Page 1 of 6 123456 LastLast
Results 1 to 10 of 55
Thread: Uh oh. My car smells like asphalt
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Hi.
    Well, I couldnt find any Peal n Seal locally. The only product that resembled it that I could find was Bakor Blueskin. It says its made out of rubberized asphalt. So I bought a roll of that and did my rear doors and trunk lid yesterday. My car hasnt been sitting in the sun (in the garage) and it already smells a bit like asphalt. The smell isnt too strong, but Im worried it will be worse if left out in the sun. Anyone have any tips? Please tell me this smell will go away after a week.
    FLAC XC-C30's Avatar
    Jun 2006
    Abele, Belgium
    I'm afraid you're screwed. The smell might be going away a little, but if it already is noticeable without paying attention to it....
    Xenia & Isabelle, totally in love!
    'T SQiekenkot: VOLVO 740GL 2.3
    CarPC: none at the moment
    CLARION HX-D2
    CLARION APA4300HX => Fountek NeoCd1.0 + TB W4-1337SD
    CLARION APA4300HX => CSS Trio8
    CLARION APA2100 => Dayton IB385-8
    Maximum Bitrate Ruffy's Avatar
    Sep 2006
    Georgia
    Peal N Seal is the same way. It might go away. But expect the smell to come back in hot weather.
    Sucks to be you, next time do it right and buy secondskin or Raamat BXT.
    http://www.sounddeadenershowdown.com/
    I should know, I did the peel n seal route in my Jeep grand cherokee. it went away after awhile but if i left it in the sun all day it would come back.
    Car : 00' Chrysler 300M
    Speakers : Rainbow Audio SLC 265 | Subs : Diamond Audio D6 12" Subs X2
    Amp's : Hifonics ZXi 6006 AB | Hifonics BXi 1606 D
    CarPC: HP Laptop AMD Sempron 3000+ | 1.5GB RAM | DVD+RW | 80GB 5400RPM HD | ATI R200 Video
    Apr 2007
    You might want to see if you can get if off while it's still fresh - better that than have it melt during the summer. It isn't a very good vibration damper to start with and it will smell until all of the VOCs outgas, at which point it will be an even worse sound deadener. Did I mention that those VOCs are toxic?
    Apr 2007
    wait, why isn't it a good vibration damper? and why would the VOCs actually adversely affect the sound deadening abilities of it? That honestly doesn't quite make sense to me, so please elaborate.
    Apr 2007
    Quote Originally Posted by WarX View Post
    Asphalt is a plastic material while it holds the VOCs, that is to say, when it is deformed, it stays in its new shape. Elasticity is an important property for vibration dampers. As an elastic material is deformed in response to vibration, internal stresses pull the material back toward its original shape. These stresses convert the vibration into very small amounts of heat, basically taking them out of play. Without this elastic action the only way a material can work is by adding mass, lowering the panel's resonant frequency and increasing the energy needed to excite it or by stiffening the panel, raising the panel's resonant frequency and again increasing the energy required to set it in motion.
    While the asphalt is still pliable, some energy is converted during deformation and the asphalt is slightly heavier. These two factors give pliable asphalt a theoretical advantage over dried out rigid asphalt.
    I have no numbers to support this theory of pliable versus non-pliable asphalt. My real intention was to emphasize the very poor choice asphalt is for in car use. The most important problem asphalt mats encounter with age is the deterioration of the rubber stabilizing compounds they contain. As asphalt ages, it becomes less and less able to tolerate heat. This is why it is very common for it to survive one or two summers in a car and melt out on the second or third - not to say that it might not melt during the first hot weather in encounters.
    The fact that the fumes are low level toxins are likely to be overlooked by people trying to save a buck. The very real possibility that the mat will either fall off or melt, potentially damaging carpet and upholstery is more likely to discourage them. In have gotten hundreds of e-mails from people whose asphalt installations have failed and none from those using butyl products.
    Leaving stability and reliability out of consideration, the fact that butyl is so much more effective than asphalt provides a better way to save money. If you planned tp buy $100 worth of Peel & Seal, buy $100 worth of a quality butyl mat instead - just spread it out. Even if you lay it out in a checkerboard pattern, you will get results that are at least as good, without any of the problems.
    Maximum Bitrate Dennis5587's Avatar
    Nov 2004
    NY
    does ruber butyl stink up your car?
    2006 Mazda 3
    Behringer DCX-2496
    JL500/1 JL10w6v2
    Apr 2007
    Quote Originally Posted by Dennis5587 View Post
    No, but be careful - several products sold for this purposeintentionally want to confuse you between rubber and butyl. Rubber is a butyl-like material and asphalt has rubber added to it. Be real sure it is butyl you are getting. At least one company is outright lying and saying their asphalt mat is butyl.
    Oct 2004
    NY
    yeah, now you've learned first hand that sometimes saving a buck can cost more in the end.... I'd say rip it out & start over... check out b-quiet, there comperable to dynamat & a bit cheaper...
    Apr 2007
    Quote Originally Posted by turbocad6 View Post
    But only B-Quiet Ultimate. B-Quiet Extreme is asphalt and I curse them for selling it. Also look at Second Skin and RAAMmat.
  1. What's your dream car?
    By Aaron Cake in forum Off Topic
    Last Post: 10-02-2007, 08:34 AM
  2. In a real PC car struggle
    By markland556 in forum Off Topic
    Last Post: 06-27-2007, 12:36 PM
  3. Replies: 9
    Last Post: 06-08-2006, 06:15 PM
  4. Employee Discounted Cars: Flatout BIG LIE!
    By sdashiki in forum Off Topic
    Last Post: 10-31-2005, 06:53 PM
  5. Car PC EZ 2.4 SDC/Inverter Controller - NOW Avail!
    By hd54321 in forum Power Supplies
    Last Post: 02-24-2005, 01:42 PM
