Okay, I figured this one out myself, or at least I found another solution. Thought I'd post here in case someone'd have the same problem.
The voltage dropped to around 7volts when I connected both the amp and the PC, which is apparently enough for the OPUS, but not enough for the amp. I solved this by connecting the amp to the remote out on the OPUS, it works GREAT! As a bonus the amp only starts 10seconds after the PC, so no problem with pops either![]()
LinkBack URL
About LinkBacks
