Results 1 to 2 of 2
Thread: Cheapest Aux Input
    Apr 2007
    Cheapest Aux Input
    I have a '93 Ford Taurus which currently has the stock AM/FM radio for sound. I am using an FM transmitter to play music from my iPod but the quality leaves something to be desired. Also, I have very little money and was hoping to get something working for less than $50. Eventually, I'd like to put in some old hardware I have lying around and make a car PC out of it too. So I see a few options:
    1. I have taken out the OEM radio and looked at the circuit. I couldn't see any obvious spots to try to add an input jack nor could I find a guide online. Is it worth poking around in there some more to try find a place to add an input?
    2. Buy a headunit. This would be the simplest choice but the most expensive and I have not been able to find one for less than about $100 with an aux input, even on ebay. Is it possible to find working headunits around, perhaps in junk yards etc.?
    3. After doing some thinking, I realized that a car amp might be just what I need. From what I can tell, it takes a signal in from an RCA cable (probably not the right level?) and drives speakers from it. Car amps are cheaper from what I've found and would make a good upgrade for my sound system.
    Thanks for any help!
    Elsewhere
    1 - If your stereo has controls for a cD-changer, then it's possible to use an AUX-in adapter that could play your iPod through.
    2 - $100 is about right.
    3 - You'd still have sound going through your headunit to the amp.
    How about the Wiki?
  1. Aux input adapter for 94 Acura Integra Factory Radio
    By kevh182 in forum General Hardware Discussion
    Last Post: 04-23-2007, 05:19 PM
  2. Alpine CDM-7856: Can't activate AUX input!
    By Bogeyman in forum Car Audio
    Last Post: 06-21-2006, 08:37 PM
  3. Aux input sound
    By girbot in forum Car Audio
    Last Post: 04-01-2006, 06:17 PM
  4. Replies: 6
    Last Post: 05-19-2005, 08:59 AM
  5. Pioneer cdrb20 aux input
    By redscar in forum Classified Archive
    Last Post: 10-21-2001, 11:57 PM
