Results 1 to 9 of 9
Thread: do you NEED an amp?
    Mar 2007
    do you NEED an amp?
    I would like to run audio through my stock E46 (with Harman kardon) speaker/sound system. This is seeming to be the tricky bit at the mo...
    My budget doesnt really allow for any extra audio equiptment (other than connector leads etc), but quite a few use an amp in their install (along with SVEN-4).
    Can i cut out the necessity of an amp?
    [ 330ci sport - 19" M3 reps, mtech-2, clubsport splitters, angel eyes, xenons, full black leather, harman kardon, LED's. ]
    Mar 2006
    Colorado, but Canadian!
    Can you cut out the neccessity of a brain?
    Nope.
    Even a HU has an amp. Teeny tiny, but it is an amp. And you can get a refurb off egay for $30-$40 shipped. Same quality as a crappy HU's built in.
    1.9in x 2.9in -- 47mm x 73mm
    FLAC XC-C30's Avatar
    Jun 2006
    Abele, Belgium
    Quote Originally Posted by 2k1Toaster View Post
    Nope.
    Are you sure? I once saw a documentary about someone that lost an arm... Got a bionic, and it was controlled by a special designed chip.....
    Xenia & Isabelle, totally in love!
    'T SQiekenkot: VOLVO 740GL 2.3
    CarPC: none at the moment
    CLARION HX-D2
    CLARION APA4300HX => Fountek NeoCd1.0 + TB W4-1337SD
    CLARION APA4300HX => CSS Trio8
    CLARION APA2100 => Dayton IB385-8
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    it may be possible if your stock setup has external amps or you keep the stock head unit and go aux in. you can find 4 chan amps on ebay for under $100 so you may need to save up a little longer but it's not out of reach.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Mar 2006
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    I have no idea what an E46 is, but usually Harmon/Kardon systems are amped. You'd best check a forum specifically for your car to see if there's anyway to bypass the headunit and use the amp directly.
    Mar 2006
    bmw?
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    Yep BMW. If your radio has a CD changer option, you might be able to use a car2pc adapter to get aux in and computer control from your HU. Or there are other adapters if you aren't connecting a computer.
    Jun 2006
    Abele, Belgium
    www.e46fanatics.com EVERY BMW driver should know this site, especially e46 drivers.
    CLARION HX-D2
  1. Replies: 38
    Last Post: 11-30-2010, 06:04 AM
  2. Engine Noise due to ground loop or amp?
    By matt11601 in forum Car Audio
    Last Post: 08-26-2009, 09:38 PM
  3. Replies: 6
    Last Post: 03-20-2007, 11:16 PM
  4. Replies: 3
    Last Post: 12-07-2004, 07:34 PM
