+ Reply to Thread
Page 1 of 13 1234567891011 ... LastLast
Results 1 to 10 of 122
Thread: Ultimate USB, Firewire, External Soundcard List
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    Post Ultimate USB, Firewire, External Soundcard List
    Its hard to keep up with all the sound cards since they change so rapidly. This is just a list of External USB and Firwire cards available. Do not confuse these with DACs. For a good section on DAC see DAC stickey.
    Pros of using a External Card
    -Low noise
    -Better sound quality (>90dB S/N) than onboard sound having a Signal to Noise ratio around 76-90dB.
    Cons
    -Bandwidth hungry, lots of CPU usage depending on computer (10-50% depending on processor speed).
    -Some cards have hibernation issues (search because this is system dependent)
    I wanted to compile a list of all sound cards old or new for those who want options. I will update as much as possible with all the following info:
    1. Maunfacturer/Model
    2. Price
    3. Basic features and specs
    4. Links on info
    It is broken down into 2 groups:
    • consumer products (products you can find locally or easliy on the internet)
    • Professional products (geared more towards audiophile/music production quality found usually in Pro Audio type stores) .
    Please be patient as I compile as much info as possible and condense it for easy reading. And here we go...
    Consumer Level
    Creative Labs
    Live! ($30-50 Still available)
    SPECIFICATIONS
    • 16/24bit @ 48kHz in 5.1 mode and up to 96kHz in stereo mode.
    • SPDIF out with up to 24-bit at 96 kHz quality.
    • USB 1.1 Bus powerd
    • Can run 5/6 channel stereo with CMSS management
    Audigy 2NX ($100 hard to find/no longer in production)
    SPECIFICATIONS
      • Front/Rear/Center/Sub 102dB @ 2Vrms
      • Headphone/Side 96db @ 2Vrms
      • 24-bit/96kHz ADC for various analog inputs
      • 24-bit/96kHz DAC for up to 7.1 channels output
      • S/PDIF format input signal of up to 24-bit/96kHz quality
      • Can run up to 8 channel stereo using their CMSS management
      • USB 1.1/2.0 External power supply needed
    Turtle Beach
    Micro ($30)
        • Analog 2 channel out
        • SPDIF Out
        • USB bus powered
    Amigo ($50)
        • SPDIF out
        • Mic IN
        • Volume Control
        • USB bus powered
    Roadie ($80) Available @ MP3CAR store HERE
        • 5.1/7.1 Analog out/Digital out (Analog 2,4,6 or 8 Channel)
        • Can run in 2/4/6/8 channel stereo mode
        • 10 Band EQ (individual speaker)
        • Speaker Delay/Position
        • Environments
        • USB bus powered
    Xitel
    HiFi Link ($50)
        • Analog Output Only
        • 90db SNR @ 1Vrms
        • 20bit DAC
        • USB bus powered
    Pro HiFi Link ($80-100)
        • Analog/Digital Outputs
        • RCA/Optical/Coax
        • 90db SNR @ 1Vrms
        • 20bit DAC
        • USB bus powered
    ADS
    RDX-150 ($35-50)
        • 16 bit DAC
        • 96 dB S/N
        • Analog/Digital Ouput
    ESI
    Gigaport AG ($200)
        • -8 x RCA Analog Output (8 x 24 bit D/A Converter)
        • - SPDIF Optical Output
        • - One Headphone Out
    Audiotrak
    Maya EX ($???)
    5.1 Sound
    Zalman
    ZM-RSSC ($50-70)
        • Input: 1 USB connection port (USB 1.1/2.0 compatible)
        • Output: three 3.5 stereo jack (Front, Rear, Center/Subwoofer)
        • one digital port (both optical and coaxial, capable of outputting 5.1 Ch.)
        • Chipset: Sonix 5.1 sound
        • Sampling Rate: 24bit 96KHz D/A & A/D converter
    SIIG
    USB SoundWave 7.1 ($17-35)
        • SIMULATED 7.1 sound (2 channel out)
        • 10 BAND eq
        • Speaker position
        • USB bus powered
    M-Audio
    Sonica (Old model $80???)
    Transit ($100)
        • mobile 24-bit/96kHz USB audio upgrade
        • Optical digital output allows AC-3 and DTS pass-through
        • Optical input (not sure if it digital signal with pass thru to analog out)
        • 104dB Dynamic Range
        • 100dB S/N
        • Maximum output Voltage 0dBV
        • ASIO compatible
    AOC
    USB-AUDIO 5.1($16)
        • SIMULATED 5.1 sound (2 channel out)
        • USB bus powered
    Pro Audio
    Behringer
    U-CONTROL UCA202 ($30 price indicates possible lower quality than "Pro")
        • Analog RCA Ouput
        • 2dBV / 400ohm unbalanced
        • Digital Optical Out
        • Line Input
        • Headphone Out
    M-Audio
    Fast Track ($130)
        • 2 Channel Analog
        • 24bit/48kHz
        • USB bus powered
        • ASIO compatible
    MobilePRE ($180)
        • 2 Channel Analog
        • 16bit/48kHz
        • USB bus powered
        • ASIO compatible
    Fastrack Pro ($200-250)
        • ASIO support with monitoring
        • 24-bit/96kHz
        • 4 unbalanced outputs (RCA)
        • 2 balanced outputs (¼” TRS)
        • S/PDIF supports pass-through of AC-3/DTS
        • Powered via USB or wallwart
        • SNR -103dB, A-weighted
    Firewire Audiophile (Firewire connection) ($350)
        • 4 Channel in 6 Channel out (analog)
        • Digital Ouput
        • 24 bit/96kHz
        • 106 dB S/N
        • ASIO support
    Firewire 410 (Firewire connection) ($400)
        • 4 Channel in 10 Channel out (Analog)
        • Digital Ouput
        • 24 bit/96kHz
        • 107dB S/N @ 20-40kHz +/-1dB
        • ASIO support
    EMU (Creative Professional)
    E-MU 0202 (???)
    E-MU 0404 ($200)
        • Sample Rates: 44.1, 48, 88.2, 96, 176.4, 192kHz from internal crystal (no sample rate conversion)
        • USB 2.0 Hi-Speed: - Full 24-bit resolution at all sample rates
        • - 4 in/4 out channels from 44.1-96kHz
        • - 2 in/2 out channels from 176.4-192kHz
        • Anti-Pop speaker protection: Minimizes noise during power on/off
        • Ultra-low jitter clock subsystem: < 500ps RMS in PLL mode
        • (48kHz, Coaxial S/PDIF Sync)
        • Analog Line Outputs (2) Balanced, AC-coupled, 2-pole low-pass differential filter
        • Level (auto detect): - Professional: +12dBV max (balanced)
        • - Consumer: +6dBV max (unbalanced)
        • Frequency Response (20Hz - 20kHz): 0.06/-.035dB
        • Dynamic Range (1kHz, A-weighted): 117dB
        • Signal-to-Noise Ratio (A-weighted): 117dB
        • THD+N (1kHz at -1dBFS): -100dB (.001%)
        • Stereo Crosstalk (1kHz at -1dBFS): < -114.5dB
        • Digital I/O:
        • S/PDIF: - 2 in/2 out coaxial
        • - 2 in/2 out optical
    Edirol/Roland
    UA-25 ($240)
        • 24bit/96kHz Sampling
        • Balanced outputs
        • Digital outputs
        • Matched low noise A/D D/A converters
    RME
    Firewire 400 (firewire connection)($1000)
        • Analog 6 IN/6 Out
        • 1 Digital In/1 Digital Out
        • 110dB Dynamic Range
        • 100 dB S/N
        • Sample rate up to 192 kHz
        • Output Level +2 dBV
    Terratec
    Aureon 7.1 (Firewire connection)(230 Euros)
        • -8 Analog Outs 24bit/192kHZ
        • -Analog Line Input 24bit/96kHZ
        • -Optical Digital S/P DIF Input (TOS Link) 24 bit/96 kHz
        • -Optical Digital S/P DIF Output (TOS Link) 24 bit/96 kHz
        • -Buspowered or optional power supply
        • -Windows XP only
    MOTU
    Ultralite (Firewire connection)$600
        • -14 Analog Balanced/Unbalanced Outs 1/4" jacks @ 24bit/96kHZ
        • -COAX Digital S/P DIF Input/Output 24 bit/96 kHz
        • -48V Phantom power for Mic Input
        • -ASIO Compatible
    FLAC XC-C30's Avatar
    Jun 2006
    Abele, Belgium
    behringer and pro-audio in the same sentence, uhmmmmm
    Xenia & Isabelle, totally in love!
    'T SQiekenkot: VOLVO 740GL 2.3
    CarPC: none at the moment
    CLARION HX-D2
    CLARION APA4300HX => Fountek NeoCd1.0 + TB W4-1337SD
    CLARION APA4300HX => CSS Trio8
    CLARION APA2100 => Dayton IB385-8
    Sep 2006
    Quote Originally Posted by IC-C30 View Post
    hahaha. I couldn't agree with you more, but that is where you can find it... Pro audio stores. Price would indicate it's not as "pro" as they say. I could move it to the "consumer" group if people might get confused.
    Edit: I decided to clarify my wording and grouping techniques.
    Jun 2006
    Abele, Belgium
    price is'n t always good indication. in Germany the edirol UA-EX one is cheaper than a turtlebeach roadie
    CLARION HX-D2
    Sep 2006
    ...and also don't forget...Just because it was engineered in Germany doesn't mean it's quality.
    (It's ok I work for a German owned company) hehehehe
    Jun 2006
    Abele, Belgium
    one other thing, most of us can't use the EMU cards, because of slower cpu. those cards requier a 1.4GHz cpu....
    CLARION HX-D2
    _
    Mar 2004
    Little Elm, Texas
    Here is an incredible option:
    http://www.rme-audio.de/english/hdsp/hdsp9632.htm
    Take a look at the info on that page and see where you can add on modules that will allow for multiple outputs.
    I'm currently looking heavily into this option.
    Also, all of the cards in the Audiotrack lineup appear to be good options for people on this board. Might as well link entirely to their site.
    Also, for the benefit of those who are willing to spend the money to get good, very high quality cards, be sure to post them up, even if they seem to be out of your price range.
    EDIT:
    PS: one thing I've found incredibly helpful is to link to the page on the manufacturers web site for the particular product. It makes research a lot easier.
    Jan Bennett
    Jun 2006
    Abele, Belgium
    http://www.audiotrak.net/mayaex.htm double the cost of a turtle beach roadie, but multiple output also, which the roadie doesn't have.
    only 16bit though
    CLARION HX-D2
    _
    Mar 2004
    Little Elm, Texas
    http://www.synthzone.com/sndcard.htm
    Good place to find other options.
    If someone has the time, they could make a GREAT list using this web site.
    http://sounden.terratec.net/index.php?
    Great options.
    The Aureon 7.1 FireWire looks like a great option. Going to email them and see if I can find out more (like voltage outs). - found out through the manual that it's 2v outputs, which would work for many people on this site, however, I'd like a little more.
    One of the main issues I'm running into, and I'm sure others will or have too is that on these surround sound cards, I need to know how the unit handles the sound. I'm not wanting surround sound in my car. I'm wanting stereo sound, how would I go about changing the outputs of the card to be what I need/want them to be.
    For instance, take a 7.1 card.
    You have RCA channels for Right and left for front, rear, and surround (that's 6 channels right there), then you have a center, then a sub, for 8 total channels. However, if I don't want to process the sound into 7.1, but would rather take the front for tweeter, rear for mid-bass, surround for mid-range, and sub for sub.
    Going to see if I can get that info as well.
    Jan Bennett
    Low Bitrate jasonsjwou's Avatar
    Sep 2006
    KOREA,USA,AUSTRALIA
    Auzentech X-Meridian has 5 Volt output. User replacable Opamps and clocks too.
    If KX project supports it, that would be my answer. I don't know if it does, or if they are working on it.
    It has 8 channel output. Configurable in any way we want..
    ActiveXover, EQ, delay, effects etc all in digital domain... infinitly reconfigurable....
+ Reply to Thread
  1. My USB/Wifi troubles.
    By JPuma in forum General Hardware Discussion
    Last Post: 09-23-2005, 12:44 PM
  2. Power USB soundcard
    By Goddy in forum Car Audio
    Last Post: 03-02-2005, 02:50 PM
  3. Power USB soundcard
    Last Post: 03-02-2005, 02:22 PM
  4. No Firewire in my BookPC / USB HD??
    By PoBoy in forum General Hardware Discussion
    Last Post: 06-12-2001, 08:38 AM
  5. Handheld + USB Hard Drive := Ultimate MP3 Player
    Last Post: 06-08-2001, 09:22 AM
