Ultimate USB, Firewire, External Soundcard List
Its hard to keep up with all the sound cards since they change so rapidly. This is just a list of External USB and Firwire cards available. Do not confuse these with DACs. For a good section on DAC see DAC stickey.
Pros of using a External Card
-Low noise
-Better sound quality (>90dB S/N) than onboard sound having a Signal to Noise ratio around 76-90dB.
Cons
-Bandwidth hungry, lots of CPU usage depending on computer (10-50% depending on processor speed).
-Some cards have hibernation issues (search because this is system dependent)
I wanted to compile a list of all sound cards old or new for those who want options. I will update as much as possible with all the following info:
- Maunfacturer/Model
- Price
- Basic features and specs
- Links on info
It is broken down into 2 groups:
- consumer products (products you can find locally or easliy on the internet)
- Professional products (geared more towards audiophile/music production quality found usually in Pro Audio type stores) .
Please be patient as I compile as much info as possible and condense it for easy reading. And here we go...
Consumer Level
Creative Labs
• Live! ($30-50 Still available)SPECIFICATIONS
- 16/24bit @ 48kHz in 5.1 mode and up to 96kHz in stereo mode.
- SPDIF out with up to 24-bit at 96 kHz quality.
- USB 1.1 Bus powerd
- Can run 5/6 channel stereo with CMSS management
• Audigy 2NX ($100 hard to find/no longer in production)SPECIFICATIONS
- Front/Rear/Center/Sub 102dB @ 2Vrms
- Headphone/Side 96db @ 2Vrms
- 24-bit/96kHz ADC for various analog inputs
- 24-bit/96kHz DAC for up to 7.1 channels output
- S/PDIF format input signal of up to 24-bit/96kHz quality
- Can run up to 8 channel stereo using their CMSS management
- USB 1.1/2.0 External power supply needed
Turtle Beach
• Micro ($30)• Amigo ($50)• Roadie ($80) Available @ MP3CAR store HERE- 5.1/7.1 Analog out/Digital out (Analog 2,4,6 or 8 Channel)
- Can run in 2/4/6/8 channel stereo mode
- 10 Band EQ (individual speaker)
Xitel
• HiFi Link ($50)
• Pro HiFi Link ($80-100)ADS
• RDX-150 ($35-50)
ESI
• Gigaport AG ($200)
- -8 x RCA Analog Output (8 x 24 bit D/A Converter)
Audiotrak
• Maya EX ($???)
Zalman
• ZM-RSSC ($50-70)
- Input: 1 USB connection port (USB 1.1/2.0 compatible)
- Output: three 3.5 stereo jack (Front, Rear, Center/Subwoofer)
- one digital port (both optical and coaxial, capable of outputting 5.1 Ch.)
- Sampling Rate: 24bit 96KHz D/A & A/D converter
SIIG
• USB SoundWave 7.1 ($17-35)
- SIMULATED 7.1 sound (2 channel out)
M-Audio
• Sonica (Old model $80???)
• Transit ($100)
- mobile 24-bit/96kHz USB audio upgrade
- Optical digital output allows AC-3 and DTS pass-through
- Optical input (not sure if it digital signal with pass thru to analog out)
- Maximum output Voltage 0dBV
AOC
• USB-AUDIO 5.1($16)
- SIMULATED 5.1 sound (2 channel out)
Pro Audio
Behringer
• U-CONTROL UCA202 ($30 price indicates possible lower quality than "Pro")M-Audio
• Fast Track ($130)• MobilePRE ($180)• Fastrack Pro ($200-250)- ASIO support with monitoring
- 4 unbalanced outputs (RCA)
- 2 balanced outputs (¼” TRS)
- S/PDIF supports pass-through of AC-3/DTS
- Powered via USB or wallwart
• Firewire Audiophile (Firewire connection) ($350)- 4 Channel in 6 Channel out (analog)
• Firewire 410 (Firewire connection) ($400)- 4 Channel in 10 Channel out (Analog)
- 107dB S/N @ 20-40kHz +/-1dB
EMU (Creative Professional)
• E-MU 0202 (???)
• E-MU 0404 ($200)- Sample Rates: 44.1, 48, 88.2, 96, 176.4, 192kHz from internal crystal (no sample rate conversion)
- USB 2.0 Hi-Speed: - Full 24-bit resolution at all sample rates
- - 4 in/4 out channels from 44.1-96kHz
- - 2 in/2 out channels from 176.4-192kHz
- Anti-Pop speaker protection: Minimizes noise during power on/off
- Ultra-low jitter clock subsystem: < 500ps RMS in PLL mode
- (48kHz, Coaxial S/PDIF Sync)
- Analog Line Outputs (2) Balanced, AC-coupled, 2-pole low-pass differential filter
- Level (auto detect): - Professional: +12dBV max (balanced)
- - Consumer: +6dBV max (unbalanced)
- Frequency Response (20Hz - 20kHz): 0.06/-.035dB
- Dynamic Range (1kHz, A-weighted): 117dB
- Signal-to-Noise Ratio (A-weighted): 117dB
- THD+N (1kHz at -1dBFS): -100dB (.001%)
- Stereo Crosstalk (1kHz at -1dBFS): < -114.5dB
- S/PDIF: - 2 in/2 out coaxial
Edirol/Roland
• UA-25 ($240)- Matched low noise A/D D/A converters
RME
• Firewire 400 (firewire connection)($1000)
- 1 Digital In/1 Digital Out
- Sample rate up to 192 kHz
Terratec
• Aureon 7.1 (Firewire connection)(230 Euros)
- -8 Analog Outs 24bit/192kHZ
- -Analog Line Input 24bit/96kHZ
- -Optical Digital S/P DIF Input (TOS Link) 24 bit/96 kHz
- -Optical Digital S/P DIF Output (TOS Link) 24 bit/96 kHz
- -Buspowered or optional power supply
MOTU
• Ultralite (Firewire connection)$600
- -14 Analog Balanced/Unbalanced Outs 1/4" jacks @ 24bit/96kHZ
- -COAX Digital S/P DIF Input/Output 24 bit/96 kHz
- -48V Phantom power for Mic Input
