Hmm, all that extra antenna wire may cause a problem (reception-wise). Maybe running a USB extension cable from the trunk to the front would be better, I think USB can "go" for longer distances without a problem, while the antenna is already far (rear to front, then front to rear might be too much). I agree with not messing with the wiring in the windshield, if you mess up either you need a new windshield or an (ugly) external antennagood luck!
LinkBack URL
About LinkBacks
good luck!
