Page 2 of 13 FirstFirst 123456789101112 ... LastLast
Results 11 to 20 of 122
Thread: Ultimate USB, Firewire, External Soundcard List
  1. #11
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by jasonsjwou View Post
    Auzentech X-Meridian has 5 Volt output. User replacable Opamps and clocks too.
    If KX project supports it, that would be my answer. I don't know if it does, or if they are working on it.
    It has 8 channel output. Configurable in any way we want..
    ActiveXover, EQ, delay, effects etc all in digital domain... infinitly reconfigurable....
    man...it's great to have home theater pc's taking off like they are. we are reaping the benefits! nice find
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  2. #12
    _
    Mar 2004
    Little Elm, Texas
    That's the same company that I sent an email a while back, here's what I wrote:
    Hi Jan,
    Thanks for sending us feedback and request for next sound card product. All your requests and feedback are taken into serious consideration from our R&D people.
    [Regarding] Currently I'm using the Audigy 2 ZS PCMCIA card with the optical output into my Alpine processor. Ultimately, I'd like to use a sound card, with high voltage RCA outputs direct into my STEG amplifiers. This would only leave me with the need to find a computer program that includes 1/3 octave 31 band eqs, as well as time alignment and cross over points.
    [AZT] We are actually planning on development for RCA outputs (however, it might not be the perfect product as per your description above). In order for us to provide you with precise base management in the PC system, we will need to request C-Media (our chipset developer) for further R&D, thus, we cannot confirm at this time whether this is possible as it depends on C-Media’s willingness for further improvement on their chipset.
    [Regarding] There are a few of us on the mp3car.com forums that are constantly searching for an option like I have mentioned. For some, the solution is to use a cheap USB DAC, like the Silverstone unit. However, there is research that proves that USB DACs can be prone to much jitter. All of the USB DACs I've found, however, only have one set of RCA outputs.
    [AZT] If the USB DAC is using 5V 500A USB bus power, it will not be possible to be free from the jitter. Even if you use the 12V from your car, the system will not be secure depending on the Car battery, cigar jack, and the related circuit board, therefore, you will need to secure these by checking testing, and making some changes in the car. This is however, a great potential product that you have brought up to us. With the current USB chipset that C-Media has, we would not be able to develop such product. However, we can consider it once C-Media release their USB 2.0 chipset.
    [Regarding] Would your company possibly be interested in developing a sound card along these lines? Possibly a PCMCIA card, with a tail of RCA outputs with high voltage outs? Or possibly a USB card with these features? Else, a PCI card for use in either small or no computer case?
    [AZT] For PCMCIA card, VIA and CL have solutions, but for notebook PC, the PCMCIA is outdated, therefore, we are not considering any development based on this.
    We have already road map for USB sound adaptor or DAC planned for next year.
    We do not have plan for LP type PCI card at this time.
    Your feedback helped us understand the Car audio market better and we will definitely look into this market further.
    We appreciate your support for our company and product.
    Sincerely,
    Stephane Bae
    AuzenTech, Inc. (www.auzentech.com)
    tel 408.727.6212/ fax 408.727.6275/ cell 650.861.2755
    Thought some might find it interesting.
    Jan Bennett
  3. #13
    _
    Mar 2004
    Little Elm, Texas
    can you show me where you read up about all of this?
    I'll send them another email as well, need to know if it can support ASIO.
    Jan Bennett
  4. #14
    Low Bitrate jasonsjwou's Avatar
    Sep 2006
    KOREA,USA,AUSTRALIA
    The Auzentech X-Meridian Website
    http://www.auzentech.com/compare.html
    It says "5Vrms (Differential DAC output with gain adjustment / approximately full swing from +/- 8V dual power supply)" - This should be good enough for Car Amp.
    The potential for KX project is enormous, especially for CarPC Audio scene. It's real light on processor resource, infinitly configurable so all the ActiveXOver, GEQ,PEQ,Phase/Delay, Surround, etc can be done in digital domain. The KX project:
    www.kxproject.com
    http://www.driverheaven.net/forumdis...?s=&forumid=67
    I can't find it now, but I read it somewhere that they are working to get the C-Media CMI-8788 chipset (X-Meridian's chip) to work with the KX project. I might be wrong.
    The best soundcard that currently works with the KX project is SoundBlaster Audigy 2 ZS (SB0350) series. SB X-FI's are not compatible with the KX Project, because Creative is not willing to share the architecture with the KX developer. (or something along that line)
    REDGTi, I am sure you know all about KX project, but it might be a good read for someone new.
  5. #15
    _
    Mar 2004
    Little Elm, Texas
    I've been reading up on the KX Project, but I was not aware that it has the ability to do X-over functions and all that other jazz...is that truely the case?
    Jan Bennett
  6. #16
    Sep 2006
    KOREA,USA,AUSTRALIA
    I first found KX project in DIYAUDIO, looking for a way make a 3 way Active crossover using a Professional grade external Soundcard ($399 M-Audio 1010 with 8 XLR outputs).. Then I found that people's been doing this for years ahead of me.
    There are whole bunch of people who has their SB card configured as a 3 way ActiveXover with EQ's and notch filters and etc. Some added a Room EQ compensation with a measurement mic. I think majority of the people using KX are the speaker crossover designers, because it's so easy to change configuration of the XOver and apply EQ and all the other Jazz.
  7. #17
    _
    Mar 2004
    Little Elm, Texas
    have you looked into the 1010LT at all?
    http://www.m-audio.com/products/en_u...10LT-main.html
    It looks like it would work for our applications.
    I was also looking at the 1010 but being that it's rack mount, I don't really have a place for it in this install.
    I was also considering this:
    http://www.esi-pro.com/viewProduct.php?pid=6&page=3
    Thoughts on that one?
    Jan Bennett
  8. #18
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    All this info is great! I want to get the external sound card options updated with more details and then also do a PCI card section. Please be patient. There is sooo much info it takes a while to organize. if anyone sees any other cards not on the list I will add them.
    xgc
    xgc is offline
    Aug 2006
    florida
    I would like to add, dont think anyone is using a emu 0404 pci card. I do studio work been playing music all of my life and upgraded my studio computer from the emu to m-audio and put my emu in the truck.. very impressed with the sound in there now.. wasnt that bad before was using 5.1 usb... but now its unbelievable.. everyone that listens to it is blown away.. but as the post earlier in this thread says.. it is cpu hungry needs a least a 1.3 and says it can run on a 1 ghz but I wouldnt recommend it.. hope this helps someone...
  10. #20
    Sep 2006
    KOREA,USA,AUSTRALIA
    RedGTi,
    I searched for two days (digging my old computer drives and the CDROM archives) and I just cannot find the website archives where they used the M-Audio 1010 (External version AND LT version) for a software driven Active Xover with EQ and Notch filter and etc.
    I'll be keep looking. I know the quality of the M-Audio 1010 series is really good. If I remember correctly, people at M-Audio were more than willing to share their driver library so people can modify it. What I'd really liketo do, is to use the Auzentech X-Meridian PCI 7.1 card with KX project. The X-Meridian has user replacable OpAmps... yeah Audiophile grade Opamps (8 of them) can be just as expensive as the card itself, but it will make good improvement..
    Meanwhile, a viable solution today (where there are lots of people actually doing this) is to use a SB Audigy 2 (SB0350) with Audiocontrol LC8 8 channel Line Driver.
    SB0350 is a 7.1 channel card, which means we have 8 channels to play with.
    Sonic quality is not as good as the best of the best external soundcard (they call these Audiocards).... but I think it is quite usable.
    So, configure it as 3 way fronts (tweet, mid, woofer) and a 2 subs in rear so that's 8 channels. That should be good enough.
    BTW
    Do you know if anyone makes a car amp with balanced input?
  1. My USB/Wifi troubles.
    By JPuma in forum General Hardware Discussion
    Last Post: 09-23-2005, 12:44 PM
  2. Power USB soundcard
    By Goddy in forum Car Audio
    Last Post: 03-02-2005, 02:50 PM
  3. Power USB soundcard
    Last Post: 03-02-2005, 02:22 PM
  4. No Firewire in my BookPC / USB HD??
    By PoBoy in forum General Hardware Discussion
    Last Post: 06-12-2001, 08:38 AM
  5. Handheld + USB Hard Drive := Ultimate MP3 Player
    Last Post: 06-08-2001, 09:22 AM
