Results 1 to 6 of 6
Thread: Bose amp system
    Newbie boss13's Avatar
    Apr 2005
    florida
    Bose amp system
    Does anyone have a clue how much wattage the factory bose amp puts out per channel
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    my bose put out ~7 wpc @ <2 ohms IIRC to the door subs
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Apr 2005
    florida
    thx that was a big help
    Apr 2007
    i would say anywhere from 7-13w
    Dec 2004
    Los Angeles Ca
    sorry, i posted that in a rush. the spec i approximated was for the 8" woofers in my car. the two woofers are powered by dedicated amps. the subs are below 2 ohms which means that you can halve the power if you hook it up to a 4 ohm speaker. the upper freq. are handled by the head unit and are normal 4 ohm speakers. the rears are also powered off the deck and are 4 ohm speakers. keep in mind this may not be the same across the gm line, it's just waht i know for the the specific gm car that i have. warx was right with his range. i think the woofers see closer to the high value of that 13 wpc then the originally state 7 wpc. though i wouldn't doubt the 'twiddlers' and the rear speakers are down at around 7wpc
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Maximum Bitrate Dennis5587's Avatar
    Nov 2004
    NY
    wow... really low powered....
    2006 Mazda 3
    Behringer DCX-2496
    JL500/1 JL10w6v2
  1. Replies: 97
    Last Post: 03-10-2013, 05:28 PM
  2. Replies: 37
    Last Post: 09-28-2006, 09:10 PM
  3. infiniti bose system input
    By hoodlum in forum Car Audio
    Last Post: 03-10-2006, 02:45 PM
  4. Keeping Bose System with Carputer
    By enkne1 in forum Newbie
    Last Post: 08-13-2005, 01:32 AM
  5. connecting the audio of carpc to a bose system
    By onehunghi in forum General Hardware Discussion
    Last Post: 08-11-2005, 08:14 PM
