Results 1 to 3 of 3
Thread: vst effects with kxproject
    Dec 2006
    Hi there, I have the KX drivers installed on a Audigy 2 zs, but I can't get any VST effects to show up. I have a vst delay and a vst 31band eq in my winamp directory. I pointed kx setup to that directory on install( when asked for VST directory) but I can't see them anywhere in the kx drivers. They both work fine in winamp with the vst bridge, but I want them in the kx dsp. I am using 6 outputs for 2-channel stereo pass filtered for mids and highs and bass and need to (want to) do time correction for my front stage because my tweeters are about a foot closer than the midbass speakers. So basically how the heck do you do it? the delay's that are with the kx effects seem worthless for millisecond type adjustments. I dl'd the UFX pack and I think my version of kx is too new but I need that for the audigy 2 to work? or do I?...Thanks in advance...Andy
    Dec 2006
    anyone?
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    vst effects do not work in the KXdriver control panel. You can only use them in a vst host or the winamp vst bridge plugin.
    If you want to have a time delay, you need to use '"timebalance" or "smalldelay". I don't remember which kx plugin package they are included in but either one will work with driver version 3538. There are links in the wikipedia to get you to the right place plus some basic guides.
  1. Software options for Tuning
    By RedGTiVR6 in forum High End Solutions
    Last Post: 01-23-2009, 09:56 AM
  2. kx and vst
    By carputerdude in forum Car Audio
    Last Post: 04-13-2007, 06:33 PM
  3. VST plugins in streetdeck?
    By cougarz in forum DigitalMods (Scripts / API)
    Last Post: 01-23-2007, 03:24 PM
  4. Screen Transitions, Pic Viewer & Album Art effects
    By DiNASTY in forum Road Runner
    Last Post: 07-18-2006, 12:30 AM
  5. VST Plug-In support - software EQ
    By Quack in forum FrodoPlayer
    Last Post: 03-31-2006, 11:25 PM
