any experience with the MOTU UltraLite?
    Jan Bennett
  1. My USB/Wifi troubles.
    By JPuma in forum General Hardware Discussion
    Last Post: 09-23-2005, 12:44 PM
  2. Power USB soundcard
    By Goddy in forum Car Audio
    Last Post: 03-02-2005, 02:50 PM
  3. Power USB soundcard
    Last Post: 03-02-2005, 02:22 PM
  4. No Firewire in my BookPC / USB HD??
    By PoBoy in forum General Hardware Discussion
    Last Post: 06-12-2001, 08:38 AM
  5. Handheld + USB Hard Drive := Ultimate MP3 Player
    Last Post: 06-08-2001, 09:22 AM
