Results 1 to 2 of 2
Thread: Newbie need help wring amp and pc
    May 2006
    Hi,
    my current set up is stock HU, 4ch amp, 2 ch amp and 2x12" woofer on armada, everytime when heat goes up or i listen more than 2 hours the sound gets all distored. i'm thinking it's crappy amp (absolute usa) so i'm going to try different amp(4 ch) see if does samething. what can cause this?
    the 4 ch amp have 4 input and 2 output, so the output i connect the second amp(for woofer) can this be the probem for over heating?
    if i buy other amp which don't have the outputs how can i connect the RCA cables, theres only 4 RCA cables from HU(2 front 2 rear) then how i get the sound for woofer?
    Thanks,
    Jan 2007
    East Central FLA
    Using the 4-channel amp output to drive the second amp (for the woofer) is not the cause of heat and distortion.
    Most quality amps will have a set of outputs, it shouldn't be hard to find a replacement meeting your needs. If, however, you can't find such an amp, then you need to get a set of "Y" adapters and split off either the front or back output from the head unit - one part of the Y goes to the 4-channel, the other part to the sub amp.
  1. PC Motherboard to 1 amp or 2?
    By hanzacra in forum General Hardware Discussion
    Last Post: 11-27-2007, 03:41 AM
  2. How2 control CarPC from key fob....
    By NotchbackVW in forum Power Supplies
    Last Post: 09-21-2007, 06:27 PM
  3. PC to AMP - AMP to Speakers connection
    By craigt in forum Car Audio
    Last Post: 09-23-2005, 09:36 AM
  4. Replies: 25
    Last Post: 08-04-2005, 12:49 PM
  5. Replies: 21
    Last Post: 07-22-2005, 02:35 PM
