Page 5 of 13 FirstFirst 12345678910111213 LastLast
Results 41 to 50 of 122
Thread: Ultimate USB, Firewire, External Soundcard List
  1. #41
    Low Bitrate PSYKO_Inc's Avatar
    Oct 2006
    Fairfield, CA
    Here's a dirt-cheap 2-channel USB soundcard to add to the list:
    http://www.newegg.com/product/produc...82E16829612001
    I'm thinking about picking one up just to run into the AUX input of my headunit as a temporary setup (till I get everything else ironed out) then upgrading later on. It's cheap enough and has received good reviews at Newegg thus far; how bad can it be?
    -Jay
    1997 Chevy S-10, ext. cab
    CarPC Progress: 75% - Functional, but not quite finished.
    Check out my progress.
  2. #42
    _
    Mar 2004
    Little Elm, Texas
    Front Tweeters = 2
    Front Midrange = 2
    Front Midbass = 2
    Sub = 2 provided you only go with a single sub amp
    That puts you at the limit of the card, can't go with any more.
    And that's provided you can completely remap what each output does, not sure on that yet.
    Jan Bennett
  3. #43
    Low Bitrate bungee91's Avatar
    Aug 2006
    South of Chicago, IL
    Everything I would ever want and more.... Women!!...LOL
    Thank you though for breaking it down for me, wasn't sure if it was some akward way of doing it with sound cards.
    Also I am not going to find out some crap about 5vRMS balanced and really 2.5 unbalanced right? I wouldn't think so, but I would hate to assume.
    I am just waiting for newegg to carry it, and I can finally order the wishlist I have been waiting on.
  4. #44
    Maximum Bitrate Ruffy's Avatar
    Sep 2006
    Georgia
    Adding this since it isnt on the list
    M-Audio Fastrack Pro : MSRP $249.99, Street Price $200
    -ASIO support with monitoring
    -24-bit/96kHz
    -4 unbalanced outputs (RCA)
    -2 balanced outputs (¼” TRS)
    -S/PDIF supports pass-through of AC-3/DTS
    -Powered via USB or wallwart
    -SNR -103dB, A-weighted
    -THD+N 0.005% (-86dB) @ -1dBFS, 1kHz
    -Master output level control
    A "card" im considering. Still leaning towards the Emu 404 usb
    if only they had 4-6 channels otuput
  5. #45
    Oct 2006
    Hate to restart this thread, but has anyone tried using a card where they can achieve 2 seperate outputs from 2 seperate programs granted their computer is powerful enough. For instance if I had sound from a movie going to headphones in the backseat and still have mp3's playing up front?
    The E-MU interfaces are not very processor friendly. We have an EMU-1820 that sounds amazing, but is slow with anything under 1.5Ghz.
  6. #46
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    I check back in now and then to update the list so don't worry about it. That is a good question you ask. You might want to post it as a new thread. I wonder if you could do it with an creative labs and the kx drivers. Otherwise you would need a PRO card that maybe you can re-route signals to.
  7. #47
    Sep 2006
    Georgia
    Quote Originally Posted by comet28024 View Post
    laptop has a 2ghz AMD 3000+ CPU so IM not really worried about cpu power
  8. #48
    _
    Mar 2004
    Little Elm, Texas
    http://www.motu.com/products/motuaudio/ultralite/
    This card might want to be added.
    If I can't get the X-Meredian to do what I need it to do, I'll probably be stepping up to the Ultralite.
    1/4" jacks are a plus!
    one benefit, it seems, to this sound card, is that it has mic inputs built in that act as a preamp with phantom power. If you're going to be using True RTA in the car, this means that you don't need to purchase a seperate preamp for your mic and find somewhere to mount it in the car...if you so desire. Me Likey!
    Jan Bennett
  9. #49
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    can you go fully active with that motu? i.e. does it have x-over capabilities?
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  10. #50
    Sep 2006
    Only with ASIO and VST plugins like Frequency allocator, but not by itself.
  1. My USB/Wifi troubles.
    By JPuma in forum General Hardware Discussion
    Last Post: 09-23-2005, 12:44 PM
  2. Power USB soundcard
    By Goddy in forum Car Audio
    Last Post: 03-02-2005, 02:50 PM
  3. Power USB soundcard
    Last Post: 03-02-2005, 02:22 PM
  4. No Firewire in my BookPC / USB HD??
    By PoBoy in forum General Hardware Discussion
    Last Post: 06-12-2001, 08:38 AM
  5. Handheld + USB Hard Drive := Ultimate MP3 Player
    Last Post: 06-08-2001, 09:22 AM
