Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: need more power to turn on amp
  1. #11
    Constant Bitrate ZtH01's Avatar
    Jan 2006
    Mankato, MN
    Quote Originally Posted by scott_fx View Post
    lol... thank you
    We're not trying to be difficult. Just throwing out something to try that is very easy, and free. I don't know about other people's installls, but I already have a ton of relays in use, there's like six for my alarm alone. They're big and bulky, and if I can get away from using one, I will...
    -ZtH01
    "It's my belief that my big balls should be held every night"
  2. #12
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    i think the person i quoted was refering to the delay circuit. sure, try the other way first and if it works, great.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  3. #13
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    Yup, exactly. I was referring to the 'just get a delay circuit'. Obviously the cheapest way is to hook your remote wire to the ACC of the car. If you don't get a thump, then you're golden.
  4. #14
    Nov 2006
    Thornhill eh?
    thanks, as i said im an electronics noob, this relay looks the best idea.
    btw currently i am running the sub on a switched source howver whenever i run the computer into the sub i get the big thump wich i don't get from my doors. im currently just running the HU cause i don't have a monitor yet for the comp.
  5. #15
    Registered User vfinterceptor's Avatar
    Oct 2005
    up-the-hill-turn-left-by-the-big-tree
    Something seems a little off there.
    Most amps require .5v or less for the "on" signal.
    Check your setup.
    The thump in the sub is a common problem. The only way I know of to deal with it is to delay the amp power on signal (however you chose to do it) until after windows has done it's thing.
    Cheers
    BJ
  6. #16
    May 2005
    Conyers, GA
    Quote Originally Posted by vfinterceptor View Post
    Check your setup.
    No, most amps require 12v, but usually only .5A (or 500mA). I've seen plenty of threads saying the M2 doesn't put out a lot of amperage on the amp-turn on and that a relay is required to ensure it works correctly.
  7. #17
    Oct 2005
    Ooops.
    Got my "v" and my "a" mixed up!
    Been happening a bit lately!
    Cheers
    BJ
  8. #18
    FLAC J187's Avatar
    Nov 2004
    Boston
    Ooops.
    Cheers
    BJ
    Just don't confuse your V&A with T&A and your alright...
    Its not the cards you're dealt, its how you play the hand!
    Quote Originally Posted by ryuandwings View Post
    Where can I get a roll of tin foil?
    I been looking for that all over the net, but I can't find it.
    Please help.
  9. #19
    Oct 2005
    Quote Originally Posted by J187 View Post
    Think about the "v" part a little more and you'll get the joke.........
    Cheers
    BJ
  1. Amp has no power.. Help! Not Newbie.
    By ziljin in forum Car Audio
    Last Post: 06-28-2006, 09:59 AM
  2. Replies: 2
    Last Post: 02-26-2006, 10:32 PM
  3. Amp Delay Turn On Solution?
    By thenick100 in forum Car Audio
    Last Post: 01-31-2006, 01:12 PM
  4. Amp turn on problem.
    By RaZor in forum Car Audio
    Last Post: 07-13-2005, 03:20 PM
  5. cant get power to amp
    By Murphy3603 in forum Car Audio
    Last Post: 10-28-2004, 02:43 AM
