Results 1 to 10 of 14
Thread: speakers stop when car stops
    Apr 2007
    memphis
    Hi everybody this is my first post. I've been reading the forums for awhile and last week I put a carputer in my civic. But I do have two problems with the audio that I am clueless about.
    1) When I drive the car the audio works great but when I stop at a red light the sound stops, but picks right back up where it left off as soon as I hit the gas. I know the amp doesn't shut off and the computer is still playing the music. I have no clue whats wrong.
    2)When the car key is in the ACC position no sound comes from the speakers even though the carputer is on as well as the amp. The sound only comes throuh when the car is cranked even though the amp is already on.
    My audio setup is a 4ga wire to a distributor in the trunk, from there the amp is hooked up with 8ga power wire and an 8ga ground wire and of course the speakers are hooked to the amp.
    Any help would be much appreciated as I know little about car audio.
    I love this site and my carputer thanks for eveything yall do.
    Maximum Bitrate GoHybrid's Avatar
    Jun 2006
    Denver, CO
    need more details: how do you control your computer... you say the music "picks right back up where it left off" this says that the computer is actually NOT still playing the music when you stop at a light.
    also, what kind of amp are you using? what kind of battery? what is the state of charge? stock alternator?
    all that stuff is helpful in solving this. please advise.
    Apr 2007
    memphis
    The carputer is controlled by touch screen, when I stop the song time counter continues as if still playing, my amp is a 4 ch 300 watt power acoustik, I have a duralast 3 or 4 year old battery with stock alternator.
    Sorry for the lack of information. Thanks for quick reply.
    Jun 2006
    Denver, CO
    here is the first thing i would do: get a discman, ipod, whatever... something you know has a functioning output. plug that into your amp instead of the computer. turn your car to ACC, verify the amp turns on, and then push play on the ipod. if you get music on ACC or at a stop light, the problem is in your PC. if not, i'd check your remote wire, 12V+ and ground wires. make sure they're in perfect shape, and the ground is good and clean to the metal. make sure that amp is getting all of the 12 volts it needs.
    Apr 2007
    memphis
    So I hooked up my ipod when the key was in the ACC position and no musi even though it was playing on the ipod. I checked and the amp is on and both ground and power wires are straight to bare metal in the trunk. Any ideas?
    Jun 2005
    chicago, Illinois
    Check on your amp for +12 voltage, remote wire voltage, ground resistance, and your power line fuse resistance with a multimeter. I would also test your amp as suggested above instead with the car on, then attempt to rev your engine and get back with your results.
    Your amp may appear on, but it may not be getting adaquate voltage or current from your battery or altenator.
    PROGRESS:
    Jun 2006
    Denver, CO
    or you might try jumping the +12V on the amp straight to the remote terminal and remove the remote wire and see if the amp actually shuts off when you're not above idle. if that's the case your battery is probably bad if not your alternator as well.
    Apr 2007
    memphis
    Ok so I got a bigger battery and it solved the problem. Thanks everybody for your help.
    _
    Mar 2004
    Little Elm, Texas
    I hope that you had your alternator tested because just replacing the battery won't last long if your alternator is the issue.
    You'll be replacing batteries left and right.
    How big is your alternator on that car? Honda isn't known for putting an alternator that's very big on their cars.
    Depending on your amps and how big they are, you might or might not need a bigger alternator.
    Jan Bennett
    Jun 2006
    Denver, CO
    he said it was a 300W amp... doesn't seem out of this world...
  1. Powering Component Speakers with Car PC
    By solo44 in forum General MP3Car Discussion
    Last Post: 09-28-2006, 02:54 PM
  2. Installing car PC in 1996 Honda Civic
    By PredatorCoder in forum Newbie
    Last Post: 08-18-2005, 08:58 AM
  3. Article: Big Brother in the car
    By VanMan69 in forum General MP3Car Discussion
    Last Post: 08-08-2005, 12:00 PM
  4. Car speakers = 8 ohms? Weird
    By CavityCr33p in forum Car Audio
    Last Post: 04-12-2005, 02:05 PM
