Results 1 to 8 of 8
Thread: weird sound interference only when engine is on!
    May 2007
    I have a inovatek in-car LCD screen head unit. with the engine off, everything plays great including the screen but when i turn on my engine a very annoying noise is produced out of the rear speaker. my rear speakers are amplified. this sound's frequency is directly proportional to the revolutions of my engine.
    does anyone have an idea why this sound is being produced?
    Apr 2007
    your rear speakers are amplifier? re-route the RCAs at least 18inches away from the power wire... so power wire on ONE side of the car, the RCA's on the opposite side of the car
    Maximum Bitrate Dennis5587's Avatar
    Nov 2004
    NY
    yeah, i got a great idea... but I really think all you need to do is
    ps: search alternator wine
    2006 Mazda 3
    Behringer DCX-2496
    JL500/1 JL10w6v2
    Apr 2007
    Quote Originally Posted by Dennis5587 View Post
    How is that anyways? I've never tried Alternator Wine
    FLAC XC-C30's Avatar
    Jun 2006
    Abele, Belgium
    maybe somethink like motor-oil?
    Xenia & Isabelle, totally in love!
    'T SQiekenkot: VOLVO 740GL 2.3
    CarPC: none at the moment
    CLARION HX-D2
    CLARION APA4300HX => Fountek NeoCd1.0 + TB W4-1337SD
    CLARION APA4300HX => CSS Trio8
    CLARION APA2100 => Dayton IB385-8
    May 2007
    took your advice
    i looked up alternator wine and i disconnected my RCA cables from the amp while my engine was on. when i disconnected the cables the sound went but then when i plugged them back in it came back on. does this help anyone deduce the problem?
    Apr 2007
    Try changing the earth of the amp to a different point. Check all connections running to and from the head unit to the amp ect because that can also cause interference.
    UV7
    UV7 is offline
    Newbie UV7's Avatar
    Mar 2007
    ...In my own little world
    What you are describing is a symptom of a ground loop. A ground loop occurs when there is a difference in potential between ground points. The most likely culprit in this case is your amplifier's ground. Ideally, all electronics would ground to the same point, thereby eliminating any possibility of a difference in potential, but this just is not possible. Since the majority of the electronics in the car ground to the frame, the best possible location to ground the amplifier is also going to directly to the frame, or as close to it as possible. Seat bolts, bracket bolts, etc., anything that will make solid, metal-to-metal contact as close to the frame as possible is going to be a good ground. You also need to ensure the ground point is clean and clear of any resistance. You will want to grind away any paint, remove any insulation, padding, dirt, carpet, etc., from the ground location so that the amplifier's ground makes as much contact as possible with as little resistance as possible.
    I hope this helps.
    True knowledge exists in knowing that you know nothing. True wisdom comes to each of us when we realize how little we understand about life, ourselves, and the world around us.
    -Socrates
  1. Weird video interference problem! HELP!
    By lookinco in forum LCD/Display
    Last Post: 03-18-2011, 07:10 PM
  2. Creative Labs Sound Blaster® Live!™ 24-Bit External USB 1.1
    By SpyderHatch in forum Classified Archive
    Last Post: 11-28-2005, 05:12 PM
  3. Noise (from engine and other sources) HELP!!!
    By sstylos in forum Car Audio
    Last Post: 09-20-2005, 01:41 PM
  4. Invertor causing a "buzz" sound
    By fireball106 in forum Power Supplies
    Last Post: 01-18-2005, 01:09 PM
  5. got sound?
    By masch in forum Newbie
    Last Post: 11-17-2003, 10:01 AM
