Results 1 to 10 of 17
Thread: very strange power problem
    May 2006
    Belgium
    Hi, I have a very strange problem with my power...
    i have 2 amps connected and 1 pc.
    as soon as an amp of pc use power, my power drops to 3 volts, making my system shut down.
    today i took everything out of the car, and reinstald it, and I played again, for about 5 minutes... then the same thing happenend...
    the same install played very well in my previous car, exactly the same way as it is now...
    anyone gat any idea why this happens?
    Greetz
    Dj NRG
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Your wiring does not support the amount of power you are drawing or is not installed correctly.
    TruckinMP3
    Read the FAQ!
    Mar 2006
    Colorado, but Canadian!
    What guage wiring are you using? How is it wired? Obviously this is a power problem, yet no details to how your wired it...
    Common distro, all seperate to battery, what? Also you dont have your PC specs in your name, so what are you trying to power? See the recurring theme?
    1.9in x 2.9in -- 47mm x 73mm
    Oct 2006
    What gauge wires do you use to power the PC? Do those wires run from the battery? How much current does your system draw (PC, amps, etc..)
    Damn, 3 replies w/ the same comments in 2 min. This forum rocks. Too bad I was the slowest one.
    May 2006
    Belgium
    I didn't share to many details because my english isn't that good, but hey, i'll give it a try.
    my cables do support the amount of power i'm drawing, since it used to work perfect in my other car (and nothing changed about my instal)
    my main cable is 16mm˛, and splits up to 2 cables from 10mm˛ going to the amps, and 1 cable from 4mm˛ going to my pc.
    my pc has a VIA Epia-MII12000 mobo, a opus 150W DC-DC PSU, 1 gig ddr, 120Gb hard disk (that's the only thing that's changed, my previous one was 80Gb)
    one amp is 4*60watt, the other 2*200watt...
    Greetz
    Dj NRG
    May 2006
    Belgium
    Quote Originally Posted by Borisw37 View Post
    one wire (16mm˛) runs from battery to trunk, and splits up there.
    i have a fuse from 60A near my battery, and fuses from 40A for amp 1, 20A for amp 2, and 15A for PSU.
    those 3 fuses are in my trunk, where my main power cable splits...
    Greetz
    Dj NRG
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    make sure you have a GOOD ground. paint must be scraped off and all. Check all your power connections to make sure they are tight. make sure you don't have a bad fuse.
    May 2006
    Belgium
    Quote Originally Posted by durwood View Post
    I think I have a good ground (exact same voltage in my trunk as on my battery)
    all cables are double checked, all connected very tight, all fuses are also checked... bought some spare ones today, will check them tomorrow...
    Greetz
    Dj NRG
    Sep 2006
    yes but sometimes when something actually tries to pull any current and you have a bad ground, that is when it will show up. Maybe I don't understand what your problem is. One of your amplifiers won't turn on? Or when your amp turns on, everything connected to the power wire is at 3V and not 12V including the PC?
    May 2006
    Belgium
    when my amp or my pc turns on everything on the power wire drops to 3 volt, making my pc to shutdown...
    at first this happened immediatly, but this evening I reinstald everything, and was able to play 5 minutes... then I put the volume a little higher, and my pc fell out again...
    Greetz
    Dj NRG
    ps: allready thanks for your reply's, and trying to solve this...
  1. Strange issue - probably not ground-loop problem
    By Jirka Jirout in forum Car Audio
    Last Post: 08-26-2006, 01:19 PM
  2. Laptop TFT cable extension, strange problem
    By predator1 in forum LCD/Display
    Last Post: 06-27-2006, 04:08 AM
  3. Replies: 0
    Last Post: 04-19-2006, 05:23 AM
  4. Not sure if this is a power problem but...
    By patchan in forum Power Supplies
    Last Post: 06-16-2004, 01:16 PM
  5. Problem testing VIA EPIA w/standard atx power supply
    By khufumen in forum Power Supplies
    Last Post: 11-15-2003, 02:22 AM
