Results 1 to 4 of 4
Thread: Need new power for cd player
    Apr 2007
    I have had my 95 grand prix se for a while now and its always had some wierd electrical stuff, the seat belt chime+light come on only when the seatbelt is off, headlights on, and the unlock button is pressed down, there is a funny buzz comming from the dash when the headlights are turned on while the car is off, etc. All fuses in the car are good. All wire connections are secure. I removed the stock radio to install a new cd player using a wiring harness made for my car. My cd player will only turn on when my headlights are switched on, when I try inserting a cd, the cd player flickers and takes the cd in very slowly, now I cant get my cd out. Is there a way to rewire the power to my cd player so I can make it work right without having to spend hundreds of dollars on a mechanic to fix it?
    Mar 2006
    Colorado, but Canadian!
    this forum is for CarPC's...
    And just wire it direct to the battery with some alligator clips or something.
    1.9in x 2.9in -- 47mm x 73mm
    Maximum Bitrate Dennis5587's Avatar
    Nov 2004
    NY
    sounds like its time to start saving for anew car...
    2006 Mazda 3
    Behringer DCX-2496
    JL500/1 JL10w6v2
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    sounds like you might have wired your radio's power wire conencted to the wrong wire-probably dimmer or illumination wire. Make sure you have it wired with a constant 12V and switched ignition, not dimmer and illumination unless the radio has a wire for that.
    Also, I will restate this...this site is dedicated to installing carpcs, not headunits. There is a sticky that you might to read. hint hint
  1. DC-DC Car Power for Mac Mini
    By MikeH in forum MacCar
    Last Post: 02-19-2005, 01:13 PM
  2. Power Question/Setup Question, minibook pc
    By seamonkey420 in forum Newbie
    Last Post: 05-17-2004, 10:47 PM
  3. Replies: 2
    Last Post: 05-11-2004, 12:07 AM
