Results 1 to 4 of 4
Thread: amp keeps turnig off and on
    Newbie ali7up's Avatar
    Feb 2007
    Georgia
    i installed a rf250.2 amp running my front speakers, it was working fine for a few months now last night i unplugged and moved things around now when i plug it back it it turns off and on.. sound only come for a sec when its on and then off again thanks
    Apr 2007
    have you gone back and checked all the wiring? Does the amp physically shut off? or is it just the audio output? are the terminals stripped? any other symptoms with it? like when the audio starts, it doesn't play at full capacity, etc etc?
    Oct 2006
    Bear, DE, USA
    likely wiring...poor or loose ground, poor connection to terminals, poor remote lead connection, one or more speakers going to ground and throwing the amp into protect...usually amps have an indicator for protection mode, does that light up when it comes out? How's your battery voltage? Lights dimming?
    Since you're not throwing fuses (at least, I hope it's a properly fused system), I'd look at the remote wire and ground leads first.
    Feb 2007
    Georgia
    well it was showing a protect mode light so i checked the speaker wiring and sure enough there was a part of the wire that was broken thanks for the help
  1. Off - On - Momentary Switch?
    By MP3DUB in forum General Hardware Discussion
    Last Post: 07-08-2003, 12:07 AM
  2. could someone please measure 4 points on his sproggy
    By felix99 in forum Power Supplies
    Last Post: 02-27-2003, 11:40 AM
