what fuse are you referring to? 30(ish) Amp fuses on the amplifier and/or the fuse you put on the battery side of the wire from the positive terminal to the amplifier? If so, the fact that they are blowing is most likely not an issue of where you have your remote wire tapped into for its 12V, hardly any current is asked for on that line by the amplifier. If this happens with the speakers disconnected from the amp, you probably have a large paper weight in your ride.
LinkBack URL
About LinkBacks
