Results 1 to 3 of 3
Thread: Fabrication and Speakers
    Apr 2007
    hey guys im kinda new here and i have a couple questions before i go ahead and start on my project. any help that you could give would be Great!
    ok well to start i own a 1984 944 Porsche and im redoing the whole sound system.
    1. When it comes to Subs is 2 ohms or 4 ohms better? i understand it measures resistance but not sure which is better.
    2. When buying an AMP do you buy one with an RMS that matches the Subs RMS or do you buy one that Matches the Peak of the Subs? i have decided on buy some Kicker CompVR 07CVR82/(4), they are 200Watts RMS and 400 Peak and im buying 2. Which amp would you recommend?
    Now for the Fabrication Question
    In my Fiberglass sealed enclosers, im planning on having the sub, but would also like to install 1 speaker in on also. would having a speaker and a sub in the same box mess with each other. i know the sub presses alot of air where as a speaker doesn't. (they would be in the same box and there would be only the one compartment for it, not 2 seperate compartments in the encloser.
    Thanks alot for the help!
    Elsewhere
    Moved to Car Audio.
    This forum is dedicated to CarPCs and installing them in your car.
    The car audio forum is dedicated to integrating your car audio system with your CarPC.
    For specific questions related to car audio equipment systems that do not include CarPCs, I would recomend checking out car audio specific forums:
    http://www.elitecaraudio.com
    http://www.carsound.com
    http://www.caraudioforum.com
    http://forum.sounddomain.com
    http://www.realcaraudio.com
    http://www.carstereo.com
    http://www.caraudiomag.com
    http://www.termpro.com
    http://www.the12volt.com
    http://www.talkaudio.co.uk
    http://www.caraudiosecurity.com
    et. al.
    There is a chance that someone on here might have an answer for you, I would just hate for you to wait around for it when I know you could get an answer much quicker on a dedicated forum.
    Good luck.
    How about the Wiki?
    Maximum Bitrate boomintrac's Avatar
    Apr 2005
    2hr west of Chicago
    Quote Originally Posted by phil823 View Post
    Theres your answer, Also search is a great tool when used correctly. food for thought.
    Aron
    New Ipad
    Zapco DSP-6SL
    Zapco Reference 360.4: H-Audio Soul, x2 right side
    Zapco Reference 360.4: H-Audio Soul, x2 left side
    Zapco Reference 500.1: JL Audio 10W3V3 Stealth box
  1. 2003 Audi A4 Worklog ~ Puff's Ride
    By Puffanug in forum Worklogs
    Last Post: 05-19-2007, 12:52 AM
  2. Power Requirement and Audio
    By Otterski in forum Newbie
    Last Post: 02-23-2007, 07:24 PM
  3. Replies: 8
    Last Post: 02-04-2007, 01:31 AM
  4. 1997 jetta fabrication
    By djatmospherere in forum Fabrication
    Last Post: 01-23-2006, 07:13 PM
  5. Fake Floor Fabrication Question
    By thecommiser in forum Fabrication
    Last Post: 03-02-2005, 02:21 PM
