So onboard audio compaired to say a stock car HU? Worse or better?
Jan Bennett
way too many variables to just have a yes or no to that...
yeah, most onboard is horrible, but then again, so is most stock headunits![]()
Jan Bennett
Xenia & Isabelle, totally in love!
'T SQiekenkot: VOLVO 740GL 2.3
CarPC: none at the moment
CLARION HX-D2
CLARION APA4300HX => Fountek NeoCd1.0 + TB W4-1337SD
CLARION APA4300HX => CSS Trio8
CLARION APA2100 => Dayton IB385-8
Kind of reminds me of this post![]()
System always under construction
CLARION HX-D2
just because you've seen this in one or 2 installs, doesn't make it universaly true... there are many variables, & onboard sound can sound better than a crappy headunit in some cases, especially if the pc happens to be very close to the amps & were talking decent amps...
one of the biggest problems with onboard sound is usually the extremely low voltages there driven with, but with a short run you can minimise noise pickup & with a good amp the gain control should be able to accept the lower voltage... it is not impossible to get halfway decent sound from onboard, but again, there are way too many variables to get into here.
I'm not saying onboard sound is great, far from it, but then again, there aren't many great factory headunits either
in the end, I would still highly recommend not using onboard sound anyway, a decent soundcard is the way to go...
heres a perfect comparison of how onboard audio sounds...
First you take a wire mesh bag of rabid cats...
spray acid on them and light them on fire...
lay under the bag and let the flaming acid drip into your ear...
string up a series of hand grenades next to your face to explode every 2 seconds...
have 5000 mexicans compete in a chalkboard scratching contest...
hire ashley simpson to sing...
have fran dresher scream the declaration of independance...
and take a big **** in your mouth.
thats pretty close to being as bad onboard sound.
hope i cleared that up for everyone. =)
